Anyone installed air bags for load and towing?
Discussion in 'Towing & Hauling' started by jpbewley, Nov 18, 2019.
  1. Mar 30, 2021 at 7:51 PM
    #61
    You should think about adding the Daystar Craddles. It will save the bags from possibly tearing when the Tundra is up un a lift being serviced.:thumbsup:
    Krewcial and ColoradoTJ like this.
  2. Mar 30, 2021 at 9:10 PM
    #62
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Firestone bags with daystar cradles . I have a decked system installed with a ARE cap with toytec boss shackles and shocks. Running about 20lbs in each and the ride is as good as stock with the ability of full articulation.
    F1shnF00l, TOYOTARIG, BGoodiE and 2 others like this.
  3. Mar 31, 2021 at 6:55 AM
    #63
    BGoodiE
    BGoodiE New Member
    Ben
    19 TRD SR5 OR
    NONE! Lasted about a month, Firestone bags, Decked system, ARE CX HD, WeatherTech mats/rainguards, TRD RSB...
    Anyone use anti-sieze or pipe tape on any of the connections? Hoping to install mine this weekend.
  4. Mar 31, 2021 at 6:56 AM
    #64
    NoRcptn
    NorCal
    2017 Platinum
    I used thread tape on the brass air fittings.
    BGoodiE[QUOTED] likes this.
  5. Mar 31, 2021 at 7:16 AM
    #65
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Mag 2650 w/76mm pulley, ADS suspension, 35's, misc overlanding doo-dads and lights
    Same. Then air it up and spray all the connections with soapy water.
  6. Mar 31, 2021 at 7:45 AM
    #66
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    So if I go with Firestone bags and daystar cradles, how often do I need to check the bags to make sure they still have the minimum psi?
    I tow a camper 5-10 times a year and sometimes I have an atv in the bed, but 90% of the time I run empty.
    I can just see myself forgetting to check the psi and running empty on accident due to temperature changes.
  7. Mar 31, 2021 at 10:19 AM
    #67
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    Ordered today sir, thank you
  8. Mar 31, 2021 at 11:44 AM
    #68
    NoRcptn
    NorCal
    2017 Platinum
    You’ll most likely notice if one side is off. But I check mine every few weeks since my wireless pump crapped out on me.
    CCLJ03[QUOTED] likes this.
  9. Mar 31, 2021 at 12:52 PM
    #69
    :hattip:
  10. Apr 3, 2021 at 8:10 PM
    #70
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    With your firestone and cradles did you have to add spacers since you have shackles?
  11. Apr 3, 2021 at 8:23 PM
    #71
    WolfPac_Outdoors
    WolfPac_Outdoors New Member
    Austin
    Northern California
    2018 Tundra TRD Sport White
    Yes Mucho
    There are many ways to deal the house, we choose not to use airbags because they offer no dampening or ride quality (only lift).
    COTundra23 and Mediumrarepls like this.
  12. Apr 3, 2021 at 8:30 PM
    #72
    saybng
    Gary
    Ventura CA
    ^^cool
    WolfPac_Outdoors likes this.
  13. Apr 3, 2021 at 8:37 PM
    #73
    NoRcptn
    NorCal
    2017 Platinum
    You need to explain to me what’s going on here. How does work for a heavy load and sagging? New to all these suspension options.
  14. Apr 3, 2021 at 9:13 PM
    #74
    WolfPac_Outdoors
    Austin
    Northern California
    Yes Mucho
    I figured this would open a can of worms
    check out the build video and I’ll answer any other questions you have
    Overland Tundra Build Walk Around – Ultimate Toyota Tundra Offroad Build
    https://youtu.be/259unvM7GSw
    DiamondW and ATHiker like this.
  15. Apr 3, 2021 at 9:28 PM
    #75
    NoRcptn
    NorCal
    2017 Platinum
  16. Apr 3, 2021 at 10:08 PM
    #76
    NoRcptn
    NorCal
    2017 Platinum
    Yep that’s a helluva build ! Lot a goodies on that rig for sure.
  17. Apr 3, 2021 at 10:30 PM
    #77
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Is that an extra air shock? Too cool
  18. Apr 4, 2021 at 11:24 AM
    #78
    ErikTRDTUNDRA
    Erik
    No
    saybng[QUOTED] likes this.
  19. Apr 6, 2021 at 5:58 PM
    #79
    WolfPac_Outdoors
    Austin
    Northern California
    Yes Mucho
    Yeah it’s a 2.5” emulsion shock. Takes care of load, sway, dampening, and allows for full articulation.
    Hbjeff[QUOTED] likes this.
  20. Apr 7, 2021 at 5:19 AM
    #80
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co., TX
    ‘17 CM TRDOR
    Not much…yet.
    I love the way the tower for the air shocks and x-brace are built.... you have given me some interesting ideas. Thanks.
  21. Apr 8, 2021 at 6:38 PM
    #81
    saybng
    Gary
    Ventura CA
    Can you tell me what is the part # for the firestones?..TIA
  22. Apr 8, 2021 at 6:42 PM
    #82
    NoRcptn
    NorCal
    2017 Platinum
    I believe it’s 2445 for the simple setup. Not sure what the F3wireless add on was.
  23. Apr 8, 2021 at 6:54 PM
    #83
    saybng
    Gary
    Ventura CA
    Just want to make sure this were the ones.
  24. Apr 8, 2021 at 10:36 PM
    #84
    NoRcptn
    NorCal
    2017 Platinum
  25. Apr 8, 2021 at 10:38 PM
    #85
    NoRcptn
    NorCal
    2017 Platinum
    My coworker had the whole thing installed with the wireless
    Remote at LesShwab for 499. Cheaper than I bought my kit for. Unless he’s lying to me.
  26. Apr 15, 2021 at 3:00 AM
    #86
    BGoodiE
    BGoodiE New Member
    Ben
    19 TRD SR5 OR
    5710BB59-CE78-464E-B510-DD020CAFAC30.jpg B1DC646C-180E-416A-AEF2-10B5382A4BAA.jpgInstalled over a week ago and hadn’t noticed this little top lip dip. Truck just came back from some warranty work at the dealer, won’t get into that, but it looks like that top bag is sucked into a vacuum and bottom bevel is fine. I ran these on my Tacoma and never experienced this weird bag sag up top. This is with 20psi in each bag. Anyone got an idea what’s happening?
    The Dude likes this.
  27. Aug 22, 2021 at 8:57 AM
    #87
    Mediumrarepls
    Mediumrarepls New Member
    2019 Tundra SR5 TRD Offroad Crewmax Quicksand 4x4 5.7
    Can you please share a link to where you purchased it? I can't seem to find this specific bag. Thanks!
  28. Aug 22, 2021 at 10:20 AM
    #88
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    I had Sierra Expeditions install my bags and cradles and he ran the lines out through the license plate. I always have a small compressor even though I don’t use them too much, since we sold the travel trailer.
  29. Sep 16, 2021 at 9:52 AM
    #89
    Rbeard18
    Rbeard18 New Member
    Ricky
    2018 Tundra Crewmax Shortbed
    I put SumoSpring Bumpstop on to help while towing my Travel Trailer. Is saw someone put bags behind the bump stop, that help as well with the sag? Upgrading to a 5th wheel, so wondering if that helps as well. Thanks
  30. Sep 16, 2021 at 11:17 AM
    #90
    TRDSPEC
    TRDSPEC New Member
    This.
    Had a bit of sag, bouncing, and sway towing a 21' boat with the TRD Pro suspension.
    Installed the bags and tow the boat with 15 to 20 PSI and bad behaviors are no more. Unloaded I run the bags at 3 to 5 PSI and do not notice a difference in ride from stock.
    Most don't install a weight distribution hitch on a trailer for a 21' boat and the airbags solved all towing problems with this load given the cushy TRD Pro suspension.
    ErikTRDTUNDRA[QUOTED] likes this.
