  1. Aug 18, 2021 at 9:21 PM
    Punisher17
    Punisher17 New Member
    A trd Camry would be really nice but too expensive. I’m considering a used Avalon and moving on from the Tundra. Thoughts? :eek:
  2. Aug 19, 2021 at 6:12 AM
    rvrats2
    rvrats2 Too Often Yankees Overprice This Auto
    Carbondalé, CO
    2011 SR5. Bench Seat!
    Avalons are awesome. If I could find one around here for a commuter I’d be all over it. And they have hybrid ones too, not sure what year that started.
    Punisher17[QUOTED] likes this.
  3. Aug 19, 2021 at 6:14 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I believe 2012 is the first year of the hybrid Avalon
    Punisher17 likes this.
  4. Aug 19, 2021 at 6:29 AM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    What other parts are you waiting on?
    Peeeheeuuu[QUOTED] likes this.
  5. Aug 19, 2021 at 8:38 AM
    Peeeheeuuu
    Peeeheeuuu New Member
    Peter
    Elk Grove, CA
    08 Tundra CM 4x4. 21 Sequoia SR5 4wd
    Waiting on my TC shock hoops, RCV axles, front coilovers, secondaries and rear shocks. This wait is killing me.
    wv00097, Prostar 190, MTRock and 4 others like this.
  6. Aug 19, 2021 at 8:48 AM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    hahahahahaha . It will be all worth it :) I was with King last week tuning our suspension. One of their R&D guy told me that the shocks production is at full speed and that the springs is what causing their ridiculous lead time
  7. Aug 19, 2021 at 12:44 PM
    Retroboy1989
    Northern Utah
    Wow, thanks! I'll Google that.
    I turned the rotors on the Sienna when we bought it at around 30k miles and put the top shelf Autozone pads on (cmax golds?). I have nearly 70k on it now and the rotors look glazed and grooved. I'll do the tsb and powerstop pads/rotors - should be set.
    Back to the Tundra, I towed the travel trailer home today in much cooler conditions and had nice smooth braking. I also went over the same mountain pass with cold brakes where three days ago they were hot from arond town driving beforehand. No shudder. Seems to be heat related.
    I have 20" wheels with tires that are only an inch or so over stock. I'm not sure how to get the tundra any additional brake cooling. Wasn't there something about early backing plates being updated to allow more cooling? How do I make sure I have the newer ones? I have a late-year 2012.
    Edit: Just did the TSB removal of the excess air dam on thr sienna. Now, do I return the powestops and go with the revised Toyota brake pad?:confused: I guess it may come down to my rotors...they have already been turned once and have 70k, I'm guessing thickness is an issue.
  8. Aug 19, 2021 at 3:05 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    That's good to know. I'll just be over here counting days for the mean time. Hahah. How'd your tuning session go? And roughly what did it cost?
    vq35721[QUOTED] likes this.
  9. Aug 19, 2021 at 3:14 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    lol . It was brutally hot lol . I thought my sweat was gonna cause some flash flooding hahaha. It went well, guys from King Shocks are awesome… day and night difference on whoops and on dirt. Truck rides awesome on road too.. feels like I’m still aired down lol. They don’t charge, just a way of King to show their appeciation to their customers but, we ended up tipping them a couple hundies..
    TheBeast and Peeeheeuuu[QUOTED] like this.
  10. Aug 19, 2021 at 7:21 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    Awesome man. Is the SC on already?
  11. Aug 19, 2021 at 8:41 PM
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    It’s going down on the 30th lol
    TheBeast likes this.
  12. Aug 20, 2021 at 8:15 AM
    Retroboy1989
    Northern Utah
    Just putting this out there.
    The updated front brake backing plates look like this, the old versions do not have the three groups of venting holes.
    Confirmed that my '12 has the newer plates.
  13. Aug 21, 2021 at 1:52 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Finally pulled my driver side rear caliper today to rebuild. Having a time getting the piston out. It's 95% of the way there. Inside for a food break/regroup.
    I can definitely see why it was staying partially applied. Pure nastiness on the bottom side of the piston not allowing it to retract.
    joseph_womack likes this.
  14. Aug 21, 2021 at 2:50 PM
    Shanet421
    San Diego,CA
    Let’s see a few pics if you have time. I believe I am having the same issue with the rear passenger side caliper
  15. Aug 21, 2021 at 5:29 PM
    French Avocado
    Utah / Wyo
    UPDATE - I installed it. Two 10mm nuts and one wire harness (always the toughest part to determine which attachment methodology was used while standing on your head spinning nickels). Noticeable improvement in shifting in my opinion. It is obvious that this is not a simple mechanical part but has imbedded software.
    ACDC2ZZTop, WVI, chugs and 2 others like this.
  16. Aug 22, 2021 at 2:40 PM
    azimuth
    azimuth New Member
    2010 double cab SR5
    I'm installing my Boost Auto tow mirrors. They arrived on Friday. I bought the paint grade caps. Had them prepped and primed Friday night. Base and clear coated by 11:00p on Saturday night. Baked in the sun all day today while I installed the mirrors and wiring for the DRLs and the power folding. Waiting for some POR15 to dry on my driver side door stay right now. Don't know why but the pivoting anchor dealie developed some surface rust over the years so I dealt with it today too. Will get pics when I can close my door in a couple of hours.
    This is how the paint grade mirror caps come. These have been washed and scrubbed with scotch-brite. Ready to prime.
    Primed three coats catalyzed primer.
    Painted 3 coats base Pyrite Mica and 4 coats catalyzed clear. Didn't even have to cut and buff this time. :D
    Color matches perfectly.
    And now for some flagrant boasting photos...
    Pardon the glare. I had goo on my camera lens. It's probably transmission fluid residue....
  17. Aug 22, 2021 at 6:38 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Found some OEM tow mirrors for cheap.
    For those who ask, they add an extra 3" on each side (not extended).
    wv00097, Prostar 190, WVI and 6 others like this.
  18. Aug 22, 2021 at 10:28 PM
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    2008 Tundra Silver DC 4.7 4x4
    OEM 18" wheels off a 2.5 gen 275/70/18 Falken Rubitrek A/T FabFour Redsteel front bumper with HF winch. Dobinsons IMS with 2.25" coils (610) JBA UCA's Iron Man +300lb rear leaf packs with Dobinsons IMS shocks ECGS bushing in front diff Black Oak Led Flood Pods. 40watt (x2) Black Oak 20" light bar. 100 watt OEM style rear bumper, black powder coat, added aux reverse leds. Stubby AM/FM antenna Century Camper Shell with Roof rack and bed mat
    Chased down three sources of rattles.
    First I adjusted the stoppers for the inside of the grill. Just a bit of pressure while closed now. Next I fixed the loose upper isolation mounts for the A/C condenser by adding two grommets to take out some of the slop. Last I replaced missing fasteners for the plastic wheel well liners. Much quieter now. Then I washed her and got started on swapping the rear leafs.
  19. Aug 23, 2021 at 6:11 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    I went ahead and pulled the dust cover/seal off because I thought that's what was maybe not allowing the piston to come out. Hard to tell in the photo but it's cocked slightly. It won't come out for love or money. New caliper on the way.
    Mountun Goat, azimuth and D4x4TRD like this.
  20. Aug 23, 2021 at 6:19 AM
    Shanet421
    San Diego,CA
    Thanks for the update! I was thinking the same thing why battle when a new caliper is pretty inexpensive. Did you order a pair to get both done in the rear?
  21. Aug 23, 2021 at 6:30 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    It may be cocked a little, but it’s damn near out. It does look like it’s got a little build up on it. It’s always best to replace them in pairs. Usually if one is toast, the other isn’t far behind
  22. Aug 23, 2021 at 9:12 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Negatory, only replacing the one. If the other begins to seize/fail I'll gladly replace it but if it ain't broke....
    Punisher17 and MTRock like this.
  23. Aug 23, 2021 at 11:00 AM
    Wangofree
    Wangofree New Member
    Midwest
    07 Tundra Double Cab 5.7L
  24. Aug 23, 2021 at 11:01 AM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    Tundra got new shoes this morning. Falken wildpeak at3, 295 70 18. Couldn't stand the bfg ko2s any longer, the falkens are so smooth and quiet.
  25. Aug 23, 2021 at 11:03 AM
    Wangofree
    Midwest
    No better feeling than new tires. Look sharp!
    Retroboy1989 and 41bigdawg like this.
  26. Aug 23, 2021 at 4:51 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    Fogs anytime mod. Not sure why I didn’t do it sooner. I butchered the clips on the connectors to remove them though. Have to get them replaced (I think)
  27. Aug 23, 2021 at 9:41 PM
    Retroboy1989
    Northern Utah
    I did the same thing with the understanding that they only add an each per side. They are much bigger. o_O
    Luckily I also found a good local deal.
    Zebruaj[QUOTED] and MTRock like this.
  28. Aug 24, 2021 at 1:20 PM
    Ktate
    Ktate New Member
    2007 RCSB SR5 TRD 4x4
    B9B8D8DA-138A-4706-9E34-12626A351073.jpg Today was new SCS Ray 10 wheels (18x9) and BFG KO2 tires (305/65R18).
  29. Aug 24, 2021 at 2:14 PM
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
    Washed the beast this weekend, forgot how shiny the paint is cleaned
  30. Aug 24, 2021 at 2:48 PM
    Wangofree
    Midwest
    Changed the PCV valve. New one "rattles" this one not so much. All gummed up. It would be nice if this upped my MPG, but I won't hold my breath. :rolleyes:
