03 Sequoia roaring noise when accelerating
Discussion in 'Sequoia 1st Gen (2001-2007)' started by shhernandez74, Jun 25, 2021.
  1. Jun 25, 2021 at 8:32 PM
    shhernandez74
    shhernandez74 [OP] New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    I just bought an 03 sequoia and it started doing something funny today.
    The best way I can describe the noise is it roars when accelerating. Similar to the roar noise trucks due when you first turn them on in the morning and take off. It only happens after it’s been on for a while. I will come to a light and when I take off it sounds like it’s sucking in a ton of air (roaring) and and it will bump into 2nd gear.
    it doesn’t do it on Initial start up only does it once it’s been running for a while. When I first turn it on it runs and shifts fine.
    Any ideas? I was thinking maybe the clutch on the fan is going bad. Any way to test it? Thanks in advance for any help.
    Toyoda Tundra and 15whtrd like this.
  2. Jun 25, 2021 at 8:51 PM
    15whtrd
    15whtrd Mr. Blonde
    What’s the temperature like when this happens? That’s your clutch fan kicking in, or at least that’s what it sounds like to me. They will come on thermostatically. So you could either have a cooling issue or an issue with the fan itself staying engaged.
  3. Jun 25, 2021 at 8:52 PM
    15whtrd
    15whtrd Mr. Blonde
    Does the fan spin freely when the truck is off?
    shhernandez74[OP] likes this.
  4. Jun 25, 2021 at 8:53 PM
    shhernandez74
    Samuel
    i tried it earlier and it has resistance. It does not spin freely
    15whtrd[QUOTED] likes this.
  5. Jun 25, 2021 at 8:53 PM
    shhernandez74
    Samuel
    Temperature stays pretty constant ( middle) I have been keeping an eye on that
  6. Jun 25, 2021 at 9:05 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m definitely not a master technician, but I would be leaning towards the clutch fan being bad. At least it’s a fail safe and still spins, keeping the engine cool.
    And of course, I have to ask, when was the last time the timing belt was changed?
  7. Jun 26, 2021 at 2:45 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Does it sound similar to this ? https://youtu.be/G1R3CE0agMI
    des2mtn likes this.
  8. Jun 26, 2021 at 8:32 PM
    shhernandez74
    Samuel
    i honestly have no idea, the person I bought it from said she never did it so I doubt it’s ever been done
  9. Jun 26, 2021 at 8:32 PM
    shhernandez74
    Samuel
  10. Jun 26, 2021 at 8:40 PM
    Toyoda Tundra
    It could also be your radiator fan bracket so just keep that in mind. If you replace your fan clutch and still does the same thing, then is probably your radiator fan bracket. Also make sure your cooling system is working properly, an engine that runs hot can cause your symptoms as well.
  11. Jun 26, 2021 at 9:17 PM
    15whtrd
    15whtrd Mr. Blonde
    The reason I ask is because maybe it’s just time to do all of it. Water pump, fan, timing belt, The works. Give it a, for sure new lease on life and it should treat you well.
  12. Jun 26, 2021 at 9:26 PM
    shhernandez74
    Samuel
    Makes sense, thanks for the information! Ive been keeping an eye on the temp gauges and it hasn’t overheated
  13. Jun 26, 2021 at 9:46 PM
    Toyoda Tundra
    No problem. Please keep us posted, I’d like to know if the fan clutch fixes your issue if you decide to do it.
  14. Jun 26, 2021 at 9:49 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The sequoias have a condensor fan on them too. You may have an issue with that little guy too… albeit rare.
    shhernandez74[OP] and 15whtrd like this.
  15. Jun 26, 2021 at 10:34 PM
    shhernandez74
    Samuel
    Definitely! This may be something out of my league though
  16. Jun 26, 2021 at 10:54 PM
    Toyoda Tundra
    Make sure to use OEM parts if you can.
  17. Jul 16, 2021 at 4:33 AM
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
    shhernandez74[OP] and Tundra2 like this.
  18. Jul 16, 2021 at 7:44 PM
    Toyoda Tundra
    Does your truck sound similar to the video?
  19. Jul 17, 2021 at 3:47 AM
    des2mtn
    Tonto cover
    Not all the time, but enough for me to be curious about it. Most of the time the truck is fine. I get that sound in the video you shared and the same symptoms OP posted.
    I'm due for a complete cooling system job (radiator, thermostat etc) and am leaning towards replacing the fan clutch too.
  20. Jul 17, 2021 at 10:22 AM
    Toyoda Tundra
    Aisin makes the OEM fan clutch for our trucks ( if you decide to go with it) let us know if that fixes your issue.
  21. Jul 28, 2021 at 9:32 AM
    shhernandez74
    Samuel
    Surprisingly the noise went away on its on lol. I've been driving it around for a few weeks and the sound never came back. I verified that the fan still operates and also I have been checking the temp to make sure it doesnt get hot.
    It did sound similar to the video but the sound went away.
  22. Jul 28, 2021 at 3:29 PM
    Toyoda Tundra
    That’s good to hear!
    des2mtn likes this.
