Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Sep 22, 2021 at 7:52 AM
    #601
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You have the belt backward. Arrow faces out
    Tundra2[QUOTED][OP] and NUDRAT like this.
  2. Sep 23, 2021 at 4:10 AM
    #602
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    @BubbaW Felt great after work. Decided to flip the belt over as I'm undisturbed, and focused.
    Hydraulic Tensioner is not on yet. Curious why the drivers side seems off. Hope I didn't mess up the timing yesterday.
    Any advice or thoughts?
    BubbaW likes this.
  3. Sep 23, 2021 at 4:23 AM
    #603
    Tundra2
    Noah
    Western Kentucky
    Decided to reset, and try again this time paying more attention.
    The Right cam (pass side) sprung forward a hair while I tried to slip the belt on. Stopped, and moved back. Sprung forward to pictured position when I got the belt on.
    All look OK?
    w666 likes this.
  4. Sep 23, 2021 at 4:32 AM
    #604
    Tundra2
    Noah
    Western Kentucky
  5. Sep 23, 2021 at 5:36 AM
    #605
    Nice work Noah. It wouldn't be a proper Crackhead resurrection without an occasional mishap. I know you'll get it sorted out. I'm most excited for the coolant flush. I think it will be cathartic.
    bmf4069 and Tundra2[OP] like this.
  6. Sep 23, 2021 at 8:45 PM
    #606
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    On the crankshaft, I’m not seeing the mark on the housing. I see it on the belt and gear where you marked it. If you like the alignment, set the tensioner and rotate a few times and check the pulley alignment again. All 3 should be dead solid perfect. The belt marks won’t line up though.
    Tundra2[OP] likes this.
  7. Sep 23, 2021 at 9:17 PM
    #607
    Tundra2
    Noah
    Western Kentucky
    Thanks for positive feedback. I'm not sure what the mark on the crank housing. I don't seem to have any better pictures than this one below.
  8. Sep 23, 2021 at 9:45 PM
    #608
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Looks good to me. If you have any doubts consult the FSM. You can always pull the plugs and check for BTDC on each piston by using a metal coat hanger with tape wrapped on the end so as to not scratch a piston crown. Turning the motor by hand should be relatively easy since there will be no compression.
    Tundra2[OP] and N84434 like this.
  9. Sep 24, 2021 at 3:13 AM
    #609
    Tundra2
    Noah
    Western Kentucky
    The plan for today when I get home is to put the crank sensor plate back on, timing belt cover around the crank, and the harmonic balancer, and then turn the engine by hand.
    Now, at this point, the marks on the belt are irrelevant. The only marks that are if any consequence are the timing marks on the HB and cams. Yes?
  10. Sep 24, 2021 at 3:36 AM
    #610
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Yep. The belt marks go out of alignment once it's turned over.
    This isn't due to the cams/crank going out of alignment but the fact belts are designed a bit longer so they don't ride on the same pattern every revolution. This is for even wear. Just like tire rotation.
    Tundra2[QUOTED][OP] likes this.
  11. Sep 24, 2021 at 3:44 AM
    #611
    Tundra2
    Noah
    Western Kentucky
    Gotcha. Thanks for the positive confirmation of my understanding.
    Now obviously I won't be putting any He-man strength when I'm turning the engine, but if it's out of time, presumably I'd hit the top of the piston, and feel resistance accordingly.
    Gently turning by hand is low risk for engine damage. Yes?
  12. Sep 24, 2021 at 4:17 AM
    #612
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Probably would be best to pull the plugs during hand rotation for the least resistance possible.
  13. Sep 24, 2021 at 4:35 AM
    #613
    Tundra2
    Noah
    Western Kentucky
    I went nice, and slow to allow all the air to move as necessary in the engine. Two full turns back to timing marks.
    How in the fuck am I supposed to torque the crank pulley bolt? Hit it with the mamba? I'd rather torque it correctly.
  14. Sep 24, 2021 at 5:46 AM
    #614
  15. Sep 24, 2021 at 5:57 AM
    #615
    Tundra2
    Noah
    Western Kentucky
    bmf4069 and shifty`[QUOTED] like this.
  16. Sep 24, 2021 at 6:03 AM
    #616
    Tundra2
    Noah
    Western Kentucky
    Made plenty of headway so far.
    Decided to cool down the work ethic by removing the studs from my fan clutch from the shitey Chinese fan bracket that was on the truck.
    Two M8x1.25 jamb nuts, and two 13mm wrenches made quick work of it.
    Cleaned up the mating surface of the fan clutch. Spick und span!
    Gave the mating surface a light coating of anti-sieze because I'm not ready to install it yet, it's bare metal now, and being stored outside where it's humid. This will mostly be wiped off before install.
  17. Sep 24, 2021 at 6:03 AM
    #617
    Hit it with the mamba full force!! Believe the spec is 300ft# of force. That's 7.5 ugga duggas on max setting with max psi for the pneumatic impact. You'll have to do the conversion for electric.
  18. Sep 24, 2021 at 6:04 AM
    #618
    Tundra2
    Noah
    Western Kentucky
    Spec is 181 Ftlbs. I gave it a 2 second burst on speed two to keep moving along. I'll see what I can scrounge up tonight at work.
  19. Sep 24, 2021 at 6:12 AM
    #619
    Definitely yallQaeda, surprised my family hasn't tried to patent that yet. Actually, I'd be shocked if a mass-produced cheap steel tool doesn't exist for this at Harbor Freight or Northern Tool, something like a t-square, with the T-end being slotted so you can adjust the width on bolt pattern. It could be used in situations like this where you need opposing force.
    There are other times in mechanics land where this is needed. If a belt isn't sitting on it, you can use a leather strap to prevent spinning. In the bicycle world, chain whips are used to pull freewheels apart, or remove cassettes. But then again, how often does one change HB? Maybe that's why it hasn't come up in conversation yet this year.
    Tundra2[QUOTED][OP] and dbittle like this.
  20. Sep 24, 2021 at 6:34 AM
    #620
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
    You are home free now! Good work!
  21. Sep 24, 2021 at 6:51 AM
    #621
    Only 181ft#? been a minute since I did mine. Swore it needed more ugga duggas. If it's only 181, then it's 3.5 ugga duggas, your conversion for electric seems accurate.
  22. Sep 24, 2021 at 7:44 AM
    #622
    Desert Dog
  23. Sep 24, 2021 at 11:58 AM
    #623
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
  24. Sep 24, 2021 at 3:29 PM
    #624
    Tundra2
    Noah
    Western Kentucky
    Thanks for linking this in, and thanks to @N84434 for posting excellent pictures. Just placed an order through big gurllll for free through rewards points.
    Toyota/Lexus Crankshaft Damper Pulley Holding Holder Harmonic Tool with 2PCS Crank Bolts
    bmf4069, N84434 and Lil Steve[QUOTED] like this.
  25. Sep 24, 2021 at 4:13 PM
    #625
    Lil Steve
    Gilbert, AZ
    N84434 and Tundra2[QUOTED][OP] like this.
  26. Sep 24, 2021 at 4:50 PM
    #626
    Tundra2
    Noah
    Western Kentucky
    When I get home from work tomorrow around 6:00 AM CST, I hope to start back tracking on all the bolts, and installing things using the 1A-Auto videos since its been a week since I took everything apart. Should be able to narrow down bolt homes using their video. Luckily, I kept everything on a Left side of engine on the left, and Right side of engine on the right. So at least there's that. Will be mighty fun doing some reverse engineering.
    Kinda bummed I'm spinning my wheels tonight at work as there is literally nothing of any importance to do except to sweep, and do 5S.
  27. Sep 24, 2021 at 5:53 PM
    #627
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    5S - I dealt with that years ago when I did carbon fiber repair work... Sort, Shine, can't remember the rest....
  28. Sep 24, 2021 at 5:55 PM
    #628
    N84434
    Milwaukee WI.
    2001 Limited TRD
    you got yours way cheaper than what mine was. I think I paid 55 bucks? Can't remember...
    You'll love that tool.:thumbsup:
  29. Sep 24, 2021 at 7:03 PM
    #629
    Tundra2
    Noah
    Western Kentucky
    Thinking on future install. What exactly does the jiggle valve look like?
    Using the below generic image as a guide...
    The outlined metal piece was up and down (vertical) versus side to side (horizontal) when I pulled the other one out. Is that why the fuel system never made it to closed loop?
  30. Sep 24, 2021 at 7:04 PM
    #630
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Jiggle valve is that little loose rivet on the outside of thermostat.
    Also any Denso radiator core measurement yet?
