Tires possibly too large? 1st gen Tundra
Discussion in 'Wheels & Tires' started by sbahne, Apr 29, 2017.
  1. Apr 29, 2017 at 11:46 AM
    sbahne
    sbahne [OP] New Member
    2002 Toyota Tundra V8 SR5 extra cab
    I just recently bought a 02 stock Tundra SR5 V8 extended cab. It came with 265/65/R17 wheels and tires. I just bought some used 265/70/R17 AT tires and put them on. I feel they are really close to the front axle arm, almost touching. After seeing this I put one of the old tires back on for reference and the spacing is almost the same. Are these new tires to big? Is this something I should worry about? Is there an easy fix? I drove with the new tires around the block and don't think there was rubbing. Attached is a photo of front axle with new tire. Thanks!
  2. Apr 29, 2017 at 11:51 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    There's nothing to worry about. I have the same spacing and it's never rubbed.
  3. Apr 29, 2017 at 11:52 AM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Doesn't seem like they should be to big. Stock on the 1st gen is 265/65/16. If they are not rubbing you should be good to go. I put 275/70/17 on my 1st gen on 14 Tacoma wheels. I had to put wheel spacers on to clear the ucas.
  4. Apr 29, 2017 at 3:50 PM
    sbahne
    Thank you!
