help me find the rat damage slayer
Discussion in '2nd Gen Tundras (2007-2013)' started by hobarto, Aug 22, 2021.
  1. Aug 22, 2021 at 12:30 PM
    hobarto
    hobarto [OP] New Member
    2011 tundra TRD 4wd
    tailgate step
    dear member slayer,
    I use my truck about once or twice a month. Yesterday, started it up, check engine on solid, traction slippage light on solid, 4-lo flashing. Opened hood and pulled manifold cover and got a rat in the house chewed my foam under the cover and made a nest, and shat on my air filter cover. You said you been there, exactly where did the chewing take place? Thanks
    Rica25 and ramjam like this.
  2. Aug 22, 2021 at 12:32 PM
    hobarto
    2011 tundra TRD 4wd
    tailgate step
    by the way, oreillys checked my obd2 and said the knock sensor was bad.
  3. Aug 22, 2021 at 12:34 PM
    AZBoatHauler
    So.Arizona
    AZTundra likes this.
  4. Aug 22, 2021 at 12:45 PM
    hobarto
    2011 tundra TRD 4wd
    tailgate step
    thanks for helping me
  5. Aug 22, 2021 at 12:47 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    A rat chewed my knock sensor up. Sucks that a teeny tiny little wire gets eaten so often. Luckily it is VERY easy to fix, took about 25 minutes to unbolt some stuff and pull the intake manifold off.
  6. Aug 22, 2021 at 1:17 PM
    Welcome from NY.
    Sorry to hear about your issues with the rodents.
    Stick some dryer sheets under the hood in several spots or spray it with peppermint oil, they hate that and will stay away. They also make a electronic rodent deterrent that you can hook up to the battery.
    Gravy and AZTundra like this.
  7. Aug 22, 2021 at 2:11 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Welcome from SoCal, post some pics
  8. Aug 22, 2021 at 2:40 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Knock sensor wires is where the little bastards got mine. Luckily I found the damage before it became an issue.KIMG1121.jpg KIMG1122.jpg
    They had a nice little home set under my intake manifold!
  9. Aug 22, 2021 at 6:52 PM
    hobarto
    2011 tundra TRD 4wd
    tailgate step
    ThcAK you very much for the pics, now I can see where I need to search.
    Dr Doobie likes this.
  10. Aug 22, 2021 at 7:11 PM
    hobarto
    2011 tundra TRD 4wd
    tailgate step
    I'll be taking sgt. gray for a spin quite often from now on, once I get this ratbastard resolved.
  11. Aug 22, 2021 at 7:18 PM
    Dr Doobie
    Talkeetna,Alaska
    Good luck on your rat safari:infantry:
  12. Sep 1, 2021 at 7:57 PM
    ramjam
    ramjam New Member
    08 Crewmax 5.7 4wd
    When my dash lights all flashed at once and I found the code was for knock sensor, I checked into it and pulled the intake where I saw where the rodents had been feasting on the ks harness. Dealer parts guy told me that he knew of a product called pepper tape and it was infused with pepper to spoil the taste. When no local suppliers could be found, I used liquid electrical tape or coating and brushed it onto the harness wiring and then sprinkled an abundant amount of cayenne pepper over the still wet liquid tape. After allowing time for drying, I reassembled and have had no further issues.
    Hbjeff[QUOTED] and Dr Doobie like this.
  13. Sep 18, 2021 at 5:52 PM
    hobarto
    2011 tundra TRD 4wd
    tailgate step
    success!
    many thanks to you folks for the information, pulled the intake and sure enough, rat city. R and R ed the knock sensor harness, new intake gasket, cleared codes, works fine last a long time.
    I plan to stuff smelly dryer sheets in there and drive much more often. I also trapped the rat bastard in my lawnmower shed, around the corner from my truck parking area.
    thanks again for all the pictures and such, it was a real help.
    Dr Doobie and TILLY like this.
  14. Sep 18, 2021 at 7:26 PM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    Alberta? Close call with that outbreak just over in Speedy Creek a little while back hey;)
  15. Sep 18, 2021 at 7:37 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Mice can do just as much damage IMO, I pop my hood pretty regularly to check for the signs. I had some slight damage last Month, but the peppermint oil spray I'm now using seems to be working great so far. Food for thought.
  16. Sep 18, 2021 at 8:04 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2025 GMC Sierra 2500HD AT4 2017 CM Limited (Sold) 2019 CM SR5 l
    I live in the sticks, have a barn and tractor, etc etc etc. If the mice/rats are really living in there, glue traps surrounding the front wheels (so they can’t get up there at all! work just fine. About half the time you find them dead on the dallied board and about half the time they drag / chew themselves and get away. Also, put out traps with peanut butter, they love PB. For me, I just live with them. I’ve always got traps of some kind or another out…. Constant battle round here. Good luck!
    TILLY likes this.
  17. Sep 18, 2021 at 10:14 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Owl houses
  18. Sep 19, 2021 at 7:00 AM
    Nueces
    Nueces New Member
    Texas Hill Country
    2002 Tundra SR5 AC
    My mechanic/car collector just found a nest inside the air filter housing on my 2007 Nissan Frontier. He installed a packet of Grandpa Gus's Extra-Strength Mouse Repellent, which he uses in his fleet of collectible cars.
    https://www.amazon.com/gp/product/B07JMDYDVJ?ie=UTF8
    I Amzonned some from this link. I drive the Tundra and Jeep TJ often enough to avoid this fate. The Nissie is a spare.
