  1. Oct 5, 2021 at 11:35 PM
    daveeasa
    Oh, and also, @shifty`, I'm assuming there is a little trick to getting the stock rearview mirror off on the Tundra? small slotted screwdriver to release some tab I can't see? No visible torx on my OEM one, but I'm hoping the metal mount behind it is the same style.
  2. Oct 6, 2021 at 2:48 AM
    Openbaffle
    Openbaffle New Member
    +1. This is on my list to purchase and install too.
  3. Oct 6, 2021 at 3:16 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  4. Oct 6, 2021 at 6:43 AM
    So there is definitely no easy spot to try and mount my air compressor intake filters INSIDE the cab near the firewall like I had done in the 4runner; the firewall seemed to have a lot more open space.
    so for now I will just mount them on the compressor and run it. I’m tempted to just mount them in the cowl but that’s a project for later, I already have the hose and fittings.
    I’m thinking of places to put the air chuck near the rear end. As of now I plan on using a bulkhead fitting at the very rear corner of the bed.
    bmf4069, alb1k and oscardog86 like this.
  5. Oct 6, 2021 at 6:47 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I was thinking running the air intake from that passengers grommet to behind the the radio or glove box.
    If you run the air line from the driver's grommet, you can hide it underneath the carpet on the floorboard.
  6. Oct 6, 2021 at 6:55 AM
    Which passenger grommet are you referring to? Maybe I couldn’t see the forest thru the trees.
    the airline itself, I’m not to worried, it will probably run under the truck since the water separator and tank will be under there. I’m trying to think of a convenient and clean-ish area to mount a air chuck for filling hose and what not.
  7. Oct 6, 2021 at 7:06 AM
    des2mtn
    SW
    Tonto cover
    Behind the ABS module, there is a grommet you can cut into and run wires and possibly an air line through. Inside the cab it's kind of hidden behind the blower motor and one of the kick panels.
  8. Oct 6, 2021 at 7:08 AM
    Ok cool! Thanks for that. I’ve got other shit to focus on, so that will have to wait.
    des2mtn[QUOTED] likes this.
  9. Oct 6, 2021 at 7:26 AM
    Should just be a 4mm (5mm?) allen to loosen the bolt fixing the mirror to the gravestone/wedge glued to the windshield. Loosen that allenhead pinch bolt and GENTLY slide UP the rear view mirror. If it hasn't been removed once within the last 6-12 months, chances are it may be stuck. If so, be careful you don't rip the glued wedge off the window, as has happened to a great number of people who've replaced their mirror in the past. Best advice is to gently wiggle the mirror off the wedge on the windshield.
    Can't reiterate this enough, so I'll re-write here in ALL CAPS: BE CAREFUL WHEN REMOVING THE MIRROR. YOU DON'T WANT TO SNAP THE MOUNT OFF THE GLASS.
    This should show the process nicely, starting at the 55s mark:
    https://www.youtube.com/watch?v=n2bO_xqAekw#t=0m55s
  10. Oct 6, 2021 at 7:51 AM
    daveeasa
    Yeah, my tundra has no visible torx/Allen. I’m guessing yours did? My Tacoma did as well. I’ll hunt Google.
  11. Oct 6, 2021 at 7:52 AM
    Send a pic
  12. Oct 6, 2021 at 7:59 AM
    daveeasa
    Forgot to take one yesterday. I did get shots of the engine bay though. It’s always the photo you didn’t take that you want.
  13. Oct 6, 2021 at 8:00 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
  14. Oct 6, 2021 at 8:05 AM
    daveeasa
  15. Oct 6, 2021 at 9:35 AM
    daveeasa
  16. Oct 6, 2021 at 10:35 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Anyone know of a shop willing to build a grumper style bumper? With a built in grille? Is a front receiver really as useful as i think its gonna be? Ive used em for trailers, but im thinking implements. Dual receivers in front (and braced) of the frame horns?
  17. Oct 6, 2021 at 10:46 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Had some fun with the forklift at work today. Clearances look good.
  18. Oct 6, 2021 at 10:48 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Didja measure hub to fender?
    Does this forum do truck of the year?
  19. Oct 6, 2021 at 11:04 AM
    KarmaKannon
    Utah
    Some junk
    I didn't. It travels about 12-14" though. I measured that when I was building the mounts. Maybe it was around 31" when I measured that from hub center to wheel well?
    Sirfive[QUOTED] and oscardog86 like this.
  20. Oct 6, 2021 at 12:39 PM
    Openbaffle
    Got some update pictures today from the shop. Should have it back tomorrow after they finish putting it back together and align it in the morning. I'm pumped. I think it looks good.
    bmf4069, RUSTYNUTS, Kimosabe and 5 others like this.
  21. Oct 6, 2021 at 1:28 PM
    daveeasa
    I would dig this as well. All the front bumpers I’ve seen don’t do it for me. And I’m also struggling with the grille. Would be very tempted if it were light and attractive.
    des2mtn and KarmaKannon like this.
  22. Oct 6, 2021 at 3:34 PM
    Casper421
    In the woods
    06 DC
  23. Oct 6, 2021 at 3:41 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Rear diff is wet?
    NUDRAT and shifty` like this.
  24. Oct 6, 2021 at 3:55 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Does anyone know if sun visors from a 4runner or sequoia also fit the tundra? I'd like to swap out for one that has a mirror cover. It's a small complaint, but when I put the visor down it's a little distracting having a reflection in the mirror while driving.
    I'd like something like this but don't need or want the illumination.
  25. Oct 6, 2021 at 4:17 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    1st gen Sequoia will fit DC's iirc. Dunno about other models.
    I found it distracting also, so I ordered a visor without a mirror for my driver side. Just gotta install it.
  26. Oct 6, 2021 at 5:13 PM
    KarmaKannon
    Utah
    Some junk
    Was wet. The rest of the diff has surface rust. The fill plug leaking protected that section.
    Tundra2[QUOTED] likes this.
  27. Oct 6, 2021 at 6:06 PM
    Huh. Never seen one like that before.
    You know, taking the old tombstone off with a removal kit and gluing on a new one isn't terribly tough.
  28. Oct 6, 2021 at 6:17 PM
    daveeasa
    That's a possible plan too. I'll see how much I like that adapter.
  29. Oct 6, 2021 at 6:19 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Started packing the truck for my Tennessee trip. I discovered that nothing fits in my drawers.
    everything is about 1/4” too big. Wash tubs, my tent, my air compressor.
    :annoyed:
    hammeron likes this.
  30. Oct 6, 2021 at 6:20 PM
    4FEE924C-7CB4-46BA-85A3-27261642C989.jpg CF9CA143-CA84-432A-B9DB-A18AFEDC7024.jpg Mounted my water separator and final mounted the air tank with all fittings except the drain valve. Trying to get ahead of all these little things, so as parts and materials show up, I can knock it out. Mainly just a few fittings and air line that I’ll grab from a buddy this weekend.
    bmf4069, Darkness, Desert Dog and 8 others like this.
