Oil Capacity with the 5.7 V8
Discussion in '2.5 Gen Tundras (2014-2021)' started by erm626, Apr 18, 2015.
  1. Feb 20, 2016 at 11:40 AM
    Aurora CO
    Just got back from Grease Monkey. 7.4qts of Mobil 1 0W-20. 7.4qts appears to be what my truck likes.
  2. Feb 20, 2016 at 1:08 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    I think it's funny how they differ. Mine is 8.5 quarts every time I change it.
    LKROOZR likes this.
  3. Feb 20, 2016 at 6:12 PM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    My 2011 5.7 takes 8.5 quarts of 0w-20 with a new filter to show properly on the dipstick. kinda glad to hear I'm not the only one!
    LKROOZR likes this.
  4. Dec 11, 2016 at 1:50 PM
    FumundaTundra
    FumundaTundra Director of civil unrest
    Wayne
    Central WA.
    2009 5.7 Tundra Double cab
    Many to come.
    I've an '09 and I just put 7.5 quarts in it and it was at the bottom mark on the dipstick. I put the other 1/2 quart in to make eight. I'll see where it is. More than likely, 8.5 is where I'll be. This is with a filter change, which btw is a pita! I was surprised at how easily the skid plate went back on though.
    LKROOZR likes this.
  5. Dec 11, 2016 at 1:56 PM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Do I hear 9?? :rofl:
  6. Dec 31, 2016 at 1:31 PM
    BLACKbute13
    BLACKbute13 New Member
    Anthony
    Rock Worrior
    YES , My 2013 5.7 Rock Warrior did take 8.5 QUARTS MOBIL 1 0W-20
    I did let it drip out for 35 - 40 minutes
    Guys you really don't have to WRENCH( tighten ) TO much on the Drain Plug & the Filter Holder just snug it up ?
    I figure if it leaks I can always Cinch it up a little more.
    I made it tight but some guys over tight every thing.... Its like holy crap.
    CALM DOWN ... its not going anywhere..
    great Message board love it , A lot of info here.
    4x4_Angel likes this.
  7. Apr 21, 2017 at 5:32 PM
    Powskier
    Powskier New Member
    Nathan
    2021 Tundra TRD Pro
    Auto Air bags, 5th wheel trailer receiver
    2011 Tundra 5.7 Limited -- 8 qts puts it spot on the top dip stick mark after 3 minutes run time.
    I've changed my oil filter every 5k miles for 100k miles now and the filter replace just gets old every time. (See photo) Oil up to your elbow... all over your tools.... really? The Tundra is as bad as any. The filter center drain plug was a good idea that wasn't tested and just doesn't work. (lol)
    I design rockets for NASA for a living. Oil changes aren't rocket science. Automotive engineers, I'm calling you out...YOU CAN DO BETTER. (Lol)
    Changing your oil should be as easy as changing a printer cartridge.
    equin, aperezsh, Black Wolf and 2 others like this.
  8. Apr 28, 2017 at 9:56 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    7.9 is what I change out every time with my oil and filter. Usually run Valvoline 0w-20 get the with a Mobil one filter.......... hehehe
  9. Apr 28, 2017 at 11:08 AM
    10forty2
    10forty2 New Member
    Doug
    NC
    2017 Tundra TRD-4x4 XSP-X
    Look at it this way..... your tools will NEVER rust!!
    Mr Swervlin likes this.
  10. Sep 18, 2017 at 8:46 PM
    Ricky79
    Ricky79 New Member
    Ricky
    2010 Tundra 5.7
    Mine 5.7 took 8.5 qts
    Bigkitchens and LKROOZR like this.
  11. Sep 19, 2017 at 5:08 AM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    My 2016 took 8 1/2 also .. I completely drained it.. with the filter change.
    LKROOZR likes this.
  12. Sep 19, 2017 at 5:28 AM
    7.9 quarts is what vehicle manual Haynes manual says and I spoke with several Toyota dealerships said
  13. Sep 26, 2017 at 7:05 PM
    Berettafan
    Berettafan New Member
    2017 CM
    mine just took 8. I wonder if a hotter engine drains more thoroughly and thus takes more oil. mine was quite warm this last oil change and that stuff poured out crazy fast. made a huge mess.
  14. Oct 31, 2017 at 1:09 AM
    gefletcher52
    gefletcher52 New Member
    Gary
    2011 Tundra Warrior with extras
    Air suspension, rear.
    Here's my two cents here on this oil capacity for the 5.7...or at least the 2011 Warrior that I bought three weeks ago. I changed oil and the filter...book says 7.9 qts of oil. Dropped in the 8 qts and ran the engine for a few minutes and waited an hour or so.The dipstick was right at the upper hole on the dipstick after the hour. ...Drove the truck for three days up and down the freeway and around town. While filling up the windshield wiper container shortly there after I thought I'd check the oil level. It was hitting the bottom hole on the dipstick....added 1.5 qt of oil, ran it for a few minutes checked it again. Brought the level up to the upper hole....been there ever since. But my oil change with filter and engine oil cooler was close to 9.5 qts.......I had to buy 2 more qts of oil. So,... why wouldn't the owners manual or the service department have this information?
  15. Oct 31, 2017 at 2:43 AM
    Mine also takes 8.5.
    LKROOZR likes this.
  16. Oct 31, 2017 at 3:17 AM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    I know the tundra w tow package comes with a Transmission cooler. But I didn't know it came w an OIL COOLER. Is that correct, oil cooler? Thanks
  17. Jan 27, 2018 at 5:52 AM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    where do you get Toyota filters ,other than the dealer
  18. Jan 27, 2018 at 10:37 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I buy Amsoil Signature Series 5W30 in Gallon Jugs and dump two of 'em in my 2010 DC, with Toyota's TRD Filter.
    netranger6 likes this.
  19. Jan 27, 2018 at 11:42 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    From what I understand, Tundra oil capacity changed in 2010 (7.9 qt with filter and 7.5 without) and pretty much remained the same.
    2007, 2008, 2009 models take 7.5 quarts.
  20. Jan 27, 2018 at 11:55 AM
    #50
    15whtrd
    15whtrd Mr. Blonde
    Sorry but I think you overdid it. There is a process how you’re supposed to check oil. If I remember correctly it’s something like let it warm up for five minutes and sit for three minutes then check oil. I don’t see how you can fit another 1.5 quarts.
    Black Wolf likes this.
  21. Jan 27, 2018 at 11:59 AM
    #51
    Aurora CO
    9.5 is a bit much...[​IMG]
    Beep88 and 15whtrd[QUOTED] like this.
  22. Jan 27, 2018 at 12:33 PM
    #52
    15whtrd
    15whtrd Mr. Blonde
    Shit you not! My neighbor needed some help with his Honda Civic. He’s a young kid and he asked me to help him check the oil. He opened the filler and said look it’s not full.
    I thought he was kidding but he wasn’t. He thought the engine should be full to the top with oil. Holy shit! I promptly schooled him.
  23. Jan 27, 2018 at 1:41 PM
    #53
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    So here's another thought on the issue/question of 7.9, 8.0, 8.5..........
    The 0W-20 oil is a SUPER lite oil. Obviously it's best for the bigger engine, but it's commonplace that after running a few days following an oil change that the level will drop slightly. Older/higher mileage engines may experience this more.
    It can be consumption (friction/breakdown), seals, etc. Extreme weather conditions/fluctuations (when the engine's not running) all play an effect as well, albeit slight.
    The best solution I know of....
    6.9 qt (call it 7 even if you want): Mobil 1, 0W-20
    AND
    1.0 qt - Lucas Oil, Full Synthetic Oil Stabilzer
  24. Jan 27, 2018 at 1:58 PM
    #54
    Aurora CO
    I add MotorKote.:thumbsup:
  25. Jan 27, 2018 at 2:32 PM
    #55
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Never used MotorKote. I think I've heard some folks talk about using that in big trucks...rigs, dumptrucks.
    I've always used Lucas Oil. I know some ninjas in the sandbox that run Lucas Oil in their stuff. Good enough for them=good for me! :thumbsup:
  26. Jan 27, 2018 at 3:31 PM
    #56
    Aurora CO
    I use Lucas Upper Cylinder Treatment religiously. MotorKote is widely used in racing engines. The best true anti friction agent. You can pour it into the crankcase. Will not displace oil volume unlike bullshit Slick 50 snake oil.
    GAknight[QUOTED] likes this.
  27. Jan 27, 2018 at 3:38 PM
    #57
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Good info.
    Pbed85 likes this.
  28. Jan 27, 2018 at 3:48 PM
    #58
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    I'e always been right at 8 quarts. But. That' with amsoil and their filter.
    15whtrd likes this.
  29. Jan 27, 2018 at 3:52 PM
    #59
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    I thought that all the replacement oil filters came with a little plastic tube that you push into the center. That's what I've always used it to do, not a random socket or adapter.
  30. Jan 28, 2018 at 6:24 PM
    #60
    15whtrd
    15whtrd Mr. Blonde
    They do. It just doesn’t get everything out. And what does come out comes out very slowly.
