Lift
Discussion in 'Suspension' started by FDawg32, May 29, 2020.
  1. May 29, 2020 at 3:47 AM
    FDawg32
    FDawg32 [OP] New Member
    2020 Covid TRD Tundra
    Sorry guys newbie here.....
    Just bought a 2020. Id like to put a Ready Lift leveling kit on it. However after reading everything from TSS issues to level kits cause long term damage. Im not sure about adding this kit! Truck has 275/65/18 tires. I was going to add 285/70/18 tires to the lift as well. Any suggestions?
  2. May 29, 2020 at 4:06 AM
    GhostF8CEkill3r
    GhostF8CEkill3r Darth Tundra
    JSUN
    Conroe, Texas
    2023 Black Tundra Platinum Hybrid
    3" Front, 1" Rear - (Leveled) on 35" x 12.50"R20 Toyo ATIII w/1" wheel spacers.
  3. May 29, 2020 at 4:08 AM
    GhostF8CEkill3r
    JSUN
    Conroe, Texas
  4. May 29, 2020 at 4:13 AM
    Some of the guys will chime in on TSS, but as far as lift, do it right the first time. I had a Readylift 3/2 for about a year and a half. It rode pretty rough. Dont offroad with spacers either. I switched to Toytecs and it's a night and day difference. Here is mine with the Toytecs and 285/70/18's on a 0 offset.
  5. Jul 22, 2021 at 1:57 PM
    CrewMax NC
    CrewMax NC New Member
    RB
    2015 Tundra Limited CrewMax
    2.5” Lift with Firestone Airbags and onboard air suspension system.
    My 2015 has been equipped with Firestone airbags with inflation valves and an Airlift 72000 onboard compressor system. The bags are awesome and been so for 3 years. That said in my opinion avoid the Airlift system as it continues to be a pain. Been installed for less than 2 years and several Issues from communication errors to most recently a module failed causing pump to run to max pressure on one side only Regardless of the setting. Airlift had to hire additional call technicians just to keep up with the calls. In my opinion keep it simple go with an analog set up with Controls for each bag.
