A/T temp light shutting off truck
Discussion in '2nd Gen Tundras (2007-2013)' started by Jay12trd, Aug 13, 2019.
  1. Aug 13, 2019 at 3:56 AM
    Jay12trd
    Jay12trd [OP] New Member
    2012 Trd 5.7
    S&b intake, 2-1 leveling kit
    ok so I have a 2012 trd crewmax with the 5.7 and about a month ago on the way home from work my a/t temp light and check engine light came on and my truck shut off. I turned the key off started it back ran fine....until Sunday, I hauled my 5x8 trailer about 50 miles (no heavy load just 2 dressers) and it did it again. I restarted it ran good for another couple miles I met my client exchanged the furniture (sat in one spot for 45min/hr) then proceeded home. That’s when the fun started. Every qt mile it kept shutting off. I’d coast turn the key off put it in neutral then restart and it’d drive fine for another qt mile shut off. There was no slipping, slamming or weirdness in the tranny prior. Now when I start it it’ll idle for about a min then shut off with the a/t temp light and check engine light. Any ideas? I checked the gas that’s good, tranny temp never went above normal. Hoping maybe bad sensor?
  2. Aug 13, 2019 at 4:29 AM
    koditten
    koditten New Member
    Any chance you have rodents chewing on your engine wires?
  3. Aug 13, 2019 at 4:40 AM
    Jay12trd
    2012 Trd 5.7
    No rodents that I know of
  4. Aug 13, 2019 at 4:42 AM
    Jay12trd
    2012 Trd 5.7
    Oh and there’s only 42,000 miles on it with regular 5000 mile services
  5. Aug 13, 2019 at 6:01 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Have you scanned the codes?
  6. Aug 13, 2019 at 6:03 AM
    Jay12trd
    2012 Trd 5.7
    I will be tonight friend was going to bring his up to read it but was sick so hopefully tonight I’ll have some kinda answers. Just wasn’t sure if anyone else has had this problem
  7. Aug 13, 2019 at 6:06 AM
    e30cabrio
    My transmission completely failed at 18x,xxxk and never did this. It lost reverse & stopped going above 4th, never killed the truck.
    Sounds like a sensor or computer issue to me.
    Good luck
    08crewmax likes this.
  8. Aug 13, 2019 at 6:26 AM
    Jay12trd
    2012 Trd 5.7
    Yeah hoping so, ya made my heart skip a beat there when I started reading lol
  9. Aug 13, 2019 at 4:13 PM
    Jay12trd
    2012 Trd 5.7
    Well ran a scanner on it after it’s been sitting at home all day. Did a live data read on it and be fore I even started the engine it said my trans temp was 150f? Shut it off it goes down to 0 start it right to 150f then the truck shuts off...any ideas where this pos of a sensor is located so I can replace it lol
  10. Nov 22, 2020 at 2:56 PM
    Petenebraska
    Petenebraska New Member
    Pete
    2009 5.7L TRD
    K&N airfilter, throttle body coolant bypass, Dirty Deeds 8" BAM exhaust
    Hi Jay12trd,
    Did you ever find a solution to your warning light issue? I'm having the same problem. Looking for a fix.
    Thanks!
    Pete
  11. Oct 6, 2021 at 5:32 AM
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    Also experiencing the same issue at the moment can anyone tell me what fixed your issue?
  12. Oct 21, 2021 at 10:16 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    well since this thread was re-cracked open for Trans temp sensor here ya go.
    TTund16 likes this.
