  1. Jul 17, 2021 at 3:34 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    lol no. Did that once. I’ll get this media blasted. I may hit it a bit with a wire wheel just to knock off some loose bits though.
    NUDRAT likes this.
  2. Jul 17, 2021 at 3:37 PM
    Nice. Going all out I like it! Please post back with the work once it’s done.
  3. Jul 17, 2021 at 4:52 PM
    Cummins3500
    Logan
    Installed the Hewitt tech gen 2 bypass on the ole girl today. Kits pretty awesome, came with super easy to follow directions. Highly recommend it
    (My little boy was helping me, don’t pay no mind to the capri sun lol)
    The box that makes it all happen.
    So I opted to not disassemble my dash all the way. I only took the glove box out for ecm access. Which left with a hell of a time trying to get wire in the cab. I ended come in above the ac condenser drain. Siliconed it really good in the engine bay and really good in the cab. Seemed like my best option
    *didn’t snap any pictures of the ecm splicing but wasn’t too bad. I did learn a hard lesson about scotch blocks, and did something really stupid with my wiring.
    *that leaves the block off plates, no photos but was relative uneventful. Took the tires off, dropped the fender liners and was able to get a small ratchet in to loosen them. It was slo go due to room but the plates are not that bad on a truck that isn’t rusty. I could see them being a nightmare on a rusty truck.
    *ole girl also got a oil change with Castrol high mileage full synthetic 5w/30 and k&n filter
    *finally installed my diode dynamics switchbacks, looks alright even though I don’t have clear corners. It did make me realize just how bad my stock headlights are though
    bmf4069, hammeron, NUDRAT and 3 others like this.
  4. Jul 17, 2021 at 5:17 PM
    the red
    That’s how I roll. I’ll start a build thread when I can put more time into it. I expect to spend 2 years on it, but it’ll involve a manual conversion among other custom mods.
    bmf4069, oscardog86 and NUDRAT like this.
  5. Jul 17, 2021 at 7:15 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    You should add this to the sticky thread on this topic.
  6. Jul 17, 2021 at 7:26 PM
    Cummins3500
    Logan
    @onesojourner good call, posted it in there also. Might can help somebody if they run into issues with the install
    onesojourner likes this.
  7. Jul 17, 2021 at 8:08 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    wait.. the gen two fits our trucks? their website doesnt list it
  8. Jul 17, 2021 at 8:12 PM
    empty_lord
    05 rollover special
    hmm so they do list it. never caught that. even states you can completely remove the pump and modules if you wanted. That kit would make the TRD supercharger bolt onto the VVTI motors since the main issue with the blower was it hit the air pump without plenum spacers
    Darkness and Filthyphil like this.
  9. Jul 17, 2021 at 9:46 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    uh oh. :spending::spending::spending:
  10. Jul 17, 2021 at 9:47 PM
    empty_lord
    05 rollover special
    Not for the foreseeable future
  11. Jul 18, 2021 at 3:16 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Did a side project this morning. I knew hanging onto the old oil fill cap would come in handy. When @empty_lord reccomended a coolant fill funnel kit replete with most of the fittings... I needed. I knew this project would be super easy!
    This specific kit is the one I have.
    I ordered two. One for oil, and one for coolant. The pictures below should be self explanatory, but will be happy to explain if anyone is curious.
    I need a little JBweld between the fill cap, and the yellow adapter, but should be golden after that.
    bmf4069, oscardog86, hammeron and 4 others like this.
  12. Jul 18, 2021 at 4:09 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Neat.
    I'd probably just epoxy part of a more standard style funnel to the drilled cap. Hmmm...
  13. Jul 18, 2021 at 4:14 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That was the original idea behind me keeping the oil fill cap, but I will eventually lose parts, and pieces of the coolant kit. I'll only need the sections shown in the last picture for the oil kit. So I'll have extras laying around for the coolant unit!
    oscardog86 and hammeron like this.
  14. Jul 18, 2021 at 7:18 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    The jeep and the titan have better ‘nooks’ to tuck my funnel into, but the funnel has its own drip pan, but i keep the lid, so it doesnt really drip. Its more of a spot to keep an oily rag, and keep a cleaner rag in the funnel to use for checking dipsticks and oil drops.
    bmf4069 likes this.
  15. Jul 18, 2021 at 10:15 AM
    It's like Christmas when these come. Installed new air filters on both vehicles and new driver side door check. Didn't realize how worn out mine was. It opens and shuts far different now. Installed those door check plates too.
  16. Jul 18, 2021 at 10:26 AM
    empty_lord
    05 rollover special
    I need that plate. But $$$$
  17. Jul 18, 2021 at 11:06 AM
    It was only $30-35 for both doors.
    Edit- actually only $25
    NUDRAT likes this.
  18. Jul 18, 2021 at 11:07 AM
    empty_lord
    05 rollover special
    Oh… wait… you were talking about the door check itself for $83… well fuck. Send me the link again in Instagram
    Darkness likes this.
  19. Jul 18, 2021 at 11:08 AM
    empty_lord
    05 rollover special
    In other news. I think tomorrow I’m going to look into all the lines I need to delete the ABS… I’m still not a fan of it
  20. Jul 18, 2021 at 11:16 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Hmmm. Wonder if there's enough interest for a group buy.
  21. Jul 18, 2021 at 11:21 AM
    empty_lord
    05 rollover special
    Well if they fit tacomas too I’d be down for a fair few… lol
    NUDRAT likes this.
  22. Jul 18, 2021 at 1:30 PM
    the red
    What's the issue? I haven't driven a Tundra enough to have paid attention or tested the ABS myself.
  23. Jul 18, 2021 at 1:32 PM
    the red
    I'll have to check my checks to check my interest in these checks.
    NUDRAT and tacoguybill like this.
  24. Jul 18, 2021 at 1:33 PM
    empty_lord
    05 rollover special
    Nothing. I just am so use for trucks without it. It’s still odd to me when it kicks on
  25. Jul 18, 2021 at 1:41 PM
    the red
    Understandable. Do you have traction control too? I think that relies on the ABS system to function.
    NUDRAT likes this.
  26. Jul 18, 2021 at 1:45 PM
    empty_lord
    05 rollover special
    Nope, mines just ABS.
    yes trac is part of the ABS system though
    the red[QUOTED] likes this.
  27. Jul 18, 2021 at 2:56 PM
    B7EC594F-B865-45B5-AE8B-FC2254590A54.jpg 12EB7691-8C55-417C-911C-4108A263FCE3.jpg 1BA6A12B-DB21-4D06-A340-41D7904A861A.jpg 40FD77A0-7B63-49F5-B9AB-F23AC0DBFDF4.jpg E9480DF6-520E-45C0-BC39-164F41639449.jpg 70AC9612-E756-421E-83E3-B87748542D30.jpg FCF0320D-8227-4BF5-AD66-2A948DB5B2CD.jpg A5077ED7-6B51-45B6-BAD9-A3EF4E72E29D.jpg F6D487A1-FB83-497A-8AB7-CD60D73263B9.jpg 93546A19-6531-4F40-BECB-92D8CDA3B3D9.jpg 142BD763-AC79-4016-B664-13E9C753D0D8.jpg 986E196C-BC7F-49C5-B0F4-642A7AA68471.jpg I’m back! Any new perma bans?
    took the family to our mountain for a 3 day adventure! It was fabulous!!! I knew we were going to get rain, @Tundra2 so as any Eagle Scout worth his weight in gold/cigarettes/or booze, I came mostly prepared! First off, anyone who wants to listen, awnings are THE absolute TITS!!! It saved our asses multiple times during our adventure due to the weather, and it’s 100% water proof! Easily deployed and easily pitched for watershed! I’m definitely going to get the annex for me and the boys trips! Second, I’ll be doing a rear member fluid swap soon, my entire ass end was up to the bumper when I launched the boat, rear tires completely under, my exhaust burbling. I have a remote breather but I’d still like to check. Boat captain said the truck crawled right out and didn’t spin at all!
    We had a great time even though the weather was perfect. We smashed it as usual with the fish, but not very many keepers; I’ll let the little guys go for another kid or to grow bigger. But this morning I caught a beautiful brown or German brown; keeper but I didn’t feel like dispatching him before we left. We got to watch this ridiculous storm come up the valley and smash into the mountain and take over the flat we were on, one of the coolest monsoons I’ve gotten to be a part of! And I cooked some stupid new yorks, corn/elote, and sautéed shrooms, shit was goooood!
    And the truck ran great the entire time! I was cooking on the way home because a left lane Lucy lollygagger from Texas wanted to keep up, stupid lane campers!!
    Oh, also fuck tail gates when your loading a bed w a camper shell!!!! I took it off all times loading and unloading!
  28. Jul 18, 2021 at 4:24 PM
    There won't be a group buy on door checks. I bought a door check but I also bought these little plates to help prevent this:
    Seller: https://instagram.com/valiantguy.george
    Also, I lied earlier. They are only $25 for access cabs.
    NUDRAT, Darkness, bmf4069 and 4 others like this.
  29. Jul 18, 2021 at 5:12 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Waiting for him to approve my request, so I can order a pair.
    des2mtn likes this.
  30. Jul 19, 2021 at 5:57 AM
    It is crazy how sensitive the rear drums are. I added a few clicks to the star adjuster yesterday with the wheels off the ground and noticed an immediate difference when I test drove it. I realize they are supposed to self adjust but that doesn't seem to work for me even though everything appears to be in great shape. I'm guessing the bell cranks I asked about last week are slightly out of adjustment. The back up and engage parking brake trick doesn't seem to do anything but the parking brake works very well.
    NUDRAT, Filthyphil and Jack McCarthy like this.
