  1. Oct 3, 2021 at 6:27 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Your old leafs and shocks must have still been in alright working condition. Mine were so clapped out it road pretty soft but just blasted through all the travel when I hit a speed bump. I actually lost some small bump comfort with my new er Frankenstein springs but the stability of a decent shock and decent feeling leaf is hard to explain. I'm interested to see if I have a change in wet weather traction. That's a really cool observation. Hopefully my budget setup gains me some of those benefits also.
    des2mtn and Darkness[QUOTED] like this.
  2. Oct 3, 2021 at 7:17 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @KarmaKannon yup my stock leafs were in great shape still really.
    KarmaKannon likes this.
  3. Oct 3, 2021 at 7:50 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    All this bump stop and leaf talk made me shell out some more money before T2S. Ordered some Timbren ABSOSRs and new ubolts for the rear.
  4. Oct 3, 2021 at 9:03 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    DD 12 hole injectors done in under 2 hrs with preping and cleaning.
    bmf4069, Openbaffle, Voss and 3 others like this.
  5. Oct 3, 2021 at 9:23 AM
    What cc injectors did you go with again?
  6. Oct 3, 2021 at 9:30 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Those look like rx8 injectors honestly
  7. Oct 3, 2021 at 10:00 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
  8. Oct 3, 2021 at 10:15 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Are you running e85 or boost? Any idea of your stft/ltft (short & long term fuel trims)?
    Thats a pretty significant jump from stock 250cc iirc.
  9. Oct 3, 2021 at 10:15 AM
    empty_lord
    05 rollover special
    270cc would be my guess
    But 270 was blues from DD if I remember right?
  10. Oct 3, 2021 at 10:34 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Not boosted yet, lol. Wanted to be ready. Plus I wanted to see how well they work NA with tuned ECM plus Aeromotive pump combination.
    FrenchToasty and empty_lord like this.
  11. Oct 3, 2021 at 10:46 AM
    Ordered a 4” seamless air tank, wasn’t actually in stock, so I had to go with a 5” tank. It doesn’t fit in the frame rails like I had hoped; possibly due to the lip on my slider frame brackets.
    Second choice was possible spare tire cross member; to low hanging fruit.
    Final option that should work well, mount to the under side of the bed behind the tire cross and infront of the bumper, win!
    I also ordered a water separator to be schmancy. Also need to figure out what ports are 3/8 and which ones are 1/4 FIP, those two are the worst to eyeball and be correct.
    Also, I’m not sure if I want to make a two or 4 legged air up hose system……..
    As of now I’m thinking of mounting the female chuck on my rear bumper right in front of the driver brake light 24F22118-AF8A-4FF1-925E-548168DB1C29.jpg
    bmf4069, oscardog86, Voss and 2 others like this.
  12. Oct 3, 2021 at 10:53 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Whats this cool set up for?
  13. Oct 3, 2021 at 10:54 AM
    Bags bro!!!
    Jk, for my air compressor setup/ on board air, maybe get super silly and do a train horn; front and rear tooters
  14. Oct 3, 2021 at 11:22 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Went like 2 feet off the road….:)
  15. Oct 3, 2021 at 11:23 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Speaking of fuel systems, anyone ever successfully add an adjustable fuel pressure regulator to your rig? Or done an inline fuel filter to 2005+ without OE filter outside like pre 2005s.
  16. Oct 3, 2021 at 11:24 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Sounds cool! Minus the train horn lol.
  17. Oct 3, 2021 at 11:28 AM
    If I do the horns, I’ll have to figure out a atf injection system into the exhaust manifolds, so I can “roll coal” like the other train horn goobers!
  18. Oct 3, 2021 at 12:01 PM
    Cummins3500
    Logan
    Where’s the pictures of the pinch weld trimming done to fit tires? Is there a dedicated thread or are they scattered about?
  19. Oct 3, 2021 at 12:02 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Probably an unpopular opinion but there's nearly zero need for an external filter on most modern vehicles. Fuel is filtered multiple times at the refinery and when you get it at the station. Most newer vehicles almost all use plastic tanks so there's very little contamination unless it's intentional.
  20. Oct 3, 2021 at 12:10 PM
    Sounds like you need to start a thread! I think @Darkness gave the best advice somewhere.
  21. Oct 3, 2021 at 12:20 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    I actually agree with you. My URD fuel pump kit has an external filter but I don't plan on running it.
  22. Oct 3, 2021 at 12:44 PM
    Drove around for 1/2 the day going anywhere from 10 mph to 80 mph with my magnetic LED light stuck to the bottom of the frame rail.
    Glad I didn't lose it on the highway and cause an accident. :eek2:
  23. Oct 3, 2021 at 12:58 PM
    Cummins3500
    Logan
    shoot I’ll see what I can do, that’s gonna be next weekends s**t show though
  24. Oct 3, 2021 at 2:45 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Ima have to ask for an upgrade to my “new member” status cause today I changed out the lower control arm and the coilover bearing.
    Good grief that LCA did not want to come out. Ended up eating through the metal blades I had at home trying to cut it out so I went to pick up something better…
    this thing may cost $16 but it’s garbage. Get yourself one of these if you’re ever in my situation
    a Diablo Carbine blade is the way.
    Now to head on over to the other side
    bmf4069, standard, oscardog86 and 5 others like this.
  25. Oct 3, 2021 at 2:49 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    Welcome to the world of Diablo Carbide blades! I have used these things since they came out! They cut steel like butter!
    They certainly save time! They may cost a bit more, but time is money!
    standard, Tundra2 and Voss like this.
  26. Oct 3, 2021 at 2:52 PM
    caleo
    caleo New Member
    Caleo
    01 sr5 4x4 4.7
    fifteen52 wheels wrapped in bfgkm3s, camper build, fox2.0 in the rear and soon to be installed archive HD leaf pack and hanger, king 2.5 ifp with camburg upca.
    first post on this forum. just installed some fox 2.0 w/reservoir shocks onto the 01 AC today. process has been a bit slow because of the retro fit. these where originally intended for a 2019+ dodge 3500 front end. I picked these up for free from work, they had about 2000 miles on them. I had to press out the lower bushings and replace with new ones, the stem top bushings where also a bit too big so I got some smaller ones that would fit this truck a little better. they ride a little more stiff than what i am used to (blown out 20 year old OEM shocks) but I will get used to it, currently there is no camper shell on it so it lifted the rear end about an inch. with all that weight back on it i am expecting it to sit just perfect, the leaf's are stock for the time being but in the future I will go with archive garages HD leaf pack and hangers. the travel numbers increased greatly so i am very happy with how this all turned out. thoughts?IMG_7556.jpg IMG_7545.jpg
  27. Oct 3, 2021 at 2:59 PM
    Coastal crew, looks good
  28. Oct 3, 2021 at 3:29 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  29. Oct 3, 2021 at 4:13 PM
    NWPirate
    Zach
    WA
  30. Oct 3, 2021 at 4:34 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've done this with a coffee cup I set on the ammo can in my bed once. Half of the coffee was still there too, although it got cold.
