5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Jul 10, 2021 at 9:40 PM
    #871
    dongziye
    dongziye New Member
    The black paint on the cooler pipe seems very thin. A lot of paint chips when it arrived. Wondering whether it would develop rust... Maybe it is my OCD.
  2. Jul 23, 2021 at 1:21 PM
    #872
    jimbrophotodotcom
    jimbrophotodotcom New Member
    Hawaii
    2021 Lunar Rock Tundra TRD Pro
    IG: @LunaTheTundra, Coachbuilder kit and 35s soon
    any way to get a cooler thats black in color? It kinda stands out behind the grill otherwise.
    IndianaGeologist and GODZILLA like this.
  3. Jul 23, 2021 at 1:46 PM
    #873
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    The Setrab is black.
    IndianaGeologist likes this.
  4. Jul 23, 2021 at 1:48 PM
    #874
    jimbrophotodotcom
    Hawaii
    You got a link? is it an option for the kit?
  5. Jul 23, 2021 at 1:53 PM
    #875
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
  6. Jul 23, 2021 at 1:56 PM
    #876
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    2019 platinum 4x4 magnetic gray
    Here’s mine installed.
  7. Jul 23, 2021 at 1:57 PM
    #877
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
  8. Jul 23, 2021 at 2:00 PM
    #878
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Awesome - the Setrab kit is supercharger friendly.
    IndianaGeologist and Platinum714 like this.
  9. Jul 25, 2021 at 1:06 PM
    #879
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    What is the weight of your boat or model please?
  10. Aug 2, 2021 at 6:16 PM
    #880
    Genuine Cooling Systems [OP] New Member Vendor
    Looking for a 2014-2018 5.7L Tundra owner who would like to install an additional cooler on their truck. I have a prototype that needs to be tested and all I ask for is you complete the install ASAP, provide the necessary photos, and work with me on any changes, instructions, etc.
    Let me know if you are interested.
  11. Aug 2, 2021 at 7:45 PM
    #881
    jimbrophotodotcom
    Hawaii
    Very interested sir
  12. Aug 2, 2021 at 7:58 PM
    #882
    Do you have a 2014-2018 Tundra?
  13. Aug 2, 2021 at 9:14 PM
    #883
    jimbrophotodotcom
    Hawaii
    No sorry I have a 2021… I got too excited before reading it and comprehending.
  14. Aug 3, 2021 at 6:27 PM
    #884
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Interested
  15. Aug 3, 2021 at 7:39 PM
    #885
    Hamster14
    Hamster14 New Member
    Utah
    2014 Tundra Limited
    -46 gallon tank - shell
    what are the risk or downsides of being the Guinea pig? I have a 14 CM
  16. Aug 4, 2021 at 1:03 AM
    #886
    I found someone, thanks everyone.
  17. Aug 9, 2021 at 6:25 PM
    #887
    TundraHulk02
    TundraHulk02 New Member
    2020 White Tundra TRD Sport CrewMax
    Been running the setrab on my 2020 CM towing a TT about 6000lbs..outside temps are around 85degrees..my Torque temps at the highest going uphill are about 245degrees the Pan only 210 at the max..the Torque temps drop quick for the most part back down to about 208 while the pan is 205..is this normal to be that high on the torque with this cooler? It does go back down quick like I said for the most part. Just curious. Also I have somewhat of a steep driveway and getting the TT back up the pan went at about 255 and the torque at 280. Wasent for too long maybe 5 min until I was able to get the trailer in a good spot. Would I need to flush out the fluid now? Since my temps reached that high. Thanks for any info.
  18. Aug 9, 2021 at 6:47 PM
    #888
    Yes, torque Temps always run way higher. The cooler has little impact on that, but it's nothing to worry about. The pan temp is what matters, because there not much you can do for the torque converter temp. It can take the heat.
    Low speed trailer maneuvers will always spike your temps. As for swapping the fluid, hitting those temps nce or twice doesn't do much. Sustaining those temps or repeatedly hitting them frequently might require a fluid change.
  19. Aug 9, 2021 at 7:04 PM
    #889
    TundraHulk02
    Thanks for the information, I really appreciate it. Can’t stop thinking all day that I ruined my truck a bit. Thanks again
  20. Aug 10, 2021 at 4:20 PM
    #890
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    going backward no to little air flow across your cooler. Assume 2000 hrs of run-time to get to 50K miles. Don't think 5 minutes will have any affect on the longevity of your fluid.
  21. Aug 15, 2021 at 8:15 PM
    #891
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    Going to be installing the Genuine kit soon. How perfectly level does the truck need to be to check the fluid level? My work space isn’t too sloped but it’s not perfect either.
  22. Aug 15, 2021 at 8:27 PM
    #892
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    My driveway has a very gentle slope to it. I got under my truck with a level and used a jack and stands to get the pan exactly level front to rear and side to side.
  23. Aug 16, 2021 at 9:39 AM
    #893
    You want it as close as level as you can.
    Jhon[QUOTED] likes this.
  24. Aug 16, 2021 at 7:16 PM
    #894
    avssuc
    avssuc Efilnikufesin
    Gulf Coast
    2021 Tundra TRD Pro LR
    Just wanted to say thanks for the quick and easy transaction, looks like everything is here, and I'll update as soon as I take delivery and have the dealership install this for me.
  25. Aug 18, 2021 at 12:12 PM
    #895
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    did you end up using the eastwood radiator paint? was 1 can enough? finally got my kit in and am going to purchase this asap. thanks in advance.
  26. Aug 18, 2021 at 12:50 PM
    #896
    rothmigo
    rothmigo New Member
    DFW TX
    2020 Tundra Crewmax Platinum
    7" BDS/Fox, 5.29, 37x13.50 Nitto, 22x12 Hostile Rage,BAM
    Yes. At least 1/2 can left. I think they sell a prep spray but I just scotch padded the sides, top and bottom to etch it a bit and hosed it off with brake cleaner and let dry really good. I read that paint likes ideal conditions to apply and timing of 2nd coat. It's thin and fumey for sure! I could smell the paint baking for several drives. Watching the OBD Fusion it's clear the tstat and cooler works well. Cooler is huge compared to one on our older Sequoia. I ended up putting my in/outs on the passenger side to help with fitting a SC cooler should I attempt someday, hose bends may be on tighter side, but I used some spiral hose wrap and hose spacer clamps and don't think hose will collapse over it..Nick probably doesn't recommend with concern of hose crimping but I'm satisfied with the routing, worst case it's a re-route. It's not a daily driver so I farted around with this project for a while lol. I lubricated hose ends with ATF and heated with hair dryer to soften them when making connections..super helpful. In a couple of weeks truck and cooler will get a good workout towing our trailer on a long haul in higher ambient temps. Enjoy the great kit!
  27. Aug 18, 2021 at 12:57 PM
    #897
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
    Nice! thanks man. yeah i'm just gonna scotch pad it and wipe it down with some acetone. gonna buy 1 can.
  28. Aug 22, 2021 at 6:30 PM
    #898
    Chip_Tundra
    Chip_Tundra New Member
    Thanks @chasenicholas93. Your kit was perfect. Install took a couple hours, and no issues to report.
    Took it out today after install and recorded some temps
    Climbing on a hill: 190 deg on TC, 170 at the pan
    Flat road with TC locked: 176 deg on both TC and Pan.
    These were recorded with the thermostat pinned, and with an ambient temp of 97 to 98 degrees in Las Vegas.
    Here are some pics. Don't mind the messy garage. It's in the process of getting cleared out lol
  29. Aug 22, 2021 at 6:41 PM
    #899
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Pictures can tell stories sometimes, but make sure the lower hose isn't rubbing on the bolt head or mount.
  30. Aug 22, 2021 at 6:49 PM
    #900
    Chip_Tundra
    That has been accounted for. Plenty of clearance for the hoses, and secured in all spots.
    If you look up close, the hose doesn't touch the bolt you're talking about.
    dt325ic[QUOTED] likes this.
