Front brakes
Discussion in '1st Gen Tundras (2000-2006)' started by robabeatle, May 28, 2021.
  1. Jun 4, 2021 at 4:39 PM
    Just clean up the fluid off any paint real well. No big deal though
  2. Jun 4, 2021 at 4:40 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Brake fluid overflowing out of the reservoir cap means it was topped off with worn brakes. Situation normal if that's the case. With the new brakes and the fluid at the full mark you shouldn't need to add any fluid unless there's a leak.
    Spongy pedal means you probably still have a little bit of air trapped in the system. Try bleeding it then activating the ABS with a good stomp or two on a gravel road, seems to do the trick for ABS equipped systems.
  3. Jun 4, 2021 at 4:44 PM
    robabeatle
    robabeatle [OP] New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Mama mia! Well can't do much about it now.
  4. Jun 4, 2021 at 4:45 PM
    robabeatle
    AZ
    The brakes were just bled about a week ago with pads that were used for about 10k miles. I'll see if things firm up after a quick ride...
  5. Jun 4, 2021 at 4:49 PM
    Lil Steve
    Gilbert, AZ
    Our trucks can be a pain to get bled properly. I'm sure you know this already, don't forget to bleed the LSPV out back.
    robabeatle[OP] likes this.
  6. Jun 4, 2021 at 4:59 PM
    robabeatle
    AZ
    Quick shake down starting with easy stops and then progressing to "spirited" stops. Brakes firmed up, not sure if they are quite as firm as before. Then onto a dirt road to stomp on the brakes: felt a rapid pulsing which I guess is the calipers closing and opening which indicates the abs is working I guess? After that slamming of the brakes, I had smoke coming out of the wheel well. I assume that is the fresh brake coating coming off and nothing to be concerned about?
    Overall brakes feel pretty good and maybe with a little time might bite harder.
  7. Jun 4, 2021 at 5:00 PM
    robabeatle
    AZ
    Actually I have never bled the brakes on this vehicle. When my timing belt was done about a week ago, I had the shop do it so I figure it was done pretty well.
  8. Jun 4, 2021 at 5:08 PM
    robabeatle
    AZ
    Thanks for the offer as always. I figured that this is an easy job and can't be messed up.
    haha I only get good at anything after I make every mistake possible.
    tdrich7 and FrenchToasty[QUOTED] like this.
  9. Jun 7, 2021 at 3:56 PM
    robabeatle
    AZ
    Update: Drove down the local mtn road today and zero pulsating. Now lets hope these rotors last more than 10K.
    bmf4069, Lil Steve, des2mtn and 2 others like this.
  10. Jun 7, 2021 at 4:17 PM
    What time were you up there? We went up at 830 and came down around 1030ish
  11. Jun 8, 2021 at 4:12 AM
    robabeatle
    AZ
    I got up there with my dog at about 6 am. Parked at Marshall Gulch and hiked to the Wilderness of rocks. Came back down around 10 am or so.
  12. Aug 13, 2021 at 5:33 PM
    Shedtundra
    Shedtundra New Member
    Spanish Fork, UT
    2012 Black Tundra Rock Warrior
    Alpharex Pro Headlights W/ Level Motor. LED GTR Ultra Series 2.0.
    Hey @robabeatle , just wanted to check in on how the Cryo’s are treating you? Have the breaks firmed up more since your last post? Appreciate the info you’ve provided. Having to replace my warped front rotors soon. Thanks!
  13. Aug 14, 2021 at 6:06 AM
    If you quote or tag people it'll give them a notification, making it easier for them to know they've been paged. Like this: @robabeatle.
    BubbaW likes this.
  14. Aug 14, 2021 at 1:25 PM
    Shedtundra
    Spanish Fork, UT
    Whoops, Thanks @bmf4069 I appreciate the help with that. I’ll go edit it now. Thanks again.
  15. Aug 18, 2021 at 4:16 AM
    robabeatle
    AZ
    They did firm up and provide great braking. No ragrets.
    Shedtundra[QUOTED] likes this.
  16. Aug 18, 2021 at 12:37 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I'm curious if it's worth it to get my calipers rebuilt? I like the reliability of OEM and worry about problems down the road with aftermarket. Am I wrong here?
  17. Aug 18, 2021 at 12:51 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    You can always rebuild them and clean them up, if you have the time to take to do that. Unless you do a BBK, Factory will always be better than aftermarket.
  18. Aug 18, 2021 at 12:51 PM
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    We'll the ones you get at the auto parts stores are rebuilt OEM calipers.
  19. Aug 18, 2021 at 12:52 PM
    They sell rebuild kits but I'm not sure how hard it is to do it yourself. Might be worth a try though.
  20. Aug 18, 2021 at 12:55 PM
    #50
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    I just bought Left and Right sides. I think they were $80 a piece. Not worth my time rebuilding them myself. And when your in the rust belt, a nice brand new coat of paint on the rebuilds has value.
  21. Aug 18, 2021 at 3:32 PM
    #51
    Strangebird22
    Strangebird22 New Member
    Terry
    Ohio
    2000 Tundra AC 4.7 4X4 SR5
    Hey rust can be good sometimes. To upgrade to the 13WL calipers I didn't have to trim my backing plates. Mother Nature took care of that for me along time ago:rofl::rofl::rofl:
