Gen 1: Transmission drain/fill is 2.1 qts, or up to 3.2 qts, depending??
Discussion in '1st Gen Tundras (2000-2006)' started by ToyotaJim, Jun 21, 2021.
  1. Jun 23, 2021 at 11:37 AM
    ToyotaJim
    ToyotaJim [OP] New Member
    More clarity, I did a nice long drive getting it hot, with the plan to check it afterwards. Then out of nowhere a sudden rainstorm started. I had just seconds to check it, and only once. It was reading just above the 2nd/top "cold" v-notch. I wish I could have rechecked it several times. So that is the plan to repeat. But in that inch or so between the "cold" and "hot" v-notches, how much fluid does that represent? So I know how much I need to add if I am too low? Is that a 1/2 qt, a full qt?
    (By comparison for motor oil that hashmark area usually represents a qt.)
    For something this important the manuals and such are just woefully lacking in information. There's not even a dipstick explanation in the manual!
  2. Jun 23, 2021 at 11:39 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Best thing I can say is it isn’t much. I don’t have your exact answer. You’ll figure it out. Just follow the advice already given and it will all make sense once you work through the Mojo.
    ToyotaJim[OP] likes this.
  3. Jun 23, 2021 at 11:47 AM
    If you feel you need to add, add a little at a time. heck the dipstick after adding and after driving to warm the fluid up. If you need some more, add a little more. Hard to take a little out if you add too much. Easier to add a little more if needed.
  4. Jun 23, 2021 at 11:59 AM
    ToyotaJim
    Thanks for all the advice. Going to go thru the process again soon, from soup to nuts and another spill and fill once I get the precise level hot confirmed. I'm wondering if the reason I only got out a bit over 2 qts is perhaps it was low to start with; second guessing my initial readings now.
  5. Jul 19, 2021 at 2:22 AM
    ToyotaJim
    Multiple changes in 2 tundras 2000 and 2002. Parking slightly elevated front.
    Consistently getting about 4.2 qts drained.
    Refills same amount. Perfect reading on dipstick when hot.
    @professionalhandmodel
    @Professional Hand Model
    Where are you?
  6. Jul 19, 2021 at 12:42 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Either way, as long as the dipstick reads good on level ground you'll be fine.
    He has been banned from the forum.
  7. Jul 19, 2021 at 12:48 PM
    ToyotaJim
    Why?? He's been one of the most helpful knowledgeable members!!!
  8. Jul 19, 2021 at 12:54 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Mods say he violated the forum rules with political post(s). :notsure:
