Intermittent Traction control
Discussion in '2.5 Gen Tundras (2014-2021)' started by Chingo31, Sep 30, 2021.
  1. Sep 30, 2021 at 5:51 PM
    Chingo31
    Chingo31 [OP] New Member
    2019 Toyota Tundra 1794 4X4
    Lift Kit
    I have the trailer error, pre collision light on, and traction control light on. As soon as I turn off and then on the light goes off. Has anyone experienced this and what fixes this?
  2. Sep 30, 2021 at 6:15 PM
    3jet3
    3jet3 New Member
    FL
    2021 Tundra TRD
    ----Suspension---- 6112 Bilstein Front 5160 Bilstein Back 3 CB .5" Shims(2 driver side, 1 passenger) CB 3+ Shackles Differential Drop kit Carrier Drop kit ----Wheels---- Tires - Falken WildPeak A/T- 295 70 18 Wheels - Raceline Gauge 18" ----Accessories---- GoRhino RB20 Running Boards
    Checked the TSS sensor/cabling in grill?
  3. Oct 2, 2021 at 9:43 AM
    TTund16
    TTund16 New Member
    Mine does this once in a while. Traction control light and couple other light that I forgot ...
    I was told it's because of low or bad battery but it did it once right after I had charged the battery. I think it typically happens if I leave the key on the ignition on for a longer period of time (more than several seconds) before I start the engine.
