  1. Sep 2, 2021 at 4:57 PM
    Also, our frame rails look perfect to get a long air tank mounted into!
  2. Sep 2, 2021 at 4:58 PM
    daveeasa
    Give me some hot air you toasty Frenchman.
    MrDirtjumper and FrenchToasty like this.
  3. Sep 2, 2021 at 6:06 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Fancy! I used some clear tubing I had laying around.
  4. Sep 2, 2021 at 6:40 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Reg and access cabs are different I’m afraid
  5. Sep 2, 2021 at 7:01 PM
    daveeasa
    I did spy some bolt holes and heaps of space. Seems doable. Maybe a totally different bracket I suppose? It’s a great spot for a compressor
    oscardog86 likes this.
  6. Sep 2, 2021 at 7:10 PM
    empty_lord
    05 rollover special
    I’m not sure the complete body differences. But I think our overall engine bay height is shorter. Which would mean anything he installs there likely will contact out hoods
    NUDRAT likes this.
  7. Sep 2, 2021 at 7:11 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Woop, extremely excited for it! I like that the power steering reservoir will be accessible still, not that I go in there too often.
    I got most of the way through my transfer case seal job today but of course I ran into trouble. I can't get the lock nut on the companion flange to break loose, even with an electric impact. I think I'm going to have to make some sort of tool to keep the companion flange steady instead of using breaker bars, then hit it again with the electric impact. The tight spaces thanks to the crossmember and cat aren't doing me any favors that's for sure.
    I also installed my Inno rack, no pictures yet.
  8. Sep 2, 2021 at 7:17 PM
    Yeah I tried to make everything accessible.
    im sure you have, but did you get the detent out of the lock nut. I remember doing my carrier bearing and it wasn’t as easy as I thought it would be.
    des2mtn[QUOTED] likes this.
  9. Sep 2, 2021 at 7:20 PM
    des2mtn
    SW
    Tonto cover
    Yeah, I punched the detent out. I thought I was going to have a hard time separating the driveshaft from the companion flange but separated easy with a few tappy tappys.
  10. Sep 2, 2021 at 7:25 PM
    empty_lord
    05 rollover special
    Have you tried putting it in 4x4 and loosening it?
  11. Sep 2, 2021 at 7:30 PM
    des2mtn
    SW
    Tonto cover
    Nope, was worried about screwing up the internals. Is that the route you'd take?
  12. Sep 2, 2021 at 7:31 PM
    empty_lord
    05 rollover special
    Won’t hurt it more than you driving it in 4x4.
    FrenchToasty and des2mtn[QUOTED] like this.
  13. Sep 2, 2021 at 8:00 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Won't copper cause steel (your frame) to corrode? Be a shame if so.
  14. Sep 2, 2021 at 8:08 PM
    i was going to throw some heat shrink where it touches only for noise reduction.
    I couldn’t imagine it rusting more than constant water dripping onto metal. Not to rub it in, but we don’t rust here
  15. Sep 2, 2021 at 8:09 PM
    daveeasa
    This makes me more worried about the group 31 battery. Tons of room on the side but not sure about hood clearance.
  16. Sep 2, 2021 at 9:24 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    127.pdf (grabberman.com)
    Galvanic Reaction.
    Galvanic Reaction: Incompatible Metals Responsible for Corrosion - Monarch Metal
    Most commonly, galvanic corrosion can be seen in plumbing systems where a copper pipe is directly connected to a steel or iron pipe. Once in contact both metals can undergo galvanic corrosion because of the electric or galvanic current that takes place at the anode and cathode of the pair of metals.
  17. Sep 3, 2021 at 5:12 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  18. Sep 3, 2021 at 11:12 AM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
  19. Sep 3, 2021 at 11:55 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    From my experience copper gets the damage from that. I've seen many a pinhole and yards of green pipe from landscapers using galvy nipples to add sprinklers on copper water systems. Never seen the galvy damaged from it. His frame should be painted and if he shields the copper it should be fine.
  20. Sep 3, 2021 at 12:14 PM
    daveeasa
    des2mtn, alb1k, Sirfive and 1 other person like this.
  21. Sep 3, 2021 at 12:41 PM
    I thought the Mishimoto doesn't have a trans cooler? That would be a hard pass for me.
    jImmegart likes this.
  22. Sep 3, 2021 at 12:50 PM
    daveeasa
    I believe that's the case and I think I feel similarly.
  23. Sep 3, 2021 at 1:06 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
  24. Sep 3, 2021 at 1:09 PM
    Perhaps they changed it since @empty_lord mentioned it a few times. If so, that would be great.
    des2mtn likes this.
  25. Sep 3, 2021 at 1:34 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Leveled the front of my 2wd with a 1/2" and 1/4" spacer and gave it a fresh alignment.
    jerryallday and Mitch09 like this.
  26. Sep 3, 2021 at 1:39 PM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Hi yaaa. Whats New???
    anyways. not much has changed. got lower ball joints in the mail yesterday. Getting those on the truck before the end of the month.
    Colorado trip is set the 28th - October 1st (ish). If anyone is around let me know! Will be starting at Red Cone and making our way out to the San Juans to do all the classics.
    Darkness, Voss and des2mtn like this.
  27. Sep 3, 2021 at 2:15 PM
    jImmegart
    Jonah
    California
    Isnt the trans cooler externally mounted?
  28. Sep 3, 2021 at 2:17 PM
    Yes but the radiators in our truck still help I guess. There are trans lines that run into the bottom of the radiator.
  29. Sep 3, 2021 at 2:18 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It runs through the radiator as a warmer before it goes to the cooler behind the grille.
    That's how the lines are on the RC anyways. I plan to bypass all that like I did on the V6.
    jImmegart[QUOTED] likes this.
  30. Sep 3, 2021 at 2:51 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    The trans line in radiators isnt really a cooler. A little, but its meant to get trans fluid up to temp.
    jImmegart and Tundra2 like this.
