  1. Oct 5, 2021 at 12:30 PM
    a_double
    a_double New Member
    Is the intent of this mod to relocate the breather to a higher elevation to prevent liquid/water ingestion on the differential ?
    TampaRD Pro, Mike59 and RainMan_PNW like this.
  2. Oct 5, 2021 at 12:31 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    ^^Yup!
    THinTX and a_double like this.
  3. Oct 5, 2021 at 12:53 PM
    a_double
    a_double New Member
    Tow/haul mode while not towing is what I’d expect from a 32V 5.7L.
    It hauls!!
  4. Oct 5, 2021 at 1:56 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Your in luck , there is a pair of mirrors off a 1794 with all your options for sale on the forum.
  5. Oct 5, 2021 at 3:03 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    You can’t swap housings. The hinge is captured in such a way it’s not really able to be disassembled without destroying it
    3xYOTA likes this.
  6. Oct 5, 2021 at 3:09 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Yes, correct.
    a_double[QUOTED] likes this.
  7. Oct 5, 2021 at 3:37 PM
    kittyhawk
    kittyhawk New Member
    Dave
    Houston/Buffalo Texas!!!!
    2015 Tundra Crewmax SR5 4x4
    6112/5160. Ranchhand rear bumper and Valhallas Shields.
    Finally got around to installing Coach Builder +1 from the group buy this spring. I'm kicking myself for not installing them sooner. Drove up to the ranch and back to drop off some stuff off. It was around a 275 mile round trip, took some back roads and was impressed with the ride expressly with around 500 pounds in the bed it was such a better ride. They definitely let the 5160 do there job.
  8. Oct 5, 2021 at 3:54 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    good point, although I wasn’t thinking about disassembly at the hinge point, more as an entire piece… if he popped off the mirror, electronic motor, and wiring on his current, and then removed the mirror off a manual folding SR5 version, he could reassemble with his motor, mirror glass, route wiring through the newly installed housing, and attach as a complete assembly… I had forgotten about the puddle light at the bottom which would require some fabrication (i.e. drill a hole and move the translucent lens over from the original housing). Just a guess if it were worth investigating as a significant cost savings :confused:
    saw someone had listed some take-off, direct matches for a reasonable price which would be the easier/better route.
    Jcmf52 likes this.
  9. Oct 5, 2021 at 4:04 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    This is totally doable. Once the round mirror motor base is removed you'll see the screws that attach the outer housing to the inner arm of the mirror assembly. The two separate easily. Someone may even have the exact plastic outer housing that he needs, sitting in storage
  10. Oct 5, 2021 at 4:15 PM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    I finally got rid of all the chrome. Had a local body shop paint the trim pieces and I gotta say it came out pretty good.
    GAknight, Yzed608, nhw544 and 18 others like this.
  11. Oct 5, 2021 at 4:33 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Your mirror has the motor, so you can take it apart.
    The inside of the non-power-fold mirror has a spring that is captured by a plate and a toothed spring washer that I've only seen taken apart destructively.
    I'm pretty sure you're going to be stuck at least getting your hands on another motorized mirror to be able to swap parts...
  12. Oct 5, 2021 at 4:56 PM
    thomasbus337
    2020 TRD Sport DC
    1934D5E1-49DB-4044-81D3-C34FA1611247.jpg 83E3CFF1-AFDC-4367-AEE3-850924798F46.jpg
    I’ve swapped parts between a Platinum/1794 and SR5 mirror when I did a power folding retrofit on my dad’s SR5 and again when I added the auto dim/side mirror signal modification to mine. Looking at the attached pics will give you a clearer idea. The housing and the folding base are easily separated as the housing is held to the folding arm by one snap clip and two screws circled in red. The mirror motor is attached by four screws shown in blue
    GAknight, Cosmoblu, Jcmf52 and 3 others like this.
  13. Oct 5, 2021 at 5:08 PM
    TaquitoBandito
    Joel (AKA Bif)
    My uncle passed away last week and to get my mind off of it, I started reading @RainMan_PNW build thread. I bought and installed Seat Jackers on the front seats. I also put some TVDecals Mountains on the truck and added their heritage vinyl to the front grill. I bought some American flags but I think it'll just be too much going on. I know a guy in town that'll detail the truck for $35, so that'll be happening soon.
  14. Oct 5, 2021 at 5:11 PM
    Do58
    Do58 New Member
    Sorry for your loss!…. Looks good on a side note
  15. Oct 5, 2021 at 5:12 PM
    Sorry for your loss Joel.
  16. Oct 5, 2021 at 5:45 PM
    3xYOTA
    3xYOTA Taco/Rav/Tundra
    Far West Texas
    2020 Tundra 1794
    Yes siiiirrrr
  17. Oct 5, 2021 at 6:07 PM
    Steve18
    Steve18 New Member
    Virginia Beach
    2016 Black 4Runner Trail and 2021 Black Tundra TRD Pro
    Driver side was a PIA to install, but they are definitely worth it!
    VTYOTER[QUOTED] likes this.
  18. Oct 5, 2021 at 6:17 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Just finished installing Baja Designs SAE fog lights. Had a slight problem right out of the box but Hunter at BD took care of the situation, incredible customer service. I wired them to my Switch Pros so I can activate any time and also be used as emergency flashers. 20211005_172002.jpg 20211005_172039.jpg
    As a side note: I used clear rtv on the surround and, installed 2 flat washers between the mounting brackets and lights on both sides. It created a tight fit and no more shakey fogs
  19. Oct 5, 2021 at 6:37 PM
    AZ Red Nek
    Chuck
    Unfortunately I cancelled my reservation for Tundras 2 Sedona. My niece is in hospice care and I'll be heading to Idaho just don't know when. When I registered the trail runs were booking up fast so I wanted someone to have the opportunity to go. Still hoping to get up there to meet you and see all those fantastic Tundras.
    Cosmoblu likes this.
  20. Oct 5, 2021 at 6:45 PM
    Prayers for your niece and your family. Life is definitely not fair at times.
    NewImprovedRon likes this.
  21. Oct 5, 2021 at 6:47 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Ok - that part of the disassembly I missed when I had looked before. Got to know!
  22. Oct 5, 2021 at 6:48 PM
    AZ Red Nek
    Chuck
    Thank you for your kind words
    Tundra234[QUOTED] likes this.
  23. Oct 5, 2021 at 6:49 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Sorry to hear about your uncle. :(
    The truck is looking good.
  24. Oct 5, 2021 at 6:54 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Does the clear have an amber backlight, or only the amber light bar?
    TaquitoBandito likes this.
  25. Oct 5, 2021 at 6:58 PM
    Yes the clear does have the amber backlight.
  26. Oct 5, 2021 at 7:00 PM
    Sorry to hear this Chuck. Prayers for your niece.
  27. Oct 5, 2021 at 7:02 PM
    GAknight and mgm16trdpro like this.
  28. Oct 5, 2021 at 7:06 PM
    Fire343fighter
    Fire343fighter New Member
    Charlotte NC
    2020 Tundra Platinum
    Window tint, ceramic coating, Tyger auto blade steps,Winjet led taillights,JDM led puddle lights, paint matched mirror covers, Gator EFX hard folding tonneau cover, BFG KO2 tires, paint matched door handles, morimoto headlights
    Installed paint matched door handles. Had to remove driver and passenger front door panels due to smart key system. But still an easy job. 2021918F-FAA9-485D-A19A-8E974ADDED89.jpgF8F59698-71EE-4034-BDA5-CF493DE4C082.jpg 61DA4BC5-F9C8-4CCD-B1ED-5C17E7330F8D.jpg
    Blueknights75, 3xYOTA, JDR76 and 6 others like this.
  29. Oct 5, 2021 at 7:17 PM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    When there are bright lights shining on glass, it will dim the reflection so as not to blind you at night.
    actually very nice feature
    RainMan_PNW and RobertD[QUOTED] like this.
  30. Oct 5, 2021 at 7:19 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Toyota Care ran out - Getting ready for the first DIY oil change, just waiting on the filter.
    GAknight, GELCW, cowboyjack and 12 others like this.
