Conflicting research caused this thread to be created. 3" lift questions.
Discussion in 'Suspension' started by TucsonTundra1794, Jul 9, 2021.
  1. Aug 3, 2021 at 9:21 AM
    #151
    TucsonTundra1794
    TucsonTundra1794 [OP] ASCM #6-11 I'll buy if you're willing to ship
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    So my Pb could be over extended because they are for 1.5" of lift and the rear is 5.5" higher right now.
  2. Aug 3, 2021 at 9:52 AM
    #152
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Measure center wheel to fender, jack one side up on frame and see how much travel you got
  3. Aug 3, 2021 at 10:40 AM
    #153
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Will do
  4. Aug 3, 2021 at 10:57 AM
    #154
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
  5. Aug 8, 2021 at 7:36 AM
    #155
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Did you end up getting this sorted out??
    TucsonTundra1794[OP] likes this.
  6. Aug 8, 2021 at 10:19 AM
    #156
    TucsonTundra1794
    Anthony
    Tucson, AZ
    So after back and forth with the rep about how the shocks are not the same at all he finally decided to give in and order the right ones. Icon is saying 5 months for them to come in and I said that's fine and never brought up bringing my truck in to take these off. I think he knew I was going to raise hell If he would have told me I have to buy temporary shocks so they could have these back. We spoke on Wednesday so I was thinking about following up this week and confirm the new ones were ordered. When I spoke with icon they said I'm probably at the very top of the limit of these shocks and they are most likely working as limit straps with how extended they are and if I keep them I'll likely blow that top bushing. This may become my goal with how much shit these guys have put me through.
    BroTun13 and TRDFerguson like this.
  7. Aug 8, 2021 at 11:19 AM
    #157
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    put 20 bags of play sand on the bed
    TRDFerguson likes this.
  8. Aug 8, 2021 at 11:24 AM
    #158
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That’s not a bad idea to at least simulate your intended bed load that you’re shooting for in a few months.
  9. Aug 8, 2021 at 2:16 PM
    #159
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Yeah I actually told icon my rear was 5.5" higher right now and he said what the f did they do to your truck and I said they added the extra leaf at my request because I am going to add the decked system in sometime next year and he told me for better ride comfort I should add weight now or take the leaf out. Now sure which route I want to go, with the lift, dirty deeds exhaust, light bar from @Squatting Pigeon, this site has drained my resources in more ways then one.
  10. Aug 8, 2021 at 2:20 PM
    #160
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The sand bags would be a cheap and easy fix. Removing the leaf is doable with normal tools but will probably take a couple hours.
  11. Aug 8, 2021 at 2:20 PM
    #161
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Luckily bags of sand are cheap :anonymous:
  12. Aug 8, 2021 at 2:56 PM
    #162
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I'll probably go the sand bag route. I was curious what my mpg would bump down to with the extra weight in the back so with sand bags I can test that out. If I drop to 10 I may consider keeping the tools in the packout boxes and using the 4runner for work mostly. I know I'll get a bump when I move to 37's and I really want to keep the mpg in double digits.
  13. Aug 8, 2021 at 4:27 PM
    #163
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    my rig isn't lifted, but I carry all my tools, I still get 15mpg and 13 with hella traffic
  14. Aug 8, 2021 at 4:35 PM
    #164
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    I'm on 35s and with 4 people and a bed of camping gear I still average 15 highway.
  15. Aug 8, 2021 at 4:51 PM
    #165
    TucsonTundra1794
    Anthony
    Tucson, AZ
    My average was 14.5 before the lift. Only put 1 tank through since the lift and it only dropped to 14. Hoping I can hit 12.5 with lift and weight but you guys got me thinking I can keep at 14.
  16. Aug 8, 2021 at 5:01 PM
    #166
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    It’s the initial off line that eat gas, once it’s rolling it’s all good
  17. Aug 8, 2021 at 5:05 PM
    #167
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Just gotta regear and add a supercharger, then you’ll be fine…
  18. Aug 8, 2021 at 5:19 PM
    #168
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Regear probably way down the line. Supercharger never gonna happen. I speed enough as it is. I've got roads dedicated to me because of how much money I've spent on speeding tickets.
    TRDFerguson[QUOTED] likes this.
  19. Aug 9, 2021 at 8:28 PM
    #169
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Figured I'd drop this in here before making a new post. I know the 2 options for aftermarket sway bars are the TRD one and the hellwig one. I know I can make the TRD fit with longer end links for my huge lift in the back and I know hellwig comes with the longer end links already. My question is what is the difference between these 2 options? Both larger then stock but what makes hellwig twice the price? Looking to get new front and rear sway bars so just trying to do research. Thanks guys.
    SC_TRD likes this.
  20. Aug 9, 2021 at 8:33 PM
    #170
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    @azTony had (still has?) the Hellwig rear I think. Might have some input.
  21. Aug 9, 2021 at 8:52 PM
    #171
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  22. Aug 9, 2021 at 9:03 PM
    #172
    TucsonTundra1794
    Anthony
    Tucson, AZ
  23. Aug 9, 2021 at 9:17 PM
    #173
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I think the hellwig is adjustable
  24. Aug 9, 2021 at 9:35 PM
    #174
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Adjustable in what way? Not meaning to sound rude, I literally have no idea, I know I'll need longer end links but I thought that was the only adjustment that needed to be made.
  25. Aug 10, 2021 at 12:02 AM
    #175
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    their sway bar rate is adjustable
    closer holes stiffer, holes on end softer
  26. Aug 10, 2021 at 12:05 AM
    #176
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  27. Aug 10, 2021 at 5:26 AM
    #177
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Interesting, then it looks like hellwig is the way to go then.
  28. Aug 10, 2021 at 7:54 PM
    #178
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It looks like he hasn’t been online here in a while so I shot him a text. He lives a mile down the road from me, so we can probably coordinate a pick up if needed.
  29. Aug 10, 2021 at 7:58 PM
    #179
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Hell yeah!
  30. Aug 10, 2021 at 8:02 PM
    #180
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    What makes you want to add in the rear sway bar and beef up the front? Most people that start building a rig as capable as yours take them out to get the most flex out of your suspension. Had one in the rear for a bit when I was driving 70 miles a day across windy mountain roads, but removed it once I added the RXT leaf springs. You will never be able to utilize that leaf pack or your front coilovers with sway bars on your truck.. just my 2 cents and want to make sure you thought about the impact before adding these to your truck.
    I now drive with no sway bars and it takes some getting used to, but the amount of travel it enables is unreal.
    EDIT: RXT full droop with no sway bars, cause I turtled :rofl:
    HighDesertSurfer likes this.
