Engine Tick (replaced left manifold and still there)
Discussion in '2nd Gen Tundras (2007-2013)' started by 406Tundra, Aug 24, 2019.
  1. Jan 29, 2021 at 2:25 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    X2
  2. Jan 29, 2021 at 3:02 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    Back in the day a noise like that at startup was sometimes caused by piston slap. It would go away when the engine warmed up, and piston expanded, and took up the slop.
  3. Feb 3, 2021 at 2:58 PM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    My 2019 PRO 5.7 makes a ticking noise, sounds just like a lifter. Only time I can hear it is when I'm out of the truck, don't hear anything from inside unless the windows are down. Dealer says it's normal for that motor. I don't like it, but it is what it is.
  4. Aug 16, 2021 at 8:02 PM
    camillethetoy
    camillethetoy New Member
    jeremy
    08 DC 4x4
    2/1 Eibach Coilovers and 1" block
    I have developed same sound as the video, also from the driver's side. Can hear it with radio down and you give it some gas. This started after installing bypass kit.. Guessing I caused a leak breaking that seal huh?
    I'll throw some injector cleaner in there though, may as well try..
  5. Aug 17, 2021 at 6:25 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I’m not familiar with what’s pressurized but could it be one of your block off plates not being tight?
  6. Aug 17, 2021 at 8:38 AM
    camillethetoy
    jeremy
    08 DC 4x4
    I’m gonna get back on it, but the torque spec was pretty low from what I remember
    Filthyphil[QUOTED] likes this.
