  1. Aug 13, 2021 at 9:55 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    lol
    these are the correct u joints. Identical to the oem ones I pulled out. 2wd have different u joints than the 4x4s. I made sure to get the 4x4 joints
  2. Aug 13, 2021 at 9:55 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Thats what I used as well.
    Well if you Happen through Portland bring it with you and we can bend it. There are no shortage of people with Benders down there though thats for sure. I probably used half dozen peoples when I was in San Diego.
    FrenchToasty and Voss[QUOTED] like this.
  3. Aug 13, 2021 at 10:05 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    You got OEM U joints with the zerk fittings?
  4. Aug 13, 2021 at 10:07 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Appreciate it my dude. I loved Portland on my trip up the coast. Those food trucks, wow! I had the best time eating and drinking there lol.
  5. Aug 13, 2021 at 10:07 PM
    Siebler
    CJ
    Eastern Oregon
    Glad you liked it. Cant fucking wait to leave myself haha.
    oscardog86 and Voss[QUOTED] like this.
  6. Aug 13, 2021 at 10:12 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Yeah I don’t blame you. I didn’t want to say anything negative but we’ve all heard what’s going on there. It’s a shame. Such a cool place, lots of small businesses providing amazing food and beer. I’m glad I was there before things got out of hand.
  7. Aug 13, 2021 at 10:14 PM
    Siebler
    CJ
    Eastern Oregon
    I came here only for a job and now that weve grown and Covid, I can work remote and thats exactly as I intend to do haha.
    Portland was a great stepping stone out of Cali. Eastern OR is the plan now.
  8. Aug 13, 2021 at 10:17 PM
    empty_lord
    05 rollover special
    from spicer directly. but through a regional guy at toyota (aka off an assembly line, LOL)
    no vibs on take off leave me to believe u joints and angles arent the issue but the slip yoke slop might be. with the suspension compressed the slop all but goes away
    Voss[QUOTED] likes this.
  9. Aug 13, 2021 at 10:30 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Could be… but bad ujoints aren’t necessarily going to cause a vibration on take off. Even an out of balance driveshaft may not cause a vibration on takeoff. Did you get your shake after the work was done?
  10. Aug 13, 2021 at 10:32 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Oh so you left Cali for a worse version of Cali lol. I’m playn, have a friend in Oregon country side who’s homesteading. Loving life
    oscardog86 likes this.
  11. Aug 13, 2021 at 10:37 PM
    Siebler
    CJ
    Eastern Oregon
    When i left Portland was still OK but SD was getting Bad. My parents are native San Diegans even but I knew I couldnt stay at early age. Now Portland is horrible, i for the first time since moving really enjoyed SD when I went to mive my dad a few weeks ago (to Eastern OR as well) for first time since I left
  12. Aug 13, 2021 at 10:42 PM
    Voss
    Valod
    2003 AC TRD 4x4
    San Diego is probably the cleanest and well run big city in the entire state.
  13. Aug 13, 2021 at 10:43 PM
    Siebler
    CJ
    Eastern Oregon
    And being from East County it was even better. Crowds and costs and traffic though....
    To stay on topic of the thread.....Today I stripped my carpet. Tomorrow you will see why.
    bmf4069, des2mtn and Voss[QUOTED] like this.
  14. Aug 13, 2021 at 10:55 PM
    empty_lord
    05 rollover special
    After the lift. Which was after the u joints. Spaced the driveshaft to correct angles, no change. Next step is a driveline shop balance it. It’s a weird vibe though. It comes and goes if I’m at 70 consistently long enough
  15. Aug 13, 2021 at 11:08 PM
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    I was getting bad though inconsistent vibrations at highway speeds. I had a stuck caliper, vibrations was from the warped rotor.
  16. Aug 13, 2021 at 11:30 PM
    empty_lord
    05 rollover special
    brakes are fine. i do need to do the front diff bushing. but what im dealing with is a rear end vibe for sure.
  17. Aug 14, 2021 at 12:40 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Interesting stuff, keep us posted. Since the vibration happens at high speeds only, from what I’ve learned… it could possibly be a Ujoint(which are new so unlikely) and an out of balance driveshaft. If you haven’t balanced your driveshaft after changing out parts, could just be something as simple as getting it balanced. I tried lowering my center bearing to correct the angle and it didn’t help at all. My issue ended up being an out of balance driveshaft because my slip yoke wasn’t installed in the correct position after being removed for maintenance.
    After reading about your front diff bushings, it reminded me of a similar issue I had with my ‘63 Cadi. It would run smooth but once in a while I’d get a vibration. It turned out to be a differential bushing that was causing the vibration but my bad bushing was in the rear. Every now and then the bad bushing would slip and cause the differential and driveshaft to come out of alignment with the transmission and the smooth Cadi would start to vibrate. Once I replaced the bushing, she smoothly sailed the streets again.
  18. Aug 14, 2021 at 12:48 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Tonight i took the titan.
  19. Aug 14, 2021 at 2:02 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Erik and the Manglers
    Come down to North County and we can get drunk and I'll screw your truck up even more, maybe scratch it.
    bmf4069, Voss, daveeasa and 1 other person like this.
  20. Aug 14, 2021 at 2:11 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    North County? You in O-side
  21. Aug 14, 2021 at 2:18 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Is this what you mean ?
  22. Aug 14, 2021 at 2:19 AM
    des2mtn
    SW
    Tonto cover
    I live in redneck and casino land, that should give it up. Spent plenty of time as a delinquent teen in O-side though, good times. You're down here too?
    Darkness and RUSTYNUTS[QUOTED] like this.
  23. Aug 14, 2021 at 4:37 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  24. Aug 14, 2021 at 8:56 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    You sure your cap isn’t just old and worn out? Or can you see obvious separation on the top cap or something?
    tacoguybill[QUOTED] likes this.
  25. Aug 14, 2021 at 9:07 AM
    Siebler
    CJ
    Eastern Oregon
    Just gotta assume Valley Center
    RUSTYNUTS and des2mtn[QUOTED] like this.
  26. Aug 14, 2021 at 10:45 AM
    Siebler
    CJ
    Eastern Oregon
    Its about to go down. Warmin in the sun....
  27. Aug 14, 2021 at 12:03 PM
    tacoguybill
    tacoguybill The Burrito Bandido
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    It was just that ugly dark brown color, I did inspect the cap it didn’t look too rough. New radiator (denso) from Napa, had to drive to MD to get it so I could replace before the sun got too high today. New cap & thermostat as well. Planning to do fan clutch in the near future before pulling that tandem axle trailer to get my next project (09 Camry). While removing the radiator I moved a small bit of foam aside and found the crack. Buttoned everything back up and inspected trans fluid lines, everything looked a great red color. I’m hoping to do a drain and fill later this evening when it cools off a bit if the war department doesn’t give me the stink eye. Truck made it back home through bumper to bumper traffic for an hour and a half so I’ll call it good until new hoses and fan clutch arrive.
  28. Aug 14, 2021 at 12:09 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Exactly. If the arrows are pointing towards the outside... you definitely have adjustment available to even the cross camber and maybe even bump caster up to 2.6 degrees.
  29. Aug 14, 2021 at 12:13 PM
    daveeasa
    New? Source? Vinyl?
    Darkness likes this.
  30. Aug 14, 2021 at 12:59 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I'm coastal, just up past the titties.
