FS: 3 switch panel insert plate
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by CorpsTundra, Aug 24, 2021.
Thread Status:
Not open for further replies.
  1. Sep 10, 2021 at 6:44 PM
    #91
    biebs96
    PA
    Do you recall how many wires the window switch has? I extended it on my old tundra, but can not recall off the top of my head.
    Additionally, did you find a close source of dash light power for the switch lights for ran to the new location?
    thanks
  2. Sep 10, 2021 at 6:50 PM
    #92
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    The window switch is 5 wires. Some Cat3 or telco wire would be perfect, probably wouldn’t recommend cat5/6 though. I used some 18/5 sprinkler wire I had in the garage.
    The climate control panel has illumination but I’d have to look at which wire. It’s another tiny one, but the red PosiTaps work fine on it.
  3. Sep 10, 2021 at 6:52 PM
    #93
    biebs96
    PA
    perfect. I have small gauge 6 wire bundle I can use.
    I’ll tap off of the window switch then most likely.
    Just have to figure out which wire it is.
  4. Sep 10, 2021 at 6:56 PM
    #94
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    nhw544, Hightide and RainMan_PNW like this.
  5. Sep 10, 2021 at 7:04 PM
    #95
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    Anyone know what length M3 bolts are needed for this? Going to HD tomorrow.
  6. Sep 10, 2021 at 7:14 PM
    #96
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Get 20mm long socket head cap screws.
    Jkenn6[QUOTED] and TRDFerguson like this.
  7. Sep 10, 2021 at 7:17 PM
    #97
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If you have an Ace or something similar close by, I’d go there instead. When I looked at HD the other day the small metric socket head screws were all in 3 packs… probably isn’t a huge difference in price but I think this is the only time I’ll ever use 3mm socket heads.
    Thanks, I was wondering the same thing lol.
  8. Sep 10, 2021 at 7:20 PM
    #98
    biebs96
    PA
    TRDFerguson and RainMan_PNW like this.
  9. Sep 10, 2021 at 7:21 PM
    #99
    biebs96
    PA
    Curious to see what you guys pick up. I’ll be going this weekend after my panel arrives at some point.
  10. Sep 10, 2021 at 7:21 PM
    #100
    RainMan_PNW
    Casey
    Clark County, WA
    The factory switch is illuminated too- why not just extend all five wires?
  11. Sep 10, 2021 at 7:23 PM
    #101
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I think he meant he’s going to tap illumination off the window switch wire for the other switches since it’ll be right there now.
    biebs96 and RainMan_PNW[QUOTED] like this.
  12. Sep 10, 2021 at 7:24 PM
    #102
    biebs96
    PA
    this
  13. Sep 10, 2021 at 7:36 PM
    #103
    RainMan_PNW
    Casey
    Clark County, WA
    I happen to know of a thread where a guy can get the wiring diagrams and figure out which wire to tap…
  14. Sep 11, 2021 at 7:44 AM
    #104
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  15. Sep 13, 2021 at 3:33 PM
    #105
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It finally came! I need to either get some better sandpaper or fill/prime/paint the top eventually, but it fits great and holds the switches well. I drilled the thru-holes a little wider for the M4 socket head screws that I picked up - M4-.70x20mm. The screw length was just long enough to get them started while the heads weren't seated, and then heads pulled down flush after tightening them down.
  16. Sep 13, 2021 at 3:36 PM
    #106
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Nice! Yeah the original post from @RainMan_PNW mentions the need for lots sanding and filler primer if you're looking to get rid of the 3d print lines. There are 4 solid layers on the top so you should have plenty of room for light sanding unless you're using a rotary or belt sander on it.
  17. Sep 13, 2021 at 3:52 PM
    #107
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    My CM design one looked the same way.
    A little sanding and filler primer.
    The hardest part is retraining yourself not to reach forward for those moved switches !!
    GAknight, WVI, RainMan_PNW and 2 others like this.
  18. Sep 13, 2021 at 3:54 PM
    #108
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Did you scrape the "REAR" off your window switch or paint over it?
    Hightide[QUOTED] likes this.
  19. Sep 13, 2021 at 3:57 PM
    #109
    Hightide
    Abalama
    Magic School Bus
    Oddly enough, it never had it.
    Even my ‘13 had it.
    Not sure how I lucked up, but it helped with looks when flipping the switch around “backwards”
    TRDFerguson[QUOTED] likes this.
  20. Sep 13, 2021 at 3:59 PM
    #110
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yeah that's exactly why I asked, lol. The upside down lettering bothers me, but not enough to really stress about it.
  21. Sep 13, 2021 at 4:04 PM
    #111
    Hightide
    Abalama
    Magic School Bus
    Heavy duty construction marker or 90% isopropyl alcohol.
    colored my volume button with the marker 6 months ago.
    Got tired off looking at that one piece of silver.
    It still hasn’t rubbed off.
    Looks better in person.
    GAknight and TRDFerguson[QUOTED] like this.
  22. Sep 13, 2021 at 4:15 PM
    #112
    CorpsTundra
    CorpsTundra [OP] New Member
    Michigan
    2021 Tundra CrewMax SR5-TRD OR - Cement
    Did you paint the cup holder trim or wrap it?
  23. Sep 13, 2021 at 4:17 PM
    #113
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    I would be interested in one of these as well. Just looking to relocate my rear window switch.
    CorpsTundra[OP] likes this.
  24. Sep 13, 2021 at 4:18 PM
    #114
    abomb60
    Massachusetts
    Send me a PM and I'll send you the ordering details. Will have more ready to ship by Wednesday/Thursday of this week.
    nhw544[QUOTED] likes this.
  25. Sep 13, 2021 at 4:23 PM
    #115
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I painted it, but it needs to be touched up. I didn’t do the best job of prep originally and it shows, lol.
  26. Sep 13, 2021 at 4:27 PM
    #116
    CorpsTundra
    Michigan
    Looks fine in the picture! I don’t really mind the shifter trim piece finish, so I’m debating on scrapping the AJT idea and painting the cup holder trim like yours. I am not the king of patience, so chances are prep steps will likely be skipped and regretted later.
  27. Sep 13, 2021 at 4:28 PM
    #117
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It does overall look fine, there are just a few spots on the far end that you can see in the picture where the paint scraped off. Self etching primer and a coat or two of matte or satin clear coat after would help a ton.
  28. Sep 15, 2021 at 5:02 AM
    #118
    abomb60
    Massachusetts
    Another batch finished printing last night and I have a few left from a previous batch so if anyone else would like one just PM me.
  29. Sep 15, 2021 at 6:04 AM
    #119
    @BlueRibbon4x4 jump on this. :thumbsup:
    CorpsTundra[OP] and Hightide like this.
  30. Sep 15, 2021 at 7:20 PM
    #120
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    Interested
Thread Status:
