Weird gas mileage range after fill up
Discussion in '2.5 Gen Tundras (2014-2021)' started by drgordon13, Sep 30, 2021.
  1. Sep 30, 2021 at 8:59 PM
    drgordon13
    drgordon13 [OP] New Member
    2020 Gray Tundra TSS
    Had a couple of weird things happen today in regards to gas tank/mileage…
    First the warning for low tank didn’t go off until I had 15 miles to empty. So I go fill up and look at my dash and it tells me 575 miles to empty! I have the 38 gallon tank but usually a full tank says 400 or so! I’ll take it but I feel something is off. What gives?
  2. Sep 30, 2021 at 9:27 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Check your battery, it may be starting to end its cycle and will start to lose certain info, like your fuel remaining mileage, time.. I've grounded out my battery and it always resets my fuel remaining counter.
  3. Sep 30, 2021 at 9:47 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Did you by chance either disconnect the battery for some reason or manually reset the miles to empty, MPG, (or whatever) display?
    Every time I disconnect my battery or reset that stuff, it goes to default factory readings.
    It takes a couple tanks of gas to reset to (somewhat) actual readings..
    WILLINH and gosolo like this.
  4. Oct 1, 2021 at 4:50 AM
    drgordon13
    That was it...totally forgot I disconnected my battery to put in my new headlights! Duh!
  5. Oct 1, 2021 at 6:51 AM
    nmjameswilson
    nmjameswilson New Member
    James
    Kansas City
    2021 Limited Nightshade Double Cab
    Yes this is aggravating and it did it on my previous 2008 Tundra I had. You would think it would sense what is actually in the tank and not just go to a default number. I hope this is fixed someday by Toyota.
    BTW he said he received an alert for low gas at 15 I had it happen to me at 3 miles to empty. Does anyone know how to get that number up to say 50 or so?
  6. Oct 1, 2021 at 7:31 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Anything to consider, at least on my 26 gallon tank;
    I've never put more than 22 gallons of gas in my 26 gallon tank.
    I've had the gauge go all the way just past empty (just to test it out) and only got 22 gallons in to full.
    So there were at least 4 gallons in it went the gauge read empty.
    Although I usually buy gas before the low light ever comes on.
  7. Oct 1, 2021 at 7:51 AM
    nmjameswilson
    James
    Kansas City
    Yes the light for sure comes on way before you are actually out of gas. I would just feel better if it gave an earlier warning especially when I am driving a long day storm chasing. It is easy to loose track of the gas levels though the new "38 gallon" tank really helps now.
    1lowlife[QUOTED] likes this.
  8. Oct 1, 2021 at 10:39 AM
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    I usually fill up when the gauge gets to about 1/3 or 1/4. every time i fill up the range usually resets close to 600.
    When i first picked up my truck, range was at 620 lol.
    does the computer calculate range based on the tank level and your avg tank level before fill up?
  9. Oct 1, 2021 at 12:29 PM
    mschein1
    mschein1 New Member
    2006 Tundra Dbl Cab 2021 Cement CM - Sold
    Just filled up the other day. Mine says 553 to empty, made a couple of short runs, everytime I turned it on it says 553. I think until the fuel gauge needle moves or "registers" it resets to the default.
  10. Oct 1, 2021 at 8:34 PM
    Flyfishing1
    Flyfishing1 New Member
    I have a 21 and a 38 gallon and I have not been able to put more then 32 in the tank .. only one click and then I stop .. first got my truck is said 627 .. last two fill ups it says 553 and 557 ..
  11. Oct 2, 2021 at 10:56 AM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    The number varies with the amount of lead in your foot. Switch to an unleaded boot and the number improves.
    I was shocked that my first number was 1000+ KM then 900 something and now barely 700 KM. I don't do a lot of hwy driving.
