Spin on filter
Discussion in 'General Tundra Discussion' started by InfernoTundra, Oct 8, 2021.
  1. Oct 8, 2021 at 7:42 AM
    InfernoTundra
    InfernoTundra [OP] New Member
    I just put on the Baxter TS-301-BK spin-on filter adapter on my 2021 SR5. The filter I used was Mobil 1 M1-209A which is one of the ones recommended. It seems to hang very low and my truck didn't come with a skid plate.
    Is anyone using this setup and what filter are you using and are there any problems fitting a skid plate with the filter. I don't mind getting a skid plate if it will fit.
    RitcheyRch likes this.
  2. Oct 8, 2021 at 7:50 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    It looks like you have a coolant leak too…
    NewImprovedRon, Ely010606 and 2mchfun like this.
  3. Oct 8, 2021 at 7:54 AM
    InfernoTundra
    Thanks, I saw that but didn't see anything around the hoses. I will clean it this weekend and see if it comes back. Didn't have a smell either, thinking it might be some cleaning agent they used to detail it when I bought it.
  4. Oct 8, 2021 at 8:25 AM
    2mchfun
    No factory skid, seems strange.
    Oey12 likes this.
  5. Oct 8, 2021 at 8:27 AM
    2mchfun
    Why tamper with the filter design?
  6. Oct 8, 2021 at 8:32 AM
    Danman34
    Danman34 New Member
    Danny
    Could be a 2wd truck.
    2mchfun[QUOTED] likes this.
  7. Oct 8, 2021 at 8:33 AM
    Danman34
    Danman34 New Member
    Danny
    Hmm. That definitely looks like coolant. It’s possible they topped off your overflow and spilled a bunch in the process. But that’s a whole lot of splashes at the bottom of the motor to be from spillage up top.
  8. Oct 8, 2021 at 8:42 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Hangs way too low for me as well. My truck also doesn't have a skid plate. I bought it used so not sure if it was removed by the prior owner or the dealership since they were the only ones that worked on it before I bought it.
    NewImprovedRon and Saltyhero13 like this.
  9. Oct 8, 2021 at 8:48 AM
    InfernoTundra
    Yeah 2wd, my other was 4x4 and had the skid plate.
    2mchfun likes this.
  10. Oct 8, 2021 at 8:50 AM
    InfernoTundra
    I'm getting old and it just seems easier, plus it mentioned the anti-drain valve would help. No clue if that's true or not.
  11. Oct 8, 2021 at 8:55 AM
    InfernoTundra
  12. Oct 8, 2021 at 8:56 AM
    InfernoTundra
    I did see a post that mentioned Wix 51335 which is shorter so I might look at that one.
  13. Oct 8, 2021 at 9:05 AM
    18" TRD Off Road Wheels
    Non Pro Tundras that don't have the TRD Off Road package don't get skids. 2wd or 4wd doesn't matter so long as it has the OR package.
    For what it's worth, the stock skids are crap anyway. Very thin and flimsy.
    Tundratoofun likes this.
  14. Oct 8, 2021 at 9:09 AM
    Danman34
    Danman34 New Member
    Danny
    My TRD Sport 4wd came with a skid plate.
  15. Oct 8, 2021 at 9:13 AM
    Hmm. That's new info. Everything I've found for the 2014+ indicated only the OR package included them. Perhaps the dealership added it? Or did you buy used and possibly the PO added one?
  16. Oct 8, 2021 at 9:15 AM
    Danman34
    Danman34 New Member
    Danny
    Nope. Bought it brand new with 3 miles on it. A friend of mine also has an 18 TRD Sport he bought new. His also has a skid plate.
    GODZILLA[QUOTED] likes this.
  17. Oct 8, 2021 at 9:20 AM
    Very curious. :monocle:
    I wonder if I messed up in the look ups I did and only looked at the stuff after 2018, or if maybe the Toyota site didn't have the proper stuff in the package lists. Might just be that the skids are on any of the TRDs.
  18. Oct 8, 2021 at 9:25 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  19. Oct 8, 2021 at 9:34 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My 2wd non trd truck came with the factory skid
  20. Oct 8, 2021 at 9:40 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    screw the skid plate and lift the dang truck already
    InfernoTundra[OP] and 2mchfun like this.
  21. Oct 8, 2021 at 9:48 AM
    2mchfun
    My trail came with skid too. Not really much more than an air dam though. Such a joke, why bother.
  22. Oct 8, 2021 at 10:03 AM
    InfernoTundra
    My 2018 4x4 non pro or OR package had a skid plate. I was just surprised when I looked and it didn't have one. Also my son's 2013 2wd had one.
  23. Oct 8, 2021 at 10:07 AM
    InfernoTundra
    Good call on the coolant leak, went out at lunch to clean everything and noticed that the top radiator hose had leaked at the engine side. Should I replace the clam? Didn't see it leaking while I had it running but wasn't up to temp yet.
  24. Oct 8, 2021 at 10:07 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    My buddies 2008 SR5 the steel wheels had a skid plate when he bought it brand new.
    Hbjeff likes this.
  25. Oct 8, 2021 at 10:08 AM
    Well shit. I guess Oprah decided that everybody was getting a skid plate.
    Maybe plate use is regional. I obviously don't know. :notsure::rofl:
  26. Oct 8, 2021 at 10:10 AM
    2mchfun
    Definately replace that clamp and fill the coolant. Then keep an eye out for leaks in the future, such as puddles where you park at places.
  27. Oct 8, 2021 at 10:16 AM
    InfernoTundra
    Will do, thanks.
  28. Oct 8, 2021 at 10:21 AM
    adamreinhardt
    adamreinhardt Blk 17 Platinum 4x4
    Seattle
    2017 Platinum in Midnight Black Metallic
    I might be wrong, but you may be thinking of the TRD skid plate which is unique to certain trucks. Can’t understand why, but my 17 Platinum has the other style skid, the big ugly black POS that doesn’t even have oil filter access. I think that one is found on many trucks without a TRD package.
  29. Oct 8, 2021 at 10:26 AM
    Nope, I'm talking about the little black one. The TRD skid is standard on the Pro, but I think it's an added option for any other. But I have already demonstrated I don't know sh*t about what trucks get skids, so.....
    adamreinhardt[QUOTED] likes this.
  30. Oct 8, 2021 at 10:27 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My radiator had a super small crack and leaked pink fluid all over just like that. They had to pressure test it to find the crack. Replaced under warranty
