Please help identify unknown cable/wire
Discussion in '1st Gen Tundras (2000-2006)' started by Shellback, Sep 5, 2021.
  1. Sep 5, 2021 at 2:53 PM
    Shellback
    Shellback [OP] New Member
    Pink/Silver 2001 Tundra TRD
    Peeling door window trim.
    Hi everyone.
    I need help identifying a cable. I removed the battery on my 1st gen to replace with new batt and new alternator. It was a few days ago and now I cannot remember what goes where...
    Ok, I know the battery (-) and the (+) locations.:)
    However....
    I do not remember how many cables are part of the (+) cables. The terminals were taken apart to clean off corrosion.
    There's one that I cannot remember. Its an assembly that has a 30A fuse and reads F/L on the top.
    Does this go together with the 2 other cables attached to the (+) battery terminal.
    Its a 2001 4.7, Limited 4x4
    Thank you
  2. Sep 5, 2021 at 3:03 PM
    Shellback
  3. Sep 5, 2021 at 3:19 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    that goes to pos terminal of batt and believe it’s trailer light fuse
    as a side for your future ref….any wire that has a fuse will lead to a pos termination point somewhere
  4. Sep 5, 2021 at 3:24 PM
    Shellback
    Awesome - thanks!
    another favor...could you post a photo of how these 3 wires get "assembled". As you stated, it goes to (+), but just want to make sure it looks factory and not like a hack job stereo amp cable spliced into the terminal.
    Thank you once again.
  5. Sep 5, 2021 at 3:33 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    SouthPaw and Coupe like this.
  6. Sep 6, 2021 at 7:22 PM
    Shellback
    Worked out great. She started right up. Thank you very much!
    BubbaW likes this.
