So are we not worried about spacers anymore?
Discussion in 'Wheels & Tires' started by CCLJ03, Mar 21, 2021.
  1. Mar 26, 2021 at 8:18 PM
    #61
    Hobbesdsm
    Hobbesdsm New Member
    Eddie
    2016 crewmax limited
    TRD exhaust and rear sway bar, 2018 led headlights
    I have never need to use thread lock with spacer, just torque it to oem torque spec. Never have an issue. But that’s just me:)
    rockmup, Badknees and JeffMac[QUOTED] like this.
  2. Mar 27, 2021 at 6:08 AM
    #62
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I’m pretty sure the last set of Spidertrax I installed had a torque recommendation of 135 Ft-lbs and also came with red loctite so I was surprised about the BORA instructions and their voiding of the warranty if loctite is used. Maybe blue loctite is a little better than red for this application...
  3. Mar 27, 2021 at 6:36 AM
    #63
    TheBubbaDude
    TheBubbaDude New Member
    2020 Tundra TRD Pro
    AJT Blackout Kit 1.25" Wheel Spacers NRG 285/70/18 Meso Customs TRD Start Button
    This is a 1.25" spacer with 285/70 on stock TRD rims. My calculations it gives me an offset of 28. Installed properly with blue loctite and retorqued at every rotation. No issues and a mean look.
  4. May 17, 2021 at 5:47 PM
    #64
    Pariverpirate
    Pariverpirate New Member
    Rich
    2015 Tundra TRD Off Road
    Non yet
    Ive been doing way to much research on spacers. Just put fender flares on the truck today and now I want to put spacers on to make them a little wider. My problem is I haul a 6500lb camper. I dont haul it all that often , but will be hauling it to georgia from PA in a couple months. Whats everyones opinion on hauling with spacers?
  5. May 17, 2021 at 6:06 PM
    #65
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    I can vouch for BORA, had them on several vehicles. USA made, you can actually talk to the owner, and he makes a nice product. STAY AWAY from the cheap ones on eBay etc. I had a set where as soon as I torqued the lug nut the stud snapped right off. They went straight in the trash and I learned my lesson.
    #65
    AggiePhil and Bigbird57 like this.
  6. May 29, 2021 at 10:05 AM
    #66
    CCLJ03
    CCLJ03 [OP] Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Oh man I would love to see some more pictures!
    TheBubbaDude[QUOTED] likes this.
  7. Jun 2, 2021 at 11:25 AM
    #67
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    I bought some RR. Will see how they are. I like how they say grade 8 but it’s metric. 8.8 metric is roughly equivalent to grade 5 sae. And 10.9 is like grade 8. Which they clearly say 10.9 on the back of the studs.
  8. Aug 24, 2021 at 3:44 PM
    #68
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    anyone use spacers on stock steelies? Thinking they should have the pockets to use 1" spacers but just wanted to confirm.
  9. Aug 29, 2021 at 12:28 PM
    #69
    salmonator
    salmonator New Member
    Tigard, OR
    2019 Tundra SR5 4x4 DC
    I
    Yes. Mine are stock SR5 Steelies I use for winter tires. Backside of wheel looks flat,no pockets. Took all of 5 min to grind the stock rear studs so they don’t protrude past the spacer. Not a big deal.
  10. Aug 29, 2021 at 3:31 PM
    #70
    MadMaxCanon
    Thanks sir
  11. Aug 30, 2021 at 3:38 PM
    #71
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Anyone with 1.25" spacers and 295-70-18 tires on a OEM wheels by chance? I have a TRD Pro that is lifted an extra 2" up front (4" total) and 3.75" at the back. I currently have 1.25" spidertrax spacers with my TRD Pro BBS wheels and 275-70-18 KO2s but want to upsize to the 295s. If anyone has any input please let me know as im scheduled this Saturday at the tire shop but can easily back out.
  12. Aug 30, 2021 at 4:08 PM
    #72
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I have a 2013 with 295s and stock steel wheels. Leveled, not lifted with 1.25 spacers. I took the spat, front mud flap, off. I've heard it rub 3 times. Always while turning and breaking. Once tires were aired down to 18 psi. I can't duplicate it and never saw a mark.
    RoniusMaximus[QUOTED] likes this.
  13. Aug 30, 2021 at 7:50 PM
    #73
    RoniusMaximus
    J
    Thanks. Yeah, im starting to expect that the front bumper mud flaps will need to be removed. Right now, I have absolutely no rubbing...
  14. Aug 31, 2021 at 5:35 AM
    #74
    Badknees
    Badknees New Member
    Hello,
    I have a 2016 1794 CM 4X4. I installed the Fox TRD Pro suspension and 1/4 CB shims in front, so lifted about 2.5" from stock in the front and added 1.5" shackles in the rear. I'm running 1" Bora spacers on the 18" Pro BBS wheels and 295/70 Cooper XLT AT3 tires. I started out with 1.25" spacers. For me, I removed the front small flaps and used a heat gun to shape the front wheel well liner and mud flaps to eliminate the rubbing. No biggie and maybe an hours worth of work on cheap $35 well liners. I think I gained a little clearance when going to 1" Bora spacers and just reducing by 1/4" helped with the crap being thrown onto the side of my truck.
    Best.
  15. Dec 5, 2022 at 11:04 PM
    #75
    cementsharktrd
    cementsharktrd New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
    How many pound feet of torque do you usually torque the spacer to your hub with?
  16. Dec 5, 2022 at 11:08 PM
    #76
    cementsharktrd
    Demetrio
    How many lbs of torque did you use to torque the spacer to your hub?
