CRAWL RATIO
Discussion in '3rd Gen Tundras (2022+)' started by FO LO, Sep 11, 2021.
  1. Sep 11, 2021 at 7:15 AM
    FO LO
    FO LO [OP] New Member
    17 CM w/ 5.7 and 4.30s
    Rica25 likes this.
  2. Sep 11, 2021 at 7:23 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    My thoughts: Toyota doesn’t make a vehicle targeted at “crawlers” (although many folks use them that way) so I am not surprised that they’re not class leading in that metric.
  3. Sep 11, 2021 at 7:54 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I see 7 shitboxes listed that I'm too busy to deal with having to keep taking them in for warranty work.
    If I wanted a crawler, I would build a dedicated rig because it will get beat on every outing. Nothing worse than getting stuck on a trail behind people afraid to scratch their new Bronco.
    MTRock, Nic146, JuicyJ and 11 others like this.
  4. Sep 11, 2021 at 8:08 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    FO LO[OP] likes this.
  5. Sep 11, 2021 at 8:17 AM
    FO LO
    mountainpete[QUOTED] likes this.
  6. Sep 11, 2021 at 8:19 AM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    If you needed that much crawl ratio, you probably wouldnt be driving a Tundra. Most pickups since 4wd was introduced have a crawl ratio between 30 and 50:1.
    Cpl_Punishment and FO LO[OP] like this.
  7. Sep 11, 2021 at 8:37 AM
    rocky5100
    rocky5100 New Member
    No 4runner in this lineup? Anyways, kind of a silly comparison. Very few people buy half tons, which all do poorly, to crawl.
  8. Sep 11, 2021 at 9:05 AM
    FO LO
    Added
  9. Sep 11, 2021 at 9:48 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Cool chart, didn't know heeps and the bronco crawl ratio was so low. Ive never felt the need personally for more than 30:1 unless it's a manual, though I like to go over 0.1mph when "crawling" :D
    Nic146, FO LO[OP] and ColoradoTJ like this.
  10. Sep 11, 2021 at 10:01 AM
    I'm at 60:1, and that feels pretty good. I would like 65-70:1 with a few hundred more HP...on the Heep.
    Truck is the standard 31:1
  11. Sep 11, 2021 at 10:27 AM
    mountainpete
    My thoughts are less on the crawl ratio (which I agree for trucks this size is generally less than relevant stat) but how different the Tundra would feel with a 9/10 speed transmission and a higher first gear ratio. It would be even more of a towing beast.
  12. Sep 11, 2021 at 10:43 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    It will be significantly different to drive. Going to the Ram 8 speed isn't much, but Ford 10 speeds are a totally different animal. Most of the time empty you start out in 2 or 3, 1 is barely used, and then on the highway empty it's up and down from 8 to 10 quite a lot. It's why I'd love semi-auto capability - small hill keep it in 10 and let the engine deal with it, larger hill drop it to 8 or 7. Not the current gear limiter but an actual semi-auto where I pick the gear.
    Honestly I think the current 1st gear in the Tundra is low enough, if you need more torque than that go get a tractor. 10 speed makes a world of difference cruising at highway speed - for towing and fuel mileage.
  13. Sep 11, 2021 at 12:30 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    Smart people do the LS swap. :duel:
    ColoradoTJ[QUOTED] and FO LO[OP] like this.
  14. Sep 11, 2021 at 12:36 PM
    That's what will get me to the 65:1...and in the works sir.:thumbsup:
  15. Sep 11, 2021 at 1:55 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    How dare you mention an engine from a shit box and imply anything positive about said shit boxes company.
    :rolleyes:
  16. Sep 12, 2021 at 3:31 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    Oh, I'm sure it would be a billet block with all aftermarket goodies and an RPM Transmission. :anonymous:
  17. Sep 12, 2021 at 4:40 AM
    1UP
    1UP Truck Gang
    Blasphemy! I only said that cause of what you said earlier in the thread. ;)
    I own a JL Rubicon. It is awesome. Wife and I go back and forth about putting down a deposit on a 2022 392. Jeep IMO has come a long way.
  18. Sep 12, 2021 at 2:10 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    If I’m gonna build a hot rod or pretty much anything with horsepower, gonna be a chebby. I’ve had a bunch in the past.
  19. Sep 14, 2021 at 5:06 AM
    FO LO
    Just noticed that Chevrolet no longer puts 4 low in their transfer case for their regular 4x4 half tons. When did that change? Surprised that not many folks on here care about toyota low range off road capability from the factory. I guess folks are wanting highly reliable highway trucks with crawl control for off road work. I'd like to see toyota delete crawl control and add true crawl gear and 2 lockers.
  20. Sep 14, 2021 at 6:26 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I love that these crawl numbers (for vehicles that are decidedly NOT crawlers, well except for the Jeeps) are presented in the same colors as safety ratings. Red = danger!! Better trade your Yota in on something in the green before your whole family dies while you’re “crawling” a gravel road! :rofl:
  21. Sep 14, 2021 at 6:44 AM
    snivilous
    SW UT
    You're not taking a tundra through anything very rough regardless, so the crawl ratio is enough for 99% of people. Plus being an automatic makes crawl ratio arguably less important, since you're not committed to moving once you take your foot off the brake like a manual. If you have enough torque to climb the obstacle, then you can climb it as slow as you want assuming the tranny is staying cool. In my opinion crawl ratio is a metric that's mostly relevant to manuals, since it says how slow can you go without slipping the clutch which is (arguably) much worse than an automatic slipping.
  22. Sep 14, 2021 at 6:58 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If you get either the 6.2 or the Z71/X31 off road package, you get the 2 speed transfer case. Seems like GM is trying not to offer the 10 speed with the 5.3 too much anyway.
  23. Sep 14, 2021 at 7:01 AM
    FO LO
    I was thinking about throwing new gears in that sucker but it looks like the diff covers are welded on?
  24. Sep 14, 2021 at 7:10 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    That is the same design toyota has always used. Gears go in from the other side....
  25. Sep 14, 2021 at 7:11 AM
    snivilous
    SW UT
    It's a 3rd member, there is no diff cover like a one ton axle. The whole differential is a stand alone unit that slides out the front of the axle (Toyota 8", 9.5", 10.5", Ford 9", etc. are all like this), versus like a Dana 60 where everything is mounted inside the axle directly.
  26. Sep 14, 2021 at 7:26 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Here's my buddy in my old 4Runner. I'm in my Tundra if you can see from the mirror shape. This is at Disney, OK.
    Videos don't link good, but here I am going up a nice little hill in Arizona Bull Dog Canyon. I got back to where only motorcycles and quads were playing.
    <a href="https://imgur.com/SNhRsZv"><img src="https://i.imgur.com/SNhRsZv.mp4" title="source: imgur.com" /></a>
    There are exceptions to every rule.
  27. Sep 14, 2021 at 7:33 AM
    FO LO
    $1400 just for the parts lol. Nope. 275 65 AT3s it is...
    Do wish toyota would get a little more aggressive with gearing though. Or at least stop crawl control from sounding like is tearing the front end out of the truck.
  28. Sep 14, 2021 at 7:42 AM
    FO LO
    Lol saw this coming
    I dont have time to be dragging 4 wheelers around everywhere I go neither
  29. Sep 14, 2021 at 7:45 AM
    FO LO
    Heres a taco at 46 degrees that baby is stuck to the ground
  30. Sep 14, 2021 at 8:24 AM
    timsp8
    NY
    I’ve noticed you made a few threads and posts about the crawl ratio in the 2022 thread. What do you do or what is your goal? Do you rock climb often? I’m just wondering why it’s so important to you in a half ton.
