Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Sep 25, 2021 at 6:53 PM
    #661
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Tundragirl putting extra hardware in your nut/bolt pile?
  2. Sep 25, 2021 at 6:53 PM
    #662
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Lol, no. :rofl:
  3. Sep 25, 2021 at 6:58 PM
    #663
    TundraGirl2
    TundraGirl2 New Member
    Kaitlyn
    Western Kentucky
    I
    I told him he did the same thing the manufacturers did but better because it’s less parts lol… he wasn’t happy with that response
    06yotamike and bmf4069 like this.
  4. Sep 25, 2021 at 6:59 PM
    #664
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Weight reduction.
    its a tundra superleggera now.
    bmf4069 and NUDRAT like this.
  5. Sep 25, 2021 at 7:07 PM
    #665
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
  6. Sep 25, 2021 at 7:13 PM
    #666
    That long bolt in the 2nd picture looks like one we had to remove when doing John's alternator. It's either for the alternator or power steering pump I think. We had to unbolt the power steering pump and swing it out of the way to remove the alternator. Some of those smaller bolts could be for the serp belt tensioner...?
    Edit- just noticed you already have the small ones figured out. 95% sure that big bolt is what I wrote above.
  7. Sep 25, 2021 at 7:43 PM
    #667
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    There’s a long one on the thermostat housing. 4 for the ac compressor one on the water pump and one over by the power steering pump if I remember right. Mines an 06 though.
    Tundra2[OP] likes this.
  8. Sep 25, 2021 at 8:10 PM
    #668
    It's too bad nobody makes a machine like those Coinstar things where you dump all the coins in, it sorts, identifies and counts all the coins, and spits out a redeemable receipt. We need the same thing, but for bolts and nuts, you dump in your pile of bolts, and it in turn spits out a receipt with a picture of the bolt, it's thread pitch, length, type and a list of everywhere on the truck it's used...
    Actually, there surely must be a smartphone app that can do that? Probably wouldn't support trucks as old as ours though. And I'm guessing between models, the bolt lengths and such may be same thread into the block, but different lengths depending on what accessory config you had. That's how all the GenIII GM motors are.
  9. Sep 25, 2021 at 9:01 PM
    #669
    TundraGirl2
    Kaitlyn
    Western Kentucky
    He’s got both timing belt covers off and the number 2 timing belt cover. No sign of anything where the left over would fit. Taking the fan bracket off now.
  10. Sep 25, 2021 at 9:04 PM
    #670
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Anything worth doing is worth doing twice.
    NUDRAT and Tundra2[OP] like this.
  11. Sep 25, 2021 at 9:42 PM
    #671
    TundraGirl2
    Kaitlyn
    Western Kentucky
    @Tundra2 here. My phone is dead as a doorknob. Anyway, think I figured out where that 12mm bolt lives. There’s a bolt just underneath the bolt for the serpentine belt tensioner. Think that’s where it lives. It threaded in, and snugged up.
    Still not sure where the 12mm nut lives…
    Lil Steve, Tundra2[OP] and Sirfive like this.
  12. Sep 25, 2021 at 9:44 PM
    #672
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    that bolt is the one that can be replaced with a stud to allow the use of the newer 130 or 150 amp alternator without having to modify it. (for anyone that cares)
    bmf4069, NUDRAT and Tundra2[OP] like this.
  13. Sep 25, 2021 at 11:43 PM
    #673
    Tundra2
    Noah
    Western Kentucky
    Okay, so I've still got one M8x1.25 nut (12mm head) without a home. Everything else has been accounted for.
    Water pump is good. PS Vane is good. Alternator is good. AC compressor is good. AC comp reinforcement bracket is good. Serp tensioner is good. Water inlet is good. I'm not sure what else is missing.
    Found one loose motor mount bolt which I snugged up...
    Not many pics because cold, but the oil cooler coolant lines are packed full of shit. I cleaned this out, but can't get much out of the oil cooler itself.
    The throttle body is packed full of shit too. I can't clean all that out. Same type of grassy, planty type shit.
    Also, I'd really like to replace the clips on the left hand TB cover. Anyone got any kind of links?
  14. Sep 25, 2021 at 11:47 PM
    #674
    empty_lord
    05 rollover special
    The oil cooler lines look like that??
    Replace the oil cooler. Seriously. It’s probably caked. Replace the rubber lines, use pipe cleaners to clear out the metal line. Pull the heater hoses off and make sure they’re not caked too. Almost looks like someone pit stop leak in at some point. GET THAT STUFF OUT
  15. Sep 25, 2021 at 11:47 PM
    #675
    Tundra2
    Noah
    Western Kentucky
    Yes. The oil cooler is full of this shit. The throttle body is full of this shit. I can't imagine what the heater core looks like....
  16. Sep 25, 2021 at 11:49 PM
    #676
    empty_lord
    05 rollover special
    Used oil cooler should be safe. Do not run that one.
  17. Sep 25, 2021 at 11:49 PM
    #677
    empty_lord
    05 rollover special
    Pull the hoses. This shit will cause a nightmare bleeding the system and may cause issues with all the work you’ve done
    NUDRAT and Tundra2[QUOTED][OP] like this.
  18. Sep 25, 2021 at 11:50 PM
    #678
    Tundra2
    Noah
    Western Kentucky
    Car-part .com here I come... :(
    Voss and NUDRAT like this.
  19. Sep 25, 2021 at 11:52 PM
    #679
    empty_lord
    05 rollover special
    @lsaami may have a cooler.
  20. Sep 25, 2021 at 11:52 PM
    #680
    Tundra2
    Noah
    Western Kentucky
    That's true. I'd rather buy from him to help him, and me out. I'll pm him.
    NUDRAT likes this.
  21. Sep 25, 2021 at 11:53 PM
    #681
    empty_lord
    05 rollover special
    Your replacing the Rad right? Back flushing the heater core with a garden hose should help.. maybe some CLR too?
  22. Sep 25, 2021 at 11:54 PM
    #682
    Tundra2
    Noah
    Western Kentucky
    The RWD? Radiator? Yes. I have new denso in hand. Guess I'll order another one, and sacrifice this one for the flush. I don't want to break up any of the gunk in the old one, and get it lost in the cooling system.
  23. Sep 25, 2021 at 11:56 PM
    #683
    empty_lord
    05 rollover special
    Flushing the engine block out may be a good idea too. Go remove t stat, reinstall the housing, remove both heater hoses, put a hose that goes from inlet and outlet (so you don’t further block the heater potentially) and remove both upper and lower rad hoses. Use the top one with a hose and run water through till it comes out clear. Once done, put together and used distilled water to flush out the tap water
    Tundra2[OP] and NUDRAT like this.
  24. Sep 25, 2021 at 11:57 PM
    #684
    empty_lord
    05 rollover special
    In this case power flushing is a good idea to get the large chunks out so you DONT ruin the new Rad
  25. Sep 25, 2021 at 11:57 PM
    #685
    Tundra2
    Noah
    Western Kentucky
    How does one power flush?
  26. Sep 25, 2021 at 11:58 PM
    #686
    empty_lord
    05 rollover special
    Just get the tap water out as soon as you can after. Don’t want that shit calcifying
  27. Sep 25, 2021 at 11:58 PM
    #687
    empty_lord
    05 rollover special
    They sell kits to hook a garden hose up and air to force water through the system under pressure
  28. Sep 25, 2021 at 11:58 PM
    #688
    Tundra2
    Noah
    Western Kentucky
    I used only distilled in the V6. 80 cents a gallon was a no-brainer.
  29. Sep 26, 2021 at 12:02 AM
    #689
    Tundra2
    Noah
    Western Kentucky
    So let me get this straight to make sure I'm understanding correctly...
    1. Remove T-stat
    2. Connect inlet, and outlet hoses from the heater together.
    3. Use top radiator hose with garden hose
    4. Run engine until clear.
    5. Hook everything up proper, and flush tap out with distilled.
    Yes?
  30. Sep 26, 2021 at 12:03 AM
    #690
    empty_lord
    05 rollover special
    Well distilled is great for flushing normally. What you have here needs a garden hose and some air pressure to work the big shit out. After that process is when you’ll put it all together and flush the tap water out with distilled water then eventually coolant
