  1. Sep 9, 2021 at 7:38 PM
    aknickyota22
    aknickyota22 New Member
    Durango, CO
    2005 Tundra Access Cab, 2001 Corolla "oil burner"
    Stock AF
    Perfect, thanks! I emailed them back to correct the order with the other part number, seems like it's for 03-06 tundras. My bolts are quite rusted so don't really want to reuse them
  2. Sep 9, 2021 at 7:47 PM
  3. Sep 9, 2021 at 11:38 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    My 05 has the fan style from the factory
  4. Sep 10, 2021 at 12:35 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Flushed the cooling system with 3 gallons of distilled water.
    Replaced thermostat (170°) and gasket. Since it was aftermarket the bleed valve was in the wrong place, so I drilled a 1/16" hole in the correct one.
    Replaced radiator with Koyo (same core size as OEM (1.4375").
    Added a bottle of Redline water wetter and 3 gallons of Toyota 'pink' coolant I already had in the garage for a few years.
    Old crusty t-stat:
    Old radiator, 15+ years of build up on it.
    OEM core measurement:
    Koyo core measurement:
    Also adjusted my headlights tonight since I didn't after leveling the truck last week.
    Flip upside down, problem solved?
    Ditto.
    jerryallday, Lil Steve and bmf4069 like this.
  5. Sep 10, 2021 at 5:05 AM
    I mean, good job on all the work but are we just going to ignore the atrocious camber on that (early 300zx?) in the bg?
    abcinv, CodyP, oscardog86 and 2 others like this.
  6. Sep 10, 2021 at 5:15 AM
    I think that's a 240/180.
    CodyP and shifty`[QUOTED] like this.
  7. Sep 10, 2021 at 5:18 AM
    I think you may be right, early-mid 90s 240
  8. Sep 10, 2021 at 5:54 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    McGeorge Toyota knows which one is right...
  9. Sep 10, 2021 at 10:32 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Was the radiator you send back a Denso? Price on the Koyo?
    Keep us posted on the Koyo temperature performance after a few runs.
    oscardog86 likes this.
  10. Sep 10, 2021 at 10:58 AM
    So I'm replacing most of my old vacuum hoses today since they were all cracking on the ends. I had McGeorge confirm part #'s.
    One of the hoses they sent is completely different looking than the old one. I don't even see a hose in the engine bay that looks like the one they sent.
    Old ones on the right. New on the left.
    Edit- Yeah this hose is wrong. It's not the right diameter at all. Damn you McGeorge.
  11. Sep 10, 2021 at 11:03 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Yeah, thats an LS swapped 240sx drift car with modified knuckles for more angle. The camber is necessary for tire wear and contact patch at angle. It belongs to another guy in the shop.
    Radiator was some cheapo off ebay. They didn't list the core thickness so I bought it to see. And then returned it lol.
    Koyo is from rock auto, $136 + tax/shipping (and -5% discount) ended up being just under $170.
  12. Sep 10, 2021 at 11:22 AM
    Such an effective swap. The GenIII motors (not just the LS) are so universally utile. I'm shocked the pile of shop stuff I posted with LS buildup and swap books didn't even get a nibble.
  13. Sep 10, 2021 at 11:24 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The one with the U bend would fit on my truck at the location below....
  14. Sep 10, 2021 at 11:35 AM
    That looks like the part # they sent me which is 1734250140
    The one I need is also showing that same part #. It's in red below. Something is wrong on the website. You know how you can click red square and it will take you down to the part # you need. It's taking me to the part# above which seems to be a hose on the opposite side of the engine bay.
  15. Sep 10, 2021 at 12:09 PM
    @BubbaW I just heard back from McGeorge. He says "I don't know where you got that parts diagram from but it's wrong." I responded and let them know it's Toyota's website. Toyotaonlineparts.McGeorgeToyota.com
    We'll see if they make it right or not.
    BubbaW likes this.
  16. Sep 10, 2021 at 12:13 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    "Damn you McGeorge".....take backs :)
  17. Sep 10, 2021 at 12:31 PM
    Well, they responded back saying I was SOL. But I called them, and the person that answered was very helpful. They are sending me a return label for the wrong part, and giving me free shipping on the new part. The lesson here is to just call them I think.
  18. Sep 10, 2021 at 1:20 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Currently holding steady at 185-187° at idle with AC on in 75° temps.
    If it was gonna be 106° like earlier this week I'd be able to have a better idea of how it would handle idle heat soak lol. Only supposed to be 90'ish today.
    I do have a motorad 170° thermostat instead of a stock temp one now.
  19. Sep 10, 2021 at 2:02 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Front covers came in. One step closer to being able to.clean entire truck with a bottle of 303.
    JustJake, NWPirate, MS22 and 6 others like this.
  20. Sep 10, 2021 at 2:37 PM
    Some people don't like putting things in writing, others just hate typing. I've found as much as I really hate talking on a phone, probably 75%+ of the people outside of my industry actually prefer a phone call over anything else. Texts and emails piss a lot of folks off. Glad to hear they're making it right, anyway.
  21. Sep 10, 2021 at 4:14 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Installed my brand spanking new battery tie down I've been wanting for years! Thanks @Coupe for the quick shipping.
    Cheers
    -Chris
    In San Dawg
    bmf4069, abcinv, Desert Dog and 3 others like this.
  22. Sep 10, 2021 at 4:20 PM
    No skid plate krew!
    What radiator are you running? No shroud?
  23. Sep 10, 2021 at 4:23 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    @FrenchToasty no skid plate now cuz I was putting on Long tube headers and just figured I'm gonna be doing more under work with Solid Off road mounts soon! Rad is by Champion Radiators. Shroud was painful getting back in so I said "oh well" and left it out lol
  24. Sep 10, 2021 at 5:09 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Those look pretty decent. What’s the brand?
  25. Sep 10, 2021 at 5:33 PM
    Lil Steve
    Gilbert, AZ
    With an ambient temp of about 106 today, these are my numbers at idle with the A/C on, was idling for about 15 minutes waiting for my kid. Pretty sure my radiator is original, planning on a preventative replacement in the near future. These numbers don't have me worried considering the climate and circumstances.
  26. Sep 10, 2021 at 6:19 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    I wish I had taken before temps of my truck.
    Still holding at 185-187° with 90° ambient temps (w/AC).
    Truck is an ice box even after idling 10-15 minutes.
  27. Sep 10, 2021 at 6:48 PM
    Siebler
    CJ
    Eastern Oregon
    They are Coverking Rhinohide
    abcinv likes this.
  28. Sep 10, 2021 at 7:48 PM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    LBJs are done. Pitman arms and an impact make this such an easy process. 4 years on the old ones.
    des2mtn, oscardog86, Darkness and 7 others like this.
  29. Sep 10, 2021 at 9:19 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    I had a similar issue awhile back on exhaust hardware from McGeorge. Corporates website accessed via McGeorge said part didn't fit my MY but I knew something wasn't quite right so I cross-referenced part #'s to verify what I believed to be correct. Turns out it only rejected my inquiry due to a supercession in #'s. I ordered what I knew was correct.
  30. Sep 11, 2021 at 4:14 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    I'm sitting on 71,475; I made another trip up to North Ga last weekend that cost me ~300 miles. I think I'll end the year around 72,500 (based on more North Ga runs).
    I have a pic of when I hit 60k miles back in November of '17. Over the last four years come November that'll put my average around 260 miles a month. I think that's enough to keep it running right since a lot of these are highway miles.
    shifty`[QUOTED] and NUDRAT like this.
