Army green trd sport build
Discussion in '2.5 Gen Builds (2014-2021)' started by Hbarmygreen, Sep 30, 2021.
  1. Sep 30, 2021 at 9:39 AM
    Hbarmygreen
    Hbarmygreen [OP] New Member
    2004 Tundra DC SR5 4x4
    Bilstein 6112/5100 Raceline wheels Toyo at3 33’s
    Hey everyone. Trying to create my build and it’s my first time doing this on this forum so bear with me. I have learned valuable information from this site and thought it was only right to try and potentially help some others out.
    I bought my 21’ tundra cm trd sport end of July. Stickered 51k, tacked on 5k because they could. 4wd, pred steps and dual exhaust came with the truck. Here’s a pic of her when I got home from the dealership
    I had a few goals with the truck. Get it level, bigger tires and I did not want to break the bank or go with an excessive, expensive lift because I don’t do much off-roading. The most severe conditions this truck will see is 4wd in mountain conditions since I go snowboarding often.
    here she is after lift/ tires/ wheels :
    I replaced all shocks.
    Front : bilstein 5100 set at lowest setting
    Rear: bilstein 5160
    added icon AAL to rear for my rear lift.
    Added WESTCOTT DESIGNS pre collar lift to front. This is a great option. It goes below the 5100 and overall, with bilstein set to .87”, gave me about 3” of lift in front. Westcott advertised this lift as being able to clear 35’s with no BMC and they were correct. Had some trimming(removed flaps etc ) but that was it. No rubbing whatsoever. And the Westcott lift is only around 300$
    added methods 701 and bfgs 35 12.5 18
    I will be adding more pics to this thread but just wanted to get it posted in case anyone was in the same boat as me 6 months ago.
  2. Sep 30, 2021 at 2:14 PM
    Hbarmygreen
    here’s a few pics of the parts I installed.
    87BDB0BE-2947-4ABE-BD5D-21BE9090AFA9.jpg 289773EB-60F9-4F09-9E36-BDEAB4B1C1A3.jpg 02DF6A99-7349-4ECE-B5BB-737C0D2DFC73.jpg 4218FACD-2580-46B0-9365-1A5DCDD897EE.jpg 0083E079-6200-4E3E-AB62-F360586D0794.jpg 5AE5C679-BE43-4152-962F-B490A6726C26.jpg 37302CB6-906B-4592-86F8-6956BC8FA652.jpg 1BED170A-52F6-4688-B6B6-CCEE5BA459C0.jpg 64713F5B-8A93-41FC-AFB4-F8BDF1E149AF.jpg FBA7F398-75B1-49BF-BBD0-4D65A57874C2.jpg
  3. Sep 30, 2021 at 3:36 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Looks nice! You may want to look at some adjustable UCAs, hard to tell in the pics but that angle looks pretty steep. They are generally required at 3 inch lift, many run adjustable UCAs with 2.5 lift. Nice truck, you got one of the last V8 Tundras.
  4. Sep 30, 2021 at 3:47 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Very nice!!!!:)
    Hbarmygreen[OP] likes this.
  5. Sep 30, 2021 at 3:50 PM
    OGDark Knight
    OGDark Knight New Member
    Jeff
    2019 Platinum, 14 4Runner Trail, 95 Land Cruiser 80
    Trans cooler. Pioneer 8600. TRD Pro suspension.
    Looks awesome!
    But, down travel, ya have none.
  6. Sep 30, 2021 at 4:46 PM
    Hbarmygreen
    it will be just fine for how I plan on using the truck. You should check out Jeff Westcotts videos on how this lift works. Shouldn’t really affect the down travel.
    https://youtu.be/mgDsi4RSQKQ
  7. Sep 30, 2021 at 6:07 PM
    OGDark Knight
    Jeff
    You’re not understanding “down travel” and that video says nothing about it. However, i do understand that it will be ok the way some folks use their own vehicle.
    See how close the inside of your upper control arm is to the coil spring? At the current lift height you are at near maximum down travel, (aka maximum lift). The result is the lack of available “down travel” within the overall (up/down) motion of suspension movement.
    Still, bad ass looking truck….
  8. Sep 30, 2021 at 6:13 PM
    3jet3
    3jet3 New Member
    FL
    2021 Tundra TRD
    ----Suspension---- 6112 Bilstein Front 5160 Bilstein Back 3 CB .5" Shims(2 driver side, 1 passenger) CB 3+ Shackles Differential Drop kit Carrier Drop kit ----Wheels---- Tires - Falken WildPeak A/T- 295 70 18 Wheels - Raceline Gauge 18" ----Accessories---- GoRhino RB20 Running Boards
    Sweet!
  9. Oct 4, 2021 at 8:37 AM
    ToyotaG
    ToyotaG New Member
    I did not know you could use the Westcott kit with the 5100 . Thats good to know
  10. Oct 5, 2021 at 7:29 AM
    rubberchicken48
    rubberchicken48 New Member
    2016 Toyota Tundra SR5, Black
    Pioneer HU and storage under the back seats
    Where did you get the hood scoop and how much was it?
  11. Oct 19, 2021 at 3:28 PM
    66Platinum
    66Platinum New Member
    Angel
    Salinas Valley CA
    20 Platinum MGM
    Damn was considering this option. So this is not the way to go?
  12. Oct 19, 2021 at 3:33 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Did you use a differential drop kit? CV axle looks a little strange to me....
  13. Oct 20, 2021 at 7:18 AM
    MadMaxCanon
    No doubt, always loved the army green too. I am curious about the diff drop because some people say you dont need it, but looking at that angle, i could see why so many ppl put it on.
  14. Nov 26, 2021 at 2:03 PM
    Hbarmygreen
    Scoop came with. It’s a trd sport
    TelemarkTumalo and Black@Blue19 like this.
  15. Nov 26, 2021 at 2:04 PM
    Hbarmygreen
    Did not use diff drop. Spoke with the guys at Westcott designs and they said it wasn’t necessary
  16. Feb 17, 2023 at 7:35 AM
    be_unscared
    be_unscared Not a truck doctor
    Brendan
    Central Cal
    21 Army Green w/skewp 4x4
    just bought this exact truck and looking and the same wheel / tire setup. I was considering going to 37s, but not sure if it would need to be re-geared at that point. ANY idea if that is the case? Beautiful truck
  17. Feb 17, 2023 at 7:56 AM
    Hbarmygreen
    All the research I did on this I got mixed reviews. If you will be towing something heavy you may want to. If not, probably don’t need to. Some people said they re geared even with 35s. I have experienced no issues with loss or lack of power or searching for gears
  18. Feb 24, 2023 at 8:17 AM
    be_unscared
    Brendan
    Central Cal
    The prevailing theory here is that you’ll want to regear at 37s. You could run suboptimally with the stock gearing, but no one is sure how long that will last.
  19. Feb 24, 2023 at 11:16 AM
    66Platinum
    Angel
    Salinas Valley CA
    20 Platinum MGM
    Look up Dirty Seven Club on the forum, some people talk about 37s with stock gears, and I've some other folks too on social running stock gears with 37s and they wheel the sh*t out of it too.
    I'm wondering if there's a concern with having 37s and stock gears on a 19-21 model since they removed the aux transmission cooler not sure if that plays a factor in overheating since it'll be searching for gears and such
  20. Jul 13, 2023 at 11:49 PM
    Mobrule
    Mobrule New Member
    2017 inferno orange Tundra SR5 TRD
    Magnusson s/c Flowmaster Outlaw dual exhaust series 10 muffler
    @Hbarmygreen I'm looking into Westscott collars and 5100's and was wondering if your front driver side is on the lowest or middle setting?
