Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Sep 5, 2021 at 12:10 AM
    #331
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Forgive me if I missed mention of it but while the motor is out I would strongly consider replacing the alt, starter and oil pump since they are much more easily accessed at this time. At minimum the starter and oil pump.
    FirstGenVol likes this.
  2. Sep 5, 2021 at 4:16 AM
    #332
    daveeasa
    I’m guessing here but hopeful I got these right?
    Starter (EDITED): 28100-50100-84 $108.68 (McGeorge) or $112.70 (Decatur)
    Oil pump: 15100-50050 $290.75 (McGeorge) or $303.97 (Decatur)
    I’m thinking the starter would be a good to replace normal wear item but unsure about the oil pump. Is that something worth preemptively replacing without any symptoms of trouble?
  3. Sep 5, 2021 at 4:36 AM
    #333
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Try parts.mcgeorgetoyota.com:
    https://parts.mcgeorgetoyota.com/oem-parts/toyota-engine-oil-pump-1510050050
    https://parts.mcgeorgetoyota.com/oem-parts/toyota-starter-motor-281005010084?c=cT0yODEwMC01MDEwMA==
    Also, check your p/n's against the VIN...the starter comes up wrong
    daveeasa[QUOTED] likes this.
  4. Sep 5, 2021 at 5:43 AM
    #334
    I asked about the oil pump a few times in the past but it didn't seem to be an issue. I've never seen anyone replace theirs on here but it does seem like a good idea for a truck with 300k miles. I read a few reports on the Tacoma forum about oil pumps failing and taking the engine with them. Doesn't seem very common though.
  5. Sep 5, 2021 at 6:24 AM
    #335
    Desert Dog
    Is insurance worth having if you've never had an accident?
    FirstGenVol and NUDRAT like this.
  6. Sep 5, 2021 at 1:10 PM
    #336
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Engine won’t be out, engine stays in cab.
  7. Sep 5, 2021 at 2:21 PM
    #337
    confused by this
    Tundra2[OP] and FirstGenVol like this.
  8. Sep 5, 2021 at 2:34 PM
    #338
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    BubbaW likes this.
  9. Sep 5, 2021 at 2:37 PM
    #339
    I would have thought the engine was mounted to the frame, not the cab. In my mind the cab, fenders, hood, radiator support, bumpers and bed all have to come off. Then you have a rolling chassis with engine, trans and fuel tank attached. Then The parts would be transferred from old frame to new frame. Then body parts and and bumpers placed onto new frame.
  10. Sep 5, 2021 at 4:07 PM
    #340
    empty_lord
    05 rollover special
    The way most dealers do it is engine support to keep the engine in the cab. Chain to hold the trans end. Works faster because all the wiring and stuff can be left alone. A/c too
    KNABORES, NUDRAT, w666 and 1 other person like this.
  11. Sep 5, 2021 at 4:18 PM
    #341
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    No, and the lobbyist that made insurance mandatory should be put on pikes.
    bmf4069 likes this.
  12. Sep 5, 2021 at 6:26 PM
    #342
    Desert Dog
    If that turns out to be the case it would obviously force me to rethink. If it turns out the way @NickB_01TRD job was done I would follow through with the items I mentioned, but that's just me.
  13. Sep 5, 2021 at 6:29 PM
    #343
    Desert Dog
    I'm working on the assumption of a voluntary, mutually beneficial transaction, so that misses the point. But I'm OK with your scenario. ;)
    Sirfive[QUOTED] likes this.
  14. Sep 5, 2021 at 6:36 PM
    #344
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    If they pull the engine all the way out like the pic showed, show up that day and put a cleaning on it. Hop the fence, steal the cart its sitting on and find a waterhose. Spray it with degreaser while running for the hose.
    bmf4069 and NUDRAT like this.
  15. Sep 5, 2021 at 6:47 PM
    #345
    shifty` Oh, I have felt Cobain's sarcoma
    This is a reindeer thinking about a banana.
    I feel like it has just as much to do with the subject of this thread as the last half dozen or more comments.
    RainMan_PNW, chrisb, N84434 and 2 others like this.
  16. Sep 5, 2021 at 7:35 PM
    #346
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    If i was having a frame swapped, 65% of my time and effort would be towards cleaning and inspecting. Camp in the bed in the service bay kinda hoverhands.
    bring some stiff bristled brushes, a spray bottle or two of cleaner. And a bag of rags.
  17. Sep 5, 2021 at 7:41 PM
    #347
    Desert Dog
    Did you miss your nap time today lil guy?
  18. Sep 5, 2021 at 8:36 PM
    #348
    Might be the Hakushu talking. But also maybe this conversation done gone bananas.
    N84434 likes this.
  19. Sep 6, 2021 at 6:16 AM
    #349
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Lots of ideas have been discussed here. Decided to just go down the Toyota list first. Knock out one category at a time.
    In my mcgeorge-fu search I've found all the left side body mounts, body mount sleeves, bolts, and everything circled in this picture below.
    Here is a link to the page if anyone else wants to help me confirm.
    The parts listed on that page all say front left, center left, and rear left, etc... I'm assuming that these are universal like sway bar links. Never seen a Left/Right designation on sway links!
    My mcgeorge-fu is weak this AM. At the time of this post, I've only got the engine mounts, and te transmission mounts in my cart at McGeorge.
    NUDRAT likes this.
  20. Sep 6, 2021 at 7:34 AM
    #350
    Desert Dog
    I believe you got it correct. It is slightly confusing that they designate a left but not a right. If in doubt though, ask them to verify.
    Tundra2[QUOTED][OP] likes this.
  21. Sep 6, 2021 at 7:38 AM
    #351
    NUDRAT, Tundra2[OP] and Desert Dog like this.
  22. Sep 6, 2021 at 7:52 AM
    #352
    Tundra2
    Noah
    Western Kentucky
    Your diagram screenshot is much more clear than mine! Looks like @jpink 's steering rack bushings. Scary! But yes, looks to be very two piece like...
    I've sent an email to Mcgeorge staff. Thank you for reminding me about rusty Wallace also. Should really compare prices...
  23. Sep 6, 2021 at 8:08 AM
    #353
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    While I have expressed positives in past about McGeorge, I’ll be trying Decatur Toyota Alybamy next time, since they are closer to me and offer free shipping. While not McGeorge’s fault, for some reason FedEx can’t get correct route from VA to my neck of the woods in lower middle TN….last 3 times….VA, NC, Nashville TN, Olive Branch MS, back to Humbolt Tn, down to me….as much as 4 days late from initial posted schedule !
    shorter story….look at places closer to you if it works
    Tundra2[QUOTED][OP] and shifty` like this.
  24. Sep 6, 2021 at 8:16 AM
    #354
    Just FYI, you can get free shipping from McGeorge too. That said, I placed an order from them a week ago that still hasn't shipped. Not thrilled about that. I may give Decatur a shot.
    If you order through Toyota and select McGeorge as the servicing dealer, they still have the FREESHIP code.
    BubbaW[QUOTED] likes this.
  25. Sep 6, 2021 at 8:23 AM
    #355
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    true but when comparing prices last three times, straight from McGeorge were somewhat cheaper even with $16 shipping from McGeorge…damn you do, damn you don’t
    :annoyed:
  26. Sep 6, 2021 at 10:42 AM
    #356
    w666
    Maryland
    There are in fact TWO McGeorge Toyata parts sites...one honors the FREESHIP code (toyotaonlineparts.mcgeorgetoyota.com), and of course the unit prices are a couple bucks higher, and the other site (parts.mcgeorgetoyota.com) which has the lowest prices. Several times I've run the same parts list through both, and only one time did it pay to get the FREESHIP. Your mileage may vary...
  27. Sep 6, 2021 at 1:49 PM
    #357
    I'm three orders deep w/Serra Decatur Alabama Toyota, and every time, they've shipped it out next business day and I've had it within 48-72 hours.
    You'll save a couple percent with McGeorge, You'll save at least 10-15% using either McGeorge or Serra of Decatur AL over walk-in at your local stealership. But sounds like the service may not be as good for everyone at McGeorge, despite the better price.
    I'd rather pay a couple extra $$ and get the faster, better svc. Just my 2¢.
    If I really, really need it fast, I'll just order for local pickup at a dealership 30min away. I save about 5% less and pay tax every time, but when you need it now, you need it now.
  28. Sep 6, 2021 at 3:59 PM
    #358
    Tundra2
    Noah
    Western Kentucky
    My nearest dealer that participates in the pick up program is where I dropped the truck off for the frame. That's 2 hours from me. Lol
    I'll look at Decatur, and see about both McGeorge websites?:confused:
    NUDRAT likes this.
  29. Sep 6, 2021 at 4:38 PM
    #359
    You don't have to pick up in person through the program. I use the program and select McGeorge. Sounds like it's cheaper to just order direct though.
  30. Sep 6, 2021 at 9:22 PM
    #360
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    So what's the turn around on a new frame usually? @empty_lord
