Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Sep 16, 2021 at 8:55 AM
    #541
    NWPirate
    Zach
    WA
    If it's like the Sequoia, I couldn't replace the bracket but I could pry it open and just replace the filter.
    Made a stupid big mess like @bmf4069 but I got it done.
    I'll show you mine if you show me yours.
    bmf4069[QUOTED] likes this.
  2. Sep 16, 2021 at 8:57 AM
    #542
    I have a feeling I'm missing something. I take it the fuel filter isn't in a convenient location on these trucks, like bolted to the inside of an open section of framerail?
    N84434 likes this.
  3. Sep 16, 2021 at 9:00 AM
    #543
    How often would you guys replace that fuel filter? Mine has 35,000 miles on it.
  4. Sep 16, 2021 at 9:07 AM
    #544
    NWPirate
    Zach
    WA
    I replaced my factory filter @ 130k miles. Zero issues, just preventive maintenance.
  5. Sep 16, 2021 at 9:11 AM
    #545
    NWPirate
    Zach
    WA
    From my picture above it's pretty convenient to get to on the Sequoia. Having a boxed frame, it's a little different than the Tundra but I think the filter bracket mounting might be the same.
  6. Sep 16, 2021 at 9:18 AM
    #546
    It's very easy to get to but I think the hard lines are a bitch to work with. I had the shop replace mine right after I bought in in 2016 so I didn't have to deal with it.
    shifty`[QUOTED] likes this.
  7. Sep 16, 2021 at 9:34 AM
    #547
    That wouldn't be to bad as it has a little flex to it.
    It's not hard to get to, it's just that it's hard piped in so while you're trying to get it out you're also trying not to kink the pipe. All this while it's dumping gas all over you.
    I'm not sure how many mine had, but like NW said it's just peace of mind.
    Smart man.
    NWPirate[QUOTED] likes this.
  8. Sep 16, 2021 at 9:44 AM
    #548
    NWPirate
    Zach
    WA
    The Tundra doesn't have the flex line on the left?
    I threw a hose clamp around the plastic connector for good measure.
  9. Sep 16, 2021 at 9:46 AM
    #549
    I mean, doesn't the fuel pump also have a basic screen style filter on it, so the actual fuel filter is already more peace-of-mind and in-case-of-massive-fail type of situation?
  10. Sep 16, 2021 at 9:49 AM
    #550
    Nope, it's straight in/straight out.
  11. Sep 16, 2021 at 9:51 AM
    #551
    It does. I think it's just to catch smaller shit that gets through the sock in the tank.
    NWPirate and shifty`[QUOTED] like this.
  12. Sep 16, 2021 at 10:11 AM
    #552
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    My filter looks to be original. I really should swap it out, but I know those lines are going to fail before the fitting breaks loose.... arrgh..
  13. Sep 16, 2021 at 10:14 AM
    #553
    NWPirate
    Zach
    WA
    Get a little Kroil or PB on the threads a few days prior. Then swap it out when you have a spare vehicle home. :D just in case
    N84434[QUOTED] likes this.
  14. Sep 16, 2021 at 5:10 PM
    #554
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Good suggestion on the Kroil.. I love that shtuff.... I just need to get in there and do it...
  15. Sep 16, 2021 at 5:44 PM
    #555
    Hit it 'n quit it. Oh yes.
    bmf4069[QUOTED] and NWPirate like this.
  16. Sep 16, 2021 at 5:56 PM
    #556
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    My truck doesn’t even have one
    But fuel filters typically last the life of the truck
    KNABORES, bmf4069 and NWPirate like this.
  17. Sep 17, 2021 at 6:33 AM
    #557
    Replaced mine, cause, I like to replace stuff and think that it's all fresh and new and makes my truck last longer. Had zero appreciable effect, but I don't buy from crappy gas stations. It may have lasted forever. I didnt think it was that hard to change. Had all the tools ready, nitrile gloves, oil change pan below it. Did it Nascar style to minimize fuel loss. Finished the job before my cigarette burnt out. Kidding I don't smoke, but I like to take chances. Kidding again, I mean you just read about me swapping out a perfectly good fuel filter!!!
    NWPirate and DarkMint like this.
  18. Sep 17, 2021 at 7:25 AM
    #558
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    N84434 likes this.
  19. Sep 17, 2021 at 8:05 AM
    #559
    If you guys manage to find one in the ATL area with under 250k that's in pretty good shape and under $5k-6k, holler at me! Friend of mine is looking for one to haul grain to/from his brewery and as an emergency 2nd vehicle.
  20. Sep 17, 2021 at 9:55 AM
    #560
    N84434
    Milwaukee WI.
    2001 Limited TRD
  21. Sep 17, 2021 at 10:01 AM
    #561
  22. Sep 17, 2021 at 10:22 AM
    #562
    N84434
    Milwaukee WI.
    2001 Limited TRD
  23. Sep 17, 2021 at 10:27 AM
    #563
    I think they took pics of an f-150 with a 302.
  24. Sep 17, 2021 at 10:28 AM
    #564
    N84434
    Milwaukee WI.
    2001 Limited TRD
    I think you may be right!
    That would be quite the build.. Take the world's most reliable V8 out and swap in a tired old 302...
  25. Sep 17, 2021 at 10:31 AM
    #565
    Yup. Here's a reference pic:
    And the pic in question:
  26. Sep 17, 2021 at 7:49 PM
    #566
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    06yotamike likes this.
  27. Sep 19, 2021 at 2:20 AM
    #567
    empty_lord
    05 rollover special
    I’m just trying to find an grey SR5 interior!
    lsaami and NUDRAT[QUOTED] like this.
  28. Sep 19, 2021 at 8:12 AM
    #568
    Tundra2
    Noah
    Western Kentucky
    The shit-rolet was a lost cause man.
    I can say this about it. Like ump-teen deer couldn't do it in, and a blown up differential did. Too much other shit to replace to make it road worthy. All the rotors, and Pads. Probably calipers too. Too much monies for something not worth it.
    We slapped the junkyard axle in, and decided to scrap it out. Along with the mercury tracer in the back yard, and the 80's model slide in camper. Should be big changes soon. I'll hold pops to that.
    The tent of pain however has a new patient.
    It's had something in it since I bought it back in December of 2020. :rofl:
    Parts from McGeorge are supposed to be here today. Time for a long, hot shower and then beddy bye. Up since 1:30 pm yesterday. Currently 10:12 am as of this post.
    bmf4069, Lil Steve, NUDRAT and 3 others like this.
  29. Sep 19, 2021 at 9:56 AM
    #569
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Ahhh, I remember being young….. Now I’m lucky if I can stay awake for 15 hours straight…
  30. Sep 19, 2021 at 10:18 AM
    #570
    Tundra2
    Noah
    Western Kentucky
    Yeah, burning the candle at all four ends.
    NUDRAT and N84434[QUOTED] like this.
