Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Sep 7, 2021 at 10:22 PM
    #2581
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Thats a significantly different offset from the post you quoted.
    Your offset puts you in the rub sweet spot .
    But you may clear with that size tire.
    Ragnarkov[QUOTED] and tonynw318 like this.
  2. Sep 7, 2021 at 10:33 PM
    #2582
    tonynw318
    tonynw318 New Member
    Tony
    Oregon coast
    2020 silver sky SR5 crewmax
    I wish I could offer more advice, but from what I’ve read, it seems like the closer you get to a negative offset, you have to be mindful of potential rubbing, but I’m not sure if 285/65r18 would. Depends if you’re talking an MT or an AT tire. I was looking at some MTs in that size that specs say are closer to a 33” tire. In AT that size is around 32.6”. So all these things play a part. If you do get rubbing, should be a fairly simple fix with that size tire. I had already removed this front flaps anyways because I think they look silly
  3. Sep 8, 2021 at 7:13 PM
    #2583
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    I have a picture/question request.
    Does anyone have pictures of their 2.5 gen Tundra on King OEM Performance series shocks, with stock 18 wheels and BFG A/T tires? And the size of the tire would be helpful as well.
    Thanks in advance.
  4. Sep 8, 2021 at 7:27 PM
    #2584
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    Baja Mike[QUOTED] likes this.
  5. Sep 9, 2021 at 10:04 AM
    #2585
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    I’m looking at a very similar setup with Icon 6-Speeds. Was going to do 285/75/17 but they are on national backorder with no ETA at DT anyway. So now considering 315/70/17. Going with Falcon shocks - they are a 2.25 level. Also have a bumper shim ordered. What are your thoughts now that you’ve had it a while.
    equin[QUOTED] likes this.
  6. Sep 9, 2021 at 10:21 PM
    #2586
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Seems like everything is on backorder nowadays. Anyway, I really like the 315s. Despite a slightly noticeable power loss, I have no regrets!
  7. Sep 10, 2021 at 2:31 PM
    #2587
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Backorder on the tires or with ICON?
    Edit: re read your post. Take a look at the 305/70 also. Same height as the 285/75 but half an inch wider. Weight wasn't much more either.20210622_071119.jpg
    rebmo, equin and tonynw318 like this.
  8. Sep 15, 2021 at 11:36 AM
    #2588
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    Front raised 2.5 inches
    Rear raised 1.5 inches with minimum air in airbags
    285/75/18 Falken Wildpeak AT3W
  9. Sep 15, 2021 at 11:45 AM
    #2589
    jpelayo85
    jpelayo85 New Member
    2021 Toyota Tundra SR5
    New Volk TE37XT's 18x9.5 0 offset with Toyo R/T 35's. I had been wanting these wheels for a long time and finally had to buy.
  10. Sep 15, 2021 at 11:56 AM
    #2590
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Looks good. So I will throw this out to anyone that might have some answers on it. I know a lot of guys don’t care about the tires sticking out and throw dirt or rocks at the side of the truck. But does it happen a lot? I know it has to. But just curious how bad. Also does the truck handle much difference in the stance? Also I’m running 285/70/18 on my tundra Pro. If I do off set on wheel 18 they will stick out about a inch. How much more will they stick out if you do 0 offset? Any info appreciated.
  11. Sep 15, 2021 at 4:12 PM
    #2591
    TundraSRQ
    TundraSRQ New Member
    Sarasota, FL
    2013 Tundra Crew Max 4 x 4
    2 1/2" Leveling Kit, Fuel Pump 18x 9 with +1 offset
    How do you like the Cooper tires? I have to replace my Toyo AT II soon
    TRDblvd likes this.
  12. Sep 15, 2021 at 5:29 PM
    #2592
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, 6112/5160, MR 701's, TOYO R/T Trails 285/75/17
    I have zero offset and the paint chips are minimal and I spend a fair amount of time on dirt rocky trails. Im OCD on keeping her clean and at the the end of the day its way worth it. ... I left mud flaps on with methods 0 offset and 295/70/7s.
  13. Sep 15, 2021 at 5:35 PM
    #2593
    RusPro21
    Don
    Pa.
    Thanks. How many inches are your 295’s sticking out with the Method wheels.
  14. Sep 15, 2021 at 6:20 PM
    #2594
    DuneShoot
    DuneShoot New Member
    West Phoenix
    ‘21 Limited Cement
    With a 2-2.5" lift and OEM offroad wheels (-60 offset?) which of these will rub?
    Toyo AT2
    Size, inches, weight, width:
    275/65R18 32.1 51 11
    275/70R18 33.2 52 11
    285/65 R18 32.6 55 11.5
    285/75 R18 34.8 65 11.3
    LT295/70R18 34.3 63 11.8
    Can't decide between the 33.2 or 34.8.
    32.6 is already 12 pounds heavier than OEM size and 34.8 is 22 pounds more!
  15. Sep 15, 2021 at 6:27 PM
    #2595
    DanTundra
    DanTundra Danny
    Wilmington, NC
    285/75/18 will rub as I just put those on this week. I had to trim the splash guard, trim the mud flaps and remove the front splash from the wheel well. Not hard to do, but I definitely feel the extra weight of the tires. However, they look amazing!
    I haven't calculated MPG as I disconnected the battery, but I see the fuel gauge quickly go down.
    The width of the tire was the issue for me to trim at full-lock/tight turns so the width of the tire needs to be less than 11.3.
  16. Sep 15, 2021 at 6:30 PM
    #2596
    DuneShoot
    West Phoenix
    ‘21 Limited Cement
    Great info, thanks.
    OEM wheels?
    Weight is a concern, don't want to go over board.
    Do they rub now that you trimmed the splash guards?
  17. Sep 15, 2021 at 6:49 PM
    #2597
    DanTundra
    DanTundra Danny
    Wilmington, NC
    OEM TRD wheels see pictures above.
    Cut the splash guard so no issues there. I trimmed the mud flaps, then felt more vibration/heard rubbing on the driver's side so I trimmed more off at lunch. No more issues now.
    DuneShoot[QUOTED] likes this.
  18. Sep 15, 2021 at 6:54 PM
    #2598
    DuneShoot
    West Phoenix
    ‘21 Limited Cement
    If you get a chance please post ic's of the trims.
  19. Sep 16, 2021 at 9:27 AM
    #2599
    DanTundra
    DanTundra Danny
    Wilmington, NC
    The mud flaps I took my multi-tool which has a saw blade and just started cutting the rear corner of the mudflap. Drove around and felt more rubbing so I cut some more. I had to cut some more after this picture, but it will give you an idea of where I was rubbing on both sides.
    [/QUOTE]
  20. Sep 18, 2021 at 4:38 PM
    #2600
    okcowboy
    okcowboy New Member
    No Mans Land (Tulsa, OK)
    2021 Tundra 4x4 1794 Edition Wind Chill Pearl
    Can anyone tell me about these wheels? I know they are 20”. A local has 2 brand new ones for sale and I want to know if the bore will fit my stock 2021 1794 and where I could get 2 more.
  21. Sep 18, 2021 at 5:52 PM
    #2601
    1794TX
    Steven
    N.TX
    '20 1794
    They'll definitely fit.
    They're +50 offset (the 18" TRD wheels are +60). I understand from a Toyota service rep and also my Discount Tire guy they're unfortunately no longer in production, but you can find takeoffs sometimes.
    20" Toyota Tundra T Force Black / Machined OEM 2020 2021 (texastrucktire.com)
    I love these wheels so much I married them, powder coated them, and will have them on my truck as soon as I get it levelled and my old tires wear out. Good choice, and good luck finding the rest of the set.
  22. Sep 18, 2021 at 6:22 PM
    #2602
    okcowboy
    okcowboy New Member
    Thank you. I’d like to see yours when you finish.
    1794TX[QUOTED] likes this.
  23. Sep 21, 2021 at 2:25 PM
    #2603
    Lost in the East
    Lost in the East New Member
    Derek
    Voodoo Blue TRD Pro
    25A8B0E4-D013-47F6-AD94-7DE0E7AD3375.jpg BBC91802-73E5-4E31-9709-24E15CD4DA3B.jpg
    TRD Pro suspension
    Westcott Designs lift in front
    Coachbuilder +3 shackles in the rear
    295/70-18 Ridge Grapplers
    SCS Ray 10
    KWC, PNWTundra2021, LR23 and 10 others like this.
  24. Sep 21, 2021 at 8:04 PM
    #2604
    RusPro21
    Don
    Pa.
    I should have asked if you were lifted. Surprised your rubbing after lifting it. How does it ride compared to factory or handle. So if I do the westcott lift and stay with my 285’s I will be fine. I plan on changing wheels down the road. Had 3 sets of SCS wheels. Waiting to see the F5’s. Had them on the 4runner Pro.
  25. Sep 22, 2021 at 6:16 AM
    #2605
    Lost in the East
    Derek
    Voodoo Blue TRD Pro
    I love look of the Ray 10s, and I think the +25 is the perfect amount of offset.
  26. Sep 22, 2021 at 8:32 AM
    #2606
    Lost in the East
    Derek
    Voodoo Blue TRD Pro
    It’s not as plush as before, but the difference is minimal.
    RusPro21[QUOTED] likes this.
  27. Sep 23, 2021 at 12:31 PM
    #2607
    Ragnarkov
    Ragnarkov New Member
    Stephen
    2021 Silver Sky Metalic Platinum Tundra
    Nothing.... yet.
    Finally got tires installed today.
    18x9 +20 offset.
    285/65R18 General Grabber A/TX
    There was slight rub, and I mean SLIGHT on full lock. I showed the removed dams and flaps from the front to show. Also showed stock vs new for comparison regarding poke.
  28. Sep 30, 2021 at 11:31 AM
    #2608
    steveoT
    steveoT New Member
    Steven
    2014 Black Tundra SR5 TSS package.
    Flowmaster Super 40 dual exhaust kit. Rough Country 6" lift kit. All LEDs
    So, I'll start off by saying that no, I have not read every reply on this thread, I mean, 87 pages, don't have time for that. What I have read, though, doesn't seem to mention Tundras with a 6" lift and what people are running as far as wheels and tires are concerned. I have a 2014 SR5 TSS package. I have the TSS rims which have a +50mm offset tires are 285/60/20. I'm putting on a rough country 6" lift kit and want to go bigger to 35/12.5/20 or 35/12.5/18. That being said, I want to have less offset, to give the truck a more aggressive stance. Any suggestions on what offset I should be looking for? What wheel width? I don't mind doing some minor plastic trimming or taking off the flaps and fog light covers. I've looked at several websites and compared notes, but I dunno, it just doesn't make a lot of sense to me. Any help would be greatly appreciated.
    Lost in the East likes this.
  29. Sep 30, 2021 at 1:22 PM
    #2609
    Lost in the East
    Derek
    Voodoo Blue TRD Pro
    I have SCS Ray 10s with a +25 offset. Nice poke and aggressive look.
  30. Sep 30, 2021 at 5:39 PM
    #2610
    jeffw6236
    Jeff
    San Antonio
    Icon 6 Speeds
    295/70/17 KO2
    Coachbuilder bumper shims but still had to remove the little front flap. Rubbed just a little before the alignment. All good now.
    3CB621AA-0615-4BCC-8540-DD784F6C8910.jpg 10239B86-B625-45C8-B229-A1D4CAF986D1.jpg 7D2499E4-44FC-4AD8-9645-83D5F694A0E2.jpg
