Transmission fears sadly confirmed...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Famof5Tundy, Aug 13, 2021.
  1. Aug 14, 2021 at 7:10 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    You could always experiment with 2WD and lower tire pressure, then if you feel you have inadequate traction, switch over to 4WD. I personally wouldn't run it in 4 high under those conditions, but that's just me.
  2. Aug 14, 2021 at 7:36 PM
    Famof5Tundy
    Famof5Tundy [OP] New Member
    2020 MGM CM Platinum
    Just getting started
    I've resorted to 4hi, no trailer...spreads 15-25 mph. Trailer, 4lo speeds 8-10 mph. Should work out fine.
    Hope this is helpful. Literally NO ONE I know and wheel with dies 4lo in the beach.....but with the trailer....it all made sense
    Wallygator and GODZILLA like this.
  3. Aug 14, 2021 at 7:38 PM
    18" TRD Off Road Wheels
    Happy wheeling! May your transmission last a million miles. :thumbsup:
  4. Aug 15, 2021 at 12:28 PM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    All of the Toyota's I've owned lock out the OD gears in 4LO if you're in D. You can select 1st, 2nd, 3rd, 4th and stay in that selection range. Max speed maybe 35-40mph without OD gears involved.
    I also read about the 2019+ Toyota trucks locking the trans more often in order to keep the pan temps down to "expected operating temperature range". Manipulating software is slick, but to me basic over-engineered cooling capacity is better.
  5. Aug 22, 2021 at 10:00 PM
    diablodalton
    diablodalton New Member
    Dalton
    Oregon
    2021 Crewmax Platinum MGM
    8" Ready Lift, SPC UCA's., Bilstein B8 8125, Amp Steps, 37/12.5R 20 Cooper STT PRO, On order: Valhalla Armor, Dirty Deeds Exhaust
    Is this the time we introduce a Power Steering cooler? Especially for sand…
    Retired...finally likes this.
