Holes for tie downs?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jaywmu, Sep 4, 2021.
  1. Sep 4, 2021 at 11:40 AM
    Jaywmu
    Jaywmu [OP] New Member
    I’m not sure what these holes are
    meant for but are there tie downs that work with them? Would be nice to have attachment points in the middle.
  2. Sep 4, 2021 at 11:40 AM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    That might be for the OEM rail system that attaches underneath the top of bed rails.
    GODZILLA and BravoDeltaRomeo like this.
  3. Sep 4, 2021 at 11:59 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Yup.
    Mine has the rail system and no holes are visible.
    GODZILLA likes this.
  4. Sep 4, 2021 at 12:49 PM
    TaquitoBandito
    Joel (AKA Bif)
    Yep, it's for the rail system. Where are you located?
  5. Sep 4, 2021 at 1:09 PM
    Jaywmu
    So does that mean
    Michigan. So if I just buy a rail system I should be able to install without drilling?
    BravoDeltaRomeo likes this.
  6. Sep 4, 2021 at 2:08 PM
    TaquitoBandito
    Joel (AKA Bif)
    Well, I was born in Michigan but live inTexas. I was gonna say I might be able to hook you up.
    I’ll look at my truck when I get back home but I’m 99% sure it’s for the racks. The racks should come with the pins to install. I’d get some tie down cleats too.
  7. Sep 4, 2021 at 2:11 PM
  8. Sep 4, 2021 at 2:12 PM
    Jaywmu
    I looked it up. It’s only about $200. Any downside to the system? Does it get in the way of other things? I have a trifold cover on now.
  9. Sep 4, 2021 at 2:16 PM
    Some bed covers require drop down brackets for the rails, but you loose alot of strength as the brackets are aluminum.
    GODZILLA and TaquitoBandito like this.
  10. Sep 4, 2021 at 2:17 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    What trifold? You might need a relocate kit that brings the rails down so it doesn’t hit the trifold
    TaquitoBandito likes this.
  11. Sep 4, 2021 at 2:18 PM
    You should have 5 or 6 holes on each side of the bed. It looks like they have been covered by the Line-X.
  12. Sep 4, 2021 at 2:22 PM
    Jaywmu
    Gator
  13. Sep 4, 2021 at 2:46 PM
    Jaywmu
    if I wanted to keep things simple and use the existed hole to attach a d ring does anyone know what hardware I would need?
  14. Sep 4, 2021 at 3:59 PM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    M6x1 for the bolts and then any D-rings you like, I have these and they’re sturdy.
    4 V-Ring Tie Down Anchors | 2" Diameter Steel Bolt-on D-Rings for Cargo on Trucks, Pickups, Trailers | Flush Mount TieDown Anchor, Replacement for D-Ring Tie-Down w/Plastic Pan Fitting B016YJY7L8 https://www.amazon.com/dp/B01CGXSNC0?_encoding=UTF8
  15. Sep 5, 2021 at 7:56 AM
    Retired...finally
    I like this option but have a question or two. My yet to be delivered SR5 4x4 CM is getting the factory sprayed bedliner. My guess is that no one masked off the bed bolts before spraying the bedliner. This would be a royal PITA to clean the bedliner material out of the torx recesses. Can anyone verify my suspicions?
    Secondly, the paperwork from the dealer states this truck will have bedrails and a tailgate cap. Do any attachment fittings come included with the bedrails?
    I'm trying to gather up as much needed odds and ends before the truck gets delivered
  16. Sep 5, 2021 at 8:28 AM
    Jaywmu
    I have the factory sprayed liner. My bed bolts were sprayed over but the tailgate ones were removed first. What I thought was odd, and I’ve seen this on other trucks, is that the anchor points near the cab were sprayed but the ones by the tailgate were taped off. Can’t figure out the reason why they didn’t just spray them both.
  17. Sep 5, 2021 at 8:54 AM
    Retired...finally
    That is odd. How many anchor points are available? Can get the 4 pack or the 10 pack and I like tiedowns. Bunches of them.
  18. Sep 5, 2021 at 9:35 AM
    Jaywmu
    Just the four in the corners. This is what I’m talking about just in case anchor points isn’t the right term.
  19. Sep 5, 2021 at 10:08 AM
    Retired...finally
    Are those standard? I'm also wondering about the bolts that secure the V rings Barrett50 mentioned.
  20. Sep 5, 2021 at 10:18 AM
    Jaywmu
    Yeah those are standard. I use a bungee cargo net often so I need something in the middle to attach to.
  21. Sep 5, 2021 at 10:31 AM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    To be clear, I don't believe the hole that is circled in the post above is a bed rail mounting hole. Not sure what those holes are for but there are no threads in that hole. It appears that the 6 holes (on a double cab there are 6, not sure on crewmax) on each bedside have been covered with the bedliner. (There are also 4 holes on the front of the bed.) You will likely need to use a punch and 6mmx1.00 tap to clean out the holes. You can then add D-rings or V-rings. I just did this myself, though the bolt locations were at least open in my case. More information in the link below.
    https://www.tundras.com/threads/3rdtundras-2017-double-cab-build.92631/#post-2392469
    1lowlife likes this.
  22. Sep 5, 2021 at 10:34 AM
    3rdTundra
    Central Texas
    You can see the unthreaded hole that you see next to the mounting locations in this picture:
  23. Sep 5, 2021 at 10:42 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You are correct, kind of.
    The hole in the OP's pic is a guide hole for a pin in the bed rail system, so it is somewhat a mounting hole.
    It is bigger than the bolt holes and less likely to be covered with the spray liner.
    I recently added the bed rails to my 2014 DC and it has a factory spray liner.
    Although none of my bolt holes where covered..
    You can see the guide pins in this pic..
    So the OP is likely to have another hole just like it towards the front of the bed sidewall and one in the middle of the bed front wall.
  24. Sep 5, 2021 at 10:56 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    ^ If one was just wanting more tires downs, this would be the way to go IMHO...
    Great idea..:thumbsup:
  25. Sep 5, 2021 at 1:49 PM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    The bed liner comes off easy with a razor blade, take your time and sure you can access torx. The D rings can be attached with these to the rail system 5D9D522C-A5C8-40F4-9160-B94443137D89.jpg
  26. Sep 5, 2021 at 2:00 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    If your truck comes with the rails, it should have 4 of these HUGE adjustable tie downs
    I couldn't use mine because of my bed cover so I sold them on the forum.
    You can purchase more, or get something like this:
    I bought these for mine but had to do a little bending to get them below my Flex bed cover..
    Review - CCR Sport Deck Rail Tie Down Hook for Tundra with a cover and rail system | Toyota Tundra Forum (tundras.com)
    eltv468l_6cbec7ff0de3b4b555e01b4a8549bd2f0018be12.jpg l7daq8yo_021877f6cfa3256f31931a318a25cf70d536b05b.jpg
    As far as a tailgate cap, all tundras have a plastic cap on the tailgate..
    31258F4B-173C-4B87-850F-D3CEABCE1B23_zps_7407044879fbce6d8e702dca1883197df058b322.jpg
    E56C2A52-CB37-4473-BA4A-B034B228A760_zps_502eb92db0716579cf47540ed62f91eb57e1d310.jpg
  27. Sep 5, 2021 at 2:03 PM
    Retired...finally
    Thanks for everyones help. I'm sure it will all come together in my head once I see the truck. Those fixtures remind me of my unistrut days. I was thinking the V rings from Amazon attached on the floor using the existing bed mount bolts.
  28. Sep 5, 2021 at 2:11 PM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    They can attach to the floor as well.
  29. Sep 5, 2021 at 2:15 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    These are super nice and stainless steel. The 2 different sizes looks like. Larger one would probably work on the bottom of the bed and the smaller one around the sides.
    Dog River Tools Stainless Steel Multi-Purpose Tie Down Anchor Strapping Hooks for Mounting in The Garage, Work Shop, Truck, Trailer, Golf Cart, Fence (8-Pack) https://www.amazon.com/dp/B07YNMGCBF
    1lowlife and Barrett50 like this.
  30. Sep 5, 2021 at 3:11 PM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Anyone happen to know the torx size for the bed floor bolt? Wtv it is I don’t have it. Was thinking about adding one of those D rings for something.
