Gauges app on Kenwood stereo
Discussion in 'Towing & Hauling' started by AZBoatHauler, Jan 28, 2020.
  1. Aug 25, 2021 at 4:05 PM
    avssuc
    avssuc Efilnikufesin
    Gulf Coast
    2021 Tundra TRD Pro LR
    No, that's the 1st picture, that was with it plugged in to the Scangauge. I unplugged the Scangauge, turned the truck off, and restarted; the message disappeared, but I'm still unable to connect to trans temps.
  2. Aug 25, 2021 at 4:06 PM
    avssuc
    Gulf Coast
    Haha, so I just need to wait? I hope it's that simple. I couldn't find the update option, but it looks like it's automatic:
  3. Aug 25, 2021 at 4:22 PM
    stlfan
    stlfan New Member
    DFW
    2017 Tundra SR5 4x4
    2018 OEM LED HEADLIGHTS, BAJA DESIGN FOGS, PRO GRILL & SURROUND, 3M CRYSTALLINE TINT40%, 8" SS BAM EXHAUST.
    I hope it works for ya, You could also try resetting the meastro unit instead of just validating PIDS. I have done that as well, I was nervous at first thinking settings on meastro would be erased but everything came back fine. I think it’s called “master reset”
  4. Aug 25, 2021 at 4:23 PM
    avssuc
    Gulf Coast
    Just got inside from doing that, no dice. Seems like my Scangauge did something on initialization, shouldn't be too much of an issue I hope. Maybe just 24 hours is all it takes.
  5. Aug 25, 2021 at 4:24 PM
    AZBoatHauler
    AZBoatHauler [OP] SSEM#140 / 2.5 gen plebe
    So.Arizona
    Well I can tell you I lose my trans temp from time to time (just shows up as -) and going through the validate PID process always brings it back.
    avssuc[QUOTED] likes this.
  6. Aug 25, 2021 at 5:07 PM
    avssuc
    Gulf Coast
    Well crap, maybe I just keep the Scangauge? I haven't found any options to validate PIDs in my 1007, but I'll talk to the guys that put it in, they should set it right, if it hasn't righted itself in 24 hours.
  7. Aug 25, 2021 at 5:19 PM
    avssuc
    Gulf Coast
    And boom, like that, the reset or something worked, thanks for the assistance folks!
    AZBoatHauler[OP] likes this.
