  1. Sep 6, 2021 at 12:09 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Damn that shots expensive. Anybody know a good place with a good price on interior weatherstripping for the door sills and stuff?
  2. Sep 6, 2021 at 2:08 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    68160-0C010 and 68210-0C010 for my truck...$50 a side
    TRDGen and shifty`[QUOTED] like this.
  3. Sep 6, 2021 at 11:38 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Replaced the hamster wheel just because I had a new one laying around. Cleaned all vents with Lysol wipes as well. Just wish these first gens had a Cabin filter. I saw a DIY post long ago somewhere, just can't remember where
  4. Sep 6, 2021 at 12:21 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Went off-roading with my new 1/10 scale rc
  5. Sep 6, 2021 at 12:22 PM
    Heather the hand model had a good cleaning write up, but there is no room or access in out trucks for a cabin filter
  6. Sep 6, 2021 at 3:00 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Rear Coverking's came in. Not sure why Fronts didnt as well but waiting to hear back there.
    With the Vinyl floor the seats needed a similar life-proof treatment. The Rhinohide seems to fit the bill.
    Fit overall is good except it seems too much fabric on the backrest in the middle where it zips for the Armrest to fold down. At least 4" too much, could have cut in half and been still generous but tighter fit. Going to call on this and just check its to spec.
  7. Sep 6, 2021 at 4:53 PM
    Cummins3500
    Logan
    New oem lower ball joints and overland custom designs sway bar links.
    *still a lot of fluid film last year left. Just gonna need a light touch up coat for the winter
    Brewer50, Darkness, RUSTYNUTS and 5 others like this.
  8. Sep 6, 2021 at 7:55 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Trying to swap out from coil springs. That stupid shock rod on the bilstein 5100 won’t stay still. Keeps slipping out of my channel locks. No Allen key hole.
    des2mtn likes this.
  9. Sep 6, 2021 at 8:09 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Are you able to weld an extension to the end of the rod temporarily to give you some leverage?
    oscardog86 likes this.
  10. Sep 6, 2021 at 8:10 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    No. No welder and I’m not one. I wanna reuse the shock though so I don’t wanna notch the rod. Maybe I’ll wait till the am. I put some pb blaster on it already.
    Desert Dog[QUOTED] likes this.
  11. Sep 6, 2021 at 8:54 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    So I was able to put the strut rod end in my vice and got the nut off. But what a pain in the ass!
    I will reassemble tomorrow and cleaning everything up. I took some pre measurements as well. I’m on stock UCAs so I don’t wanna lift anymore than I have. I believe the general consensus is the very bottom notch with these 2885s. My current measurements were:
    Front hubs to fender
    21 3/8” driver
    21 1/2” pass
    Rear
    22 1/2” driver
    23” pass
    some pics to keep @bmf4069 at half chub. Check out my spring compressor. As thick as the strut lol! Not worried with this guy.
    Also took some measurements of the OME coils vs the stocks for you curious guys.
    660875D8-C0C2-4A0B-8490-BDA3234C1001.jpg 3035F4CF-81DA-471E-A851-571A9F9A412A.jpg 23DA2366-DA92-45E0-9B59-5AADE2D82F30.jpg
  12. Sep 7, 2021 at 7:28 AM
    gcholmes1
    gcholmes1 New Member
    2006 Tundra SR5
    Spent the long weekend chasing mountain trout here in NW Montana
    20210906_160101.jpg20210906_111615.jpg 20210906_152113.jpg 20210906_130931.jpg
  13. Sep 7, 2021 at 7:50 AM
    Desert Dog
    Glad it worked out for you. I was going to suggest a vice with the end of the rod wrapped in a thin piece of rubber (like a jar opener) after the welding suggestion.
    Darkness and CodyP[QUOTED] like this.
  14. Sep 7, 2021 at 8:48 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Ive been looking for something like this instead of the factory "hook" recovery points. What bolt size did you use, just the default option? Thanks for the heads up, Ill be ordering these today. Great find!
  15. Sep 7, 2021 at 9:02 AM
    Cummins3500
    Logan
    @oscardog86 yea man just the default option on the bolts. I also order (4.75 ton) shackles from them also.
  16. Sep 7, 2021 at 9:05 AM
    oscardog86
    Southern California
    Thanks! Just ordered them
  17. Sep 7, 2021 at 10:48 AM
    Nice work on these. I'd be concerned that the mounting point would cause the recovery rope or chain to contact the front bumper during extraction. Especially if the front end is buried up a bit.
  18. Sep 7, 2021 at 11:01 AM
    oscardog86
    Southern California
    This was actually Cummins3500 who found these. As for contacting the bumper that could be an issue but I have a custom front bumper that doesnt sit quite as low so Ill have to see how they work for me. Either way, should be much better than the stock recovery hooks.
    Cummins3500 and KNABORES[QUOTED] like this.
  19. Sep 7, 2021 at 12:54 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Ok OME 2885 coils installed. Seems to ride smoother actually but initially I thought they would be a stiffer ride. I had the 5100s on the 3rd clip and went to the bottom with these 885s and pretty much kept the same height so that’s nice.
  20. Sep 7, 2021 at 2:51 PM
    Cummins3500
    Logan
    @KNABORES @oscardog86 I can’t take credit for finding these. @BestGen posted them in another thread.
    I think I’m one of the few that has bought a set and tried them though
    oscardog86 and FrenchToasty like this.
  21. Sep 7, 2021 at 7:48 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The smooth ride is the best part of the 885s. Only an tiny bit stiffer than straight up stock. But extra height.
  22. Sep 7, 2021 at 8:24 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    yeah, after realizing that the coil is much longer and not as compressed as the stock one was it makes sense that the ride is smoother. Now it's on to rear leafs in the next month or so.
  23. Sep 7, 2021 at 9:02 PM
    Desert Dog
    I'm glad you posted this. I'm going to have to rethink my swaybar end link replacement choice. I have another company's set bookmarked but I'll have to compare now.
  24. Sep 7, 2021 at 9:48 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I went with Maxxsuspension ones but honestly can't tell any difference. They are definitely more stout and more expensive so hopefully they last longer.
  25. Sep 7, 2021 at 9:59 PM
    Desert Dog
    I just need something longer than OEM due to lift. It may be Maxx I have bookmarked but that's at home on my laptop.
  26. Sep 7, 2021 at 10:28 PM
    empty_lord
    05 rollover special
    i run stock offroad ones.. no issues yet
  27. Sep 8, 2021 at 12:09 AM
    Desert Dog
    Interesting. I need something. The ones on there are prolly original and look and sound like shit.
  28. Sep 8, 2021 at 3:19 AM
    huntsonora
    huntsonora New Member
    2006 Toyota Tundra DC
    I have the OME 885’s and the archive garage HD leaf pack and couldn’t be happier
    CodyP[QUOTED] and oscardog86 like this.
  29. Sep 8, 2021 at 3:32 AM
    Cummins3500
    Logan
    almost bought the suspension maxx links like others mentioned. Overland custom designs has 2 different styles, the ball joints style and a uniball style. They’ve got an account here. That’s how I found out about them
  30. Sep 8, 2021 at 7:20 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Unless they are like a quick disconnect sway bar end link what are the pro's about going with a good aftermarket end link vs. a standard rock auto?
    RUSTYNUTS likes this.
