Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Jul 18, 2021 at 11:34 AM
    #2521
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    GRID OFF-ROAD WHEELS GD04
    20X9.0
    GLOSS GRAPHITE / MILLED
    0 offset
    Nitto Ridge Grippler 35x12.5
    BMC
    no rubbing
    Camburg UCAs pushed to max caster
    Decided to buck the trend and go with an old school 5 spoke with a new school touch.
    D4x4TRD and Blown284 like this.
  2. Jul 18, 2021 at 3:24 PM
    #2522
    SrgJigPog
    SrgJigPog New Member
    '19 Tundra TRD Off-Road
    Yup here you go!
  3. Jul 19, 2021 at 9:37 AM
    #2523
    Maggy4x4
    Maggy4x4 N+1 mods
    Washington
    2008 SR5 Tundra
    35s on methods Icon lift 46 gal fuel tank
    Yep, they’re 110.5 bore
    And here’s some bonus pics with the lift I added a couple weeks ago. Icon 2.5 CDCV RR front, 2.5 non CDCV (not in stock) RR RXT rear with RXT option 2 leaf pack. Didn’t measure before/after but did about 3/3 and 3/2 loaded up
  4. Jul 27, 2021 at 9:11 PM
    #2524
    Sasuke
    Sasuke New Member
    1794 with mods
    Baer rotors and pads - Baer rear rotors defective. Weld spots. Threw in trash.
    Fox TRD shocks. Gave it a leveling.
    Land Cruiser Heritage - 285/65/18 KO2s
    No spacers or anything needed.
    KN air filter
    Optima red top battery
    Run 92oct
    14.6mpg
    1P7R9O4, D4x4TRD, equin and 2 others like this.
  5. Jul 28, 2021 at 5:46 AM
    #2525
    ThompTundra14
    ThompTundra14 New Member
    Shane
    2015 Tundra Crewmax
    2015 CrewMax TRD package
    Levelling kit
    18” Fuel Vector 20mm offset
    305 65 R18 Falken Wildpeaks
    minor rubbing at full crank on both sides while going in reverse
    a_double, thedonn, FishFlash and 6 others like this.
  6. Jul 29, 2021 at 3:34 PM
    #2526
    COTundra23
    COTundra23 New Member
    OME 2.5" all around
    Icon RXT leafs
    285/75/18
  7. Jul 30, 2021 at 2:02 PM
    #2527
    mstrchief
    mstrchief New Member
    Is this completely leveled from the side with this kit?
  8. Jul 30, 2021 at 2:05 PM
    #2528
    3.slow 4life
    3.slow 4life New Member
    Lodi, CA
    2000 4x4 Tundra TRD
    2.5” rough country lift, rough country rims, used 285 75 r16 BFG KO’s. Electric cutouts, flowmaster.
    DB9FF11D-B4C1-422C-BFE1-802BDBB01065.jpg B9E5B057-7191-4F4A-8A73-F795761131A6.jpg I’m running a $125 set of 285 75 r16 BFG KO’s on rough country steal rims because I’m too cheap to get the pro com steel rims and white letter KO2’s. That’s the worst part about load range e KO’s, no white letters…
    D4x4TRD and equin like this.
  9. Aug 2, 2021 at 2:16 PM
    #2529
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Update from a couple years ago. Now running 315/70/17 (not a true 35” - roughly 34.4” x 12”) BFG AT/KO2s on the same Icon Rebounds. No BMC needed, but I removed the mud flaps and plastic bumper pieces. Still running Bilstein 6112s on the 1.9” setting.
  10. Aug 2, 2021 at 2:43 PM
    #2530
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Vision Manx398 17x8.5" -15ET cast bead lock rims.
    35x10.0R17 Super Swamper TSL/SXII tires. Pizza Cutters.
    Front: 3" spacer lift, stock springs. Have aftermarket bumper and winch.
    Rear: Roadmaster Active Suspension set with dime width and Fox 2.0 shocks.
  11. Aug 3, 2021 at 2:32 PM
    #2531
    tonynw318
    tonynw318 New Member
    Tony
    Oregon coast
    2020 silver sky SR5 crewmax
    I know this post is from a long time back, but what's the offset on your wheels? I have Method mr305's with a +25. I've been looking at the Yokohama Geolandar MTs in the same size of 285/65r18. possibly adding the Bilstein 6112s up front at the 1.3 or 1.9 setting.
  12. Aug 6, 2021 at 4:07 PM
    #2532
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    I'm looking at the same wheels. How much sticks out past the fenders ?
  13. Aug 6, 2021 at 4:28 PM
    #2533
    Tundra694
    AJ
    So I believe I have the +18 offset Method Grids but they could be the 0's so I'm going to pull one this weekend and see what its stamped. Help me understand the offset math. I'm looking to move the wheel more towards the fender well to avoid the flying rocks against the body
    If I go from a Method 0 offset 18x9 to a +25 Icon 18x9 wheel than it should suck into the fenderwell 25mm from where it is with the 0's right ?
    If I go from a Method +18 offset 18x9 to a +25 Icon 18x9 wheel than it should suck into the fenderwell 7mm from where it is with the 18s right ?
  14. Aug 10, 2021 at 8:14 PM
    #2534
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    correct…although I’m not sure you’d see much difference with 7mm inward (~.25”; if you have a 0 offset and go to a +25 it will be ~1” further in)…stock tundra wheels are a +60mm and will be inside the fender…I had 20x9 Toyota TSS wheels with a +50mm and they were even with the wheel well/fender with 35x11.5 tires.
    tiresize.com is a good place to compare/calculate tire size and offsets…it lets you calculate and compare side by side and shows visual measurements
    customoffsets.com has lots of customer pics with various wheel manufacturers/sizes/offsets if you want to see how they look
  15. Aug 10, 2021 at 8:49 PM
    #2535
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    Anyone know of a Tundra with some 315 Machined Methods on it? Im trying to go that look with my 2010 Platinum to see how the wheels match with the front and rear chrome bumper.
    My ideal picture would be a 3" front lift with a 3/4"-1.5" rear lift, 2020 sequoia grille, some LED headlights and then the 315 Machined Method wheels
    (17" with 0 offset) on either 305s or 35/12.5s tires.
  16. Aug 11, 2021 at 3:30 AM
    #2536
    Tundra694
    AJ
    Awesome thank you that does help visualize things
  17. Aug 11, 2021 at 3:31 AM
    #2537
    Tundra694
    AJ
  18. Aug 11, 2021 at 8:39 AM
    #2538
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
  19. Aug 11, 2021 at 11:05 AM
    #2539
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
  20. Aug 11, 2021 at 11:10 AM
    #2540
    Tundra694
    AJ
    How much do these poke out past the fenders ?
  21. Aug 11, 2021 at 12:09 PM
    #2541
    Tundra694
    AJ
    LB-Tundra6 and Rippyro like this.
  22. Aug 11, 2021 at 12:19 PM
    #2542
    Rippyro
    Rippyro New Member
    2014 Tundra 1794 - Sunset Mica Bronze
    Classic style there. Gotta have some meaty looking tires with that style wheel IMO. I had a similar style American Racing wheel (ar172 I believe) in 17s on an 05 red Silverado until the tire shop overtorqued one of the lugs and wallered out one of the holes. They looked good.
  23. Aug 11, 2021 at 12:20 PM
    #2543
    Tundra694
    AJ
    Yea I have the Falken wild peak 275/70r18.
    Rippyro[QUOTED] likes this.
  24. Aug 11, 2021 at 2:14 PM
    #2544
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    likely about an inch…those are icon rebounds with a +25 offset. Those were my #2 option when I was looking for new wheels
  25. Aug 15, 2021 at 4:25 AM
    #2545
    TygerTundra
    TygerTundra New Member
    '07 Limited DC
    late update, but I contacted a distributor awhile back to see about getting replacement caps. Ended up getting the correct size caps, but they had the iron cross on them again.... After taking a closer look I realized the cross was a separate piece, so I just popped them all off and replaced them with some vinyl stickers. My wheels are custom now, lol
    WVI and Vr0ck[QUOTED] like this.
  26. Aug 15, 2021 at 6:13 AM
    #2546
    Brettstation37
    Brettstation37 New Member
    Brett
    Catskills NY
    2020 Tundra CrewMax TRD Sport
    Wanna buy wheels and after all the reading and looking I’m just confusing myself worse then when I started… I have a rough country 3/1 level and 275/65/20 General Grabber ATx tire…I want to keep my tires and keep looking at fuel wheels…offset… I would like to just poke out of the fenders…what offset do I need so that I won’t run into troubles? 20x9 +20 should be perfect correct??
  27. Aug 15, 2021 at 8:34 AM
    #2547
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched metallic grey front and rear bumpershellz Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    Yes the +20 will have a slight poke. I am running the Fuel Vector 20x9 + 20 with 35x11 .50 Nitto tires..
  28. Aug 15, 2021 at 11:52 AM
    #2548
    Brettstation37
    Brett
    Catskills NY
    what are you running for lift? I have 3/1 rough country level and am going to be keeping my same tire size so it should be same, just wanna make sure the +20 isn’t going to have me rubbing?
  29. Aug 15, 2021 at 12:17 PM
    #2549
    YotaTruckLtd
    2014 MGM Limited CM
    I am running Bilstein 6112s on top setting 1 shim DS and 5160s in rear with Boss 4x4 shackles set at 1.5". No rub anywhere at any any time just removed front mud flaps.
    LB-Tundra6 likes this.
  30. Aug 15, 2021 at 12:56 PM
    #2550
    Brettstation37
    Brett
    Catskills NY
    So again my rough country 3/1 lift level with 275/65/20 on a fuel wheel +20 won’t rub? I do have the front bs flaps removed already
