door lock actuators
Discussion in '2.5 Gen Tundras (2014-2021)' started by Fab, Mar 2, 2019.
  1. Mar 2, 2019 at 10:40 AM
    Fab
    Fab [OP] New Member
    2014 tundra platinum
    I have had all 4 door lock actuators replaced at least once. Looks like another went bad. So the 1st 4 took 8 separate trips to dealership, 1 to diagnose and 1 to repair. Luckily under warranty but a huge nuisance. I just had another go bad for the 2nd time, now my extended warranty has ended. My question is will Toyota pay for replacement? I do not know how this is not a recall issue. To me it's a potential safety hazard. Any recommendations are greatly appreciated!
  2. Mar 2, 2019 at 10:52 AM
    If it’s the part, and it’s under warranty maybe. Labor- nah
  3. Mar 30, 2019 at 6:21 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    my drivers door lock actuator went bad 2 weeks after 3 years at 39,000 miles dealer said no warranty. toyota offered to pay for parts if i paid labor not a bad deal since part was $350 but i really dont like to let flat rate techs work on my vehicles (i am a flat rate tech myself). so i went online did a little research found that all that goes bad is little motor inside actuator, got 4 of them on Amazon for $28 less than an hour later i had power locks again. hopefully holds up supposedly better quality motor
    831Tun likes this.
  4. Mar 30, 2019 at 7:26 AM
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    Do you have a link to the lock motors?
    How much of a pain to replace? For a non-flat rate tech.
    Dr Doobie and NewImprovedRon like this.
  5. Mar 30, 2019 at 9:42 AM
    Tundraplatinum
    2016 Platinum CM
  6. Mar 30, 2019 at 9:51 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from NorCal. You're the first I've heard of with this issue but sounds like there's an easy and affordable fix. Still a PITA.
  7. Mar 30, 2019 at 10:19 AM
    PermaFrostTRD
    Northern NY
  8. Mar 30, 2019 at 11:51 AM
    TheBeast
    TheBeast The Beach
    not very difficult to change yourself. I did one on the wife SUV. took about 20 min once the door panel was out.
    definitely DIY
    NewImprovedRon and PermaFrostTRD like this.
  9. Mar 30, 2019 at 1:44 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I've had two go bad on me so far...
    PermaFrostTRD likes this.
  10. Mar 30, 2019 at 2:37 PM
    PermaFrostTRD
    Northern NY
    My 2 front door locks are toasted and the back doors are going (double cab). They work 99% of the time.
    I’d likely just replace all 4 at once.
  11. Mar 16, 2021 at 7:18 PM
    kingdr1300
    kingdr1300 New Member
    2017 Crew Max Limited TRD
    18" Fuel Anza +20 275/75 r18 cooper discoverer st maxx Thule Xsporter rack
    Literally just got done replacing the motor on my Tundra actuator. Really pretty easy. Just make sure when re-installing the actuator that the rod for the outside door handle goes through it's home on the actuator. Thank goodness for YouTube video's and you guys.
    ZappBrannigan likes this.
  12. Oct 3, 2021 at 12:59 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Just wanted to add a thanks to this thread. 29k miles and my tundra actuators have been failing for months. Both front doors finally crapped out and I had them replaced under warranty but that’s up soon so I’m thrilled to have a cheaper, less wasteful option.
  13. Oct 3, 2021 at 6:49 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    First, OP, Welcome from LA (Lower Alabama)! Next, thanks for this. I haven't heard much abut these actuators going out, but it's good to know there's an inexpensive, easy fix!
  14. Oct 3, 2021 at 10:51 AM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    My wifes Highlander is down to 1 working door, looks like the motor will also work for the Highlander. Thanks for the link.
  15. Oct 3, 2021 at 1:24 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Hmmm, my wife's Highlander (2012) has over 350k miles and we've never had an issue with this.
  16. Jul 26, 2022 at 9:40 PM
    Jwelch700r
    Jwelch700r New Member
    Jack
    2022 Tundra Limited 4x4
    1.75” RC Level Retrax bed cover Taco Tunes cat shield Chrome delete BFG KO2s Coming soon: TRD pro grill w/ light bar
    I know this is an old thread but want to say thanks to @Tundraplatinum for posting the links. My driver side keyless entry works about half the time, so going to replace the actuator and see if that does the trick.
  17. Jan 26, 2023 at 1:49 PM
    Tundra_King1
    Tundra_King1 New Member
    2018 Tundra 4x4 5.7L Crewmax
    2.5" Level with Bilstein 5100s, 275/70R18 Nitto Ridge Grapplers, and JBA UCAs.
  18. Jan 26, 2023 at 1:52 PM
    Tundra_King1
    Here are the P/N for that piece of plastic if anyone needs a new one.
    Door Water Deflector (Right, Front)
    678310C050
    Door Water Deflector (Left, Front) 678320C030
  19. Jan 26, 2023 at 7:29 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Well, I had the drivers lock replaced with a factory unit around 30k miles, it’s dead now at 44k miles. A couple months later I put one of these cheap motors in the passenger door, which is still working.
  20. Jan 26, 2023 at 7:37 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    77k miles and no issues with mine :fingerscrossed:
    ZappBrannigan and Tundra_King1 like this.
  21. Jan 26, 2023 at 7:37 PM
    Tundra_King1
    Thanks, yeah I might just do all 4 and get it done and over with. I have a 2018 with 102k on it right now, bought brand new. The horn also does not "beep" when I double click the lock button on the key.
  22. Jan 26, 2023 at 8:32 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I was having other door lock issues and a starting issue. Found corrosion on the negative battery terminal. I replaced it and it fixed my other electrical Gremlins.
    if it ain’t broke don’t fix it. I wouldn’t replace anything until it breaks.
  23. Jan 27, 2023 at 1:31 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    My driver side went out about a year and 1/2 ago. Ordered from car parts .com. 1st part came broken. Sent it back. 2nd part came broken too and was the wrong one. Auto zone couldn’t get one. I got frustrated Soooo, I’ve been using my key until I decide to get one.
    texasrho83 likes this.
  24. Jan 27, 2023 at 4:18 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Try Rockauto?
