Dash Cluster going heywire
Discussion in '2nd Gen Tundras (2007-2013)' started by Jmurph, Aug 17, 2021.
  1. Aug 17, 2021 at 12:05 PM
    Jmurph
    Jmurph [OP] New Member
    08 Tundra Crewcab
    Just a question to see if anyone has experienced this? I have a 08 Tundra and I have noticed now about 3 times my dash cluster will go nuts. Speedo will go up and down as well at the tac. Lights flashing on and off (lights in the dash) The truck runs fine. When I turn it off and let it sit for few mins and turn it back on, all is normal. Any info would be appreciated.
  2. Aug 17, 2021 at 12:12 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    You definitely have a loose ground wire somewhere. Only explanation for multiple electrical items flickering. Check your negative battery cable from the battery to the frame. Next check every other ground wire you can find.
  3. Aug 17, 2021 at 12:24 PM
    Jmurph
    08 Tundra Crewcab
    Thanks will do.
  4. Aug 17, 2021 at 4:20 PM
    DVCNick
    DVCNick New Member
    2011 5.7 4x4 Double Cab
    Mine did the same thing when the original positive battery post clip literally broke in half not long ago (no idea how that happened) and it was just sitting there barely touching the positive battery terminal, probably arcing, the rest of the way home till I parked and found it.
