Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Sep 27, 2021 at 5:48 PM
    #811
    Looks like the OD is 15/16" and the bibs they sit on are 11/16.
    Granted, YMMV, mine is an '06 and my hoses are factory original, 15 years old.
    Tundra2[QUOTED][OP] likes this.
  2. Sep 27, 2021 at 6:07 PM
    #812
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Im not trying to flush the new cooler. I want to by pass it so I don't clog the new one with shittake
    I don't trust the old one for power flushing because of those seals you mentioned. I don't want to push water into my oil pan at 10 psi because of a fucked up seal. Which is why I want to by pass it just to do power flush.
    Unless I'm not understanding something.
  3. Sep 27, 2021 at 6:09 PM
    #813
    Tundra2
    Noah
    Western Kentucky
    Thanks for this. I'll see what I can come up with. Should have sliced an end off for test fit at work, but can do that when I get home.
    Made up a regulator at work. Will return this when I'm finished with it.
    bmf4069 and shifty`[QUOTED] like this.
  4. Sep 27, 2021 at 6:12 PM
    #814
    bmf4069 and Tundra2[OP] like this.
  5. Sep 27, 2021 at 6:14 PM
    #815
    Tundra2
    Noah
    Western Kentucky
    I might be able to do some kind of video. Just not real sure exactly how I'm going to catch everything. I want to investigate the aftermath versus it just being on the ground...
  6. Sep 27, 2021 at 6:15 PM
    #816
    Tundra2
    Noah
    Western Kentucky
    Quoting this just so I can find it easier in the future.
  7. Sep 27, 2021 at 6:32 PM
    #817
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Oh you can do it with the old one hooked up. That pipe won’t be getting the full force. No fear there. I was meaning to flush that thin out you’d need to be directly on it. That’s how you’d ruin it
  8. Sep 27, 2021 at 6:48 PM
    #818
    Tundra2
    Noah
    Western Kentucky
    Okay, gotcha. So I'll stick the old oil cooler on when I get home. Remove the T-stat, and set up for flushes. Depending on how I feel. I may do the flush then as well.
    dbittle and shifty` like this.
  9. Sep 27, 2021 at 7:40 PM
    #819
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    Yep. Hook it up and fire for effect!
  10. Sep 27, 2021 at 8:07 PM
    #820
    Tundra2
    Noah
    Western Kentucky
    I'll see what it does. I'll be sure to post pics, or take a video of it.
    dbittle[QUOTED] likes this.
  11. Sep 27, 2021 at 9:28 PM
    #821
    Tundra2
    Noah
    Western Kentucky
    Been studying up on this wiring diagram you posted. Think I'm learning it okay in my free time. Work computer with larger screen, and stupid fast internet helps too. Been on the hunt for the accelerator position sensor clip because the retaining clip broke off. Think I finally found it. Connector A8.. Code number H6. See page 26. Go there. A8 is "Accel Position Sensor." Toy Part number 90980-11150.
    Double check my work? Please, and thank you.
    BubbaW[QUOTED] likes this.
  12. Sep 28, 2021 at 3:18 AM
    #822
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  13. Sep 28, 2021 at 3:53 AM
    #823
    Tundra2
    Noah
    Western Kentucky
    Thanks for posting this. I added it to the cart. Can anyone recommend any good hose clamp pliers? I checked a few on the rainforest. Wasn't real sure what the pros use.
  14. Sep 28, 2021 at 3:56 AM
    #824
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    :p
    I concur and if connector is of a different color than white, you can look at the Connector List pg 224 where it shows it is black in color. It will also show what the pin #'s are in case you need to troubleshoot the "Accel Position Sensor" for example for proper voltage, gnd and/or signal(Accel Postion open/closed).
  15. Sep 28, 2021 at 4:12 AM
    #825
    Tundra2
    Noah
    Western Kentucky
    Good deal. I've already mangled one of the smaller hose clamps like shown below. Thus is what I've been using for the ones these fit in the space.
    Connector order is placed.
  16. Sep 28, 2021 at 5:27 AM
    #826
    Tundra2
    Noah
    Western Kentucky
    Did a power flush. Here's my set up.
    Max PSI used was 18.
    Nastia. One day it will be better. Not today though. I'm pooped!
    Reused one of the heater core hoses as my bypass including the blend valve. Couldn't come up with anything that I felt confident in.
    Hooked up old oil cooler without mounting it so I couldn monitor if it ruptured or not. It didn't. Still doesn't instill me with confidence that it's usable.
    Video uploading soon, but I got three five gallon buckets through the system. One of which was tap water, and two of which were distilled water.
    First bucket was dingy, but no chunks. Second bucket was less dingy, and third distilled bucket was clear as pool water.
    bmf4069 and FirstGenVol like this.
  17. Sep 28, 2021 at 5:34 AM
    #827
    Tundra2
    Noah
    Western Kentucky
    Now, should I drain the distilled water out that's in there, or leave it? I'm 95% sure I got all the tap water out, or at least diluted it enough so it wouldn't matter. Thoughts?
    I mean, it's an iron block. If I drain the water out, the inside of the engine will rust more than it already is.
    @BubbaW @empty_lord @Darkness @assassin10000
  18. Sep 28, 2021 at 5:37 AM
    #828
    Where did you insert the hose/water? Nice work!
    Tundra2[OP] likes this.
  19. Sep 28, 2021 at 5:38 AM
    #829
    Tundra2
    Noah
    Western Kentucky
    In the inlet the majority of the time, and the outlet the last little bit.
  20. Sep 28, 2021 at 6:15 AM
    #830
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    can’t remember, are ya’ll well water and if public, much lime in ya’lls water ?
  21. Sep 28, 2021 at 6:17 AM
    #831
    Tundra2
    Noah
    Western Kentucky
    Not much lime. Some calcium, but I put about 7-ish gallons of city water through, and did the rest of the 15 gallons with distilled.
    I feel like it's diluted enough, but if you think draing the block would be wise at this point. I have nothing to put back in except my high dolla Zerex or more tap water.
  22. Sep 28, 2021 at 6:22 AM
    #832
    Tundra2
    Noah
    Western Kentucky
  23. Sep 28, 2021 at 6:28 AM
    #833
    w666
    Maryland
    I dig the reflector shirt...is that your every day garb, or only when you're power flushing (which, BTW, reminds me of that toilet that flushes golf balls)
    FirstGenVol, bmf4069 and Tundra2[OP] like this.
  24. Sep 28, 2021 at 6:33 AM
    #834
    Tundra2
    Noah
    Western Kentucky
    Work issue work uniform. Lots of internal plant traffic. Fork lifts, tuggers, etc...
  25. Sep 28, 2021 at 6:37 AM
    #835
    Why you gotta post a 20 min video right before I gotta go work? And while I'm low on data? Jerk.
  26. Sep 28, 2021 at 6:37 AM
    #836
    Tundra2
    Noah
    Western Kentucky
    I can squeeze it down and compress it. Speed it up for you, but it'll be after my nap. :laugh::laughing:
    bmf4069[QUOTED] likes this.
  27. Sep 28, 2021 at 6:41 AM
    #837
    Tundra2
    Noah
    Western Kentucky
    Well, I'm tired. I'm leaving what's in the block in it. Not much more I can do now except wait for an oil cooler to show up.
    shifty` likes this.
  28. Sep 28, 2021 at 6:42 AM
    #838
    Man, I'm sad, I was really expecting that thing to poop out solids like in that video I linked.
    Sounds like it just liquified the contents? Do you have any specific passages you know were clogged so you can check for status on whether the content pushed out?
    (I was expecting chunks also, but using your Tupperware experiment as a baseline, maybe not! I am curious now, how it originally settled as sediment, though!)
  29. Sep 28, 2021 at 6:50 AM
    #839
    Tundra2
    Noah
    Western Kentucky
    I think I got all the chunks out, and there was only a light film in the heater core lines. I'd bet it was the wrong coolant mixture, and it coagulated. Probably from lots of short drives. Farm life. Pack the bed full of tools. Pull up to the fence. Work on 20 feet. Pull up 20 feet. Work on 20 feet. Pull up 20 feet.
    Probably just lots of sloshing from off/on/off/on/off/on.... that oughta create some kind of froth from all that slurrying.
    I don't know though, and am only speculating. I feel like the block is clear, and was clear before power flushed. I'm not sure how the coolant goes through the block, or the heads, or any of that. I've only replaced what you've all have seen, and what I could get to easily on the outside of the engine.
    Time will have to tell.
    shifty`[QUOTED] likes this.
  30. Sep 28, 2021 at 6:54 AM
    #840
    Indeed. I mean, I dunno if you'll be doing any more lines and/or ports that may expose other stuff. I'd be curious what the rear/lower block drains dumped out, but probably not something happening today. Just thinking about how sediment likes to settle at the bottom.
    Really, the silver bullet on this will probably be a proper chemical flush. But in my mind, I'm also, like, given the maintenance history and prior life, prior ownership, what can of worms could that open up, y'know? Maybe stick to half or 1/4 the advertised usage amount of whatever treatment is used.
