Went Camping, not stoked on saggy backend
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by dhbrown, Apr 19, 2021.
  1. Jun 4, 2021 at 12:41 PM
    #61
    2mchfun
    Shackles will continue to push your springs down after hitting bump stops, not good at all in my opinion because at that point you will ruin the springs. I mean your shackles will force the springs too far down due to the excessive length of the shackle.
    JStrabler1 likes this.
  2. Jun 4, 2021 at 12:45 PM
    #62
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    I'll Second the Roadmaster Active Suspension!! The lift it can provide is adjustable as well. They say it increases the payload and towing capacity, but I don't agree with that. The payload and towing capacities are based on the frame and bed strength, not suspension lift. That being said, my truck bed can get a whole lot fuller before the rear end sags down.
  3. Jun 4, 2021 at 12:52 PM
    #63
    2mchfun
    For those of us with RAS, I think the weak links are the bed and the axle/5 lug pattern.
    AggiePhil and jimbrophotodotcom like this.
  4. Jun 4, 2021 at 1:47 PM
    #64
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The axle is only semi floating as well, not a true HD setup.
    I agree with your sumo point about the spacing between bump and frame being a big deal. On a stock tundra, the sumo is almost touching the frame at ride height
    2mchfun likes this.
  5. Jun 4, 2021 at 1:53 PM
    #65
    2mchfun
    That's part of the reason I have a good ride, the other reason is because I have many layers of spring, each leaf can be thinner than those thick stock leafs. Many thin simply rides better than a few thick due to the spring rate difference.
    Hbjeff[QUOTED] likes this.
  6. Jun 4, 2021 at 2:50 PM
    #66
    Bradleybb
    Bradleybb New Member
    Georgia
    2021 CM TRD OR
    Transmission cooler TRD REAR SWAY RCI front skid
    Big plus on the RAS , added benefit towing TT memorial weekend for first time ,
    No harsh ride without towing and empty bed
  7. Jun 4, 2021 at 11:25 PM
    #67
    dhbrown
    dhbrown [OP] New Member
    2019 TRD Pro, black
    No squeaking. I've added leafs on two trucks now. No squeaking whatsoever.
  8. Jun 5, 2021 at 12:36 PM
    #68
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles Flowmaster super 50. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5
    I have the icon Add a leaf. I regret them. They squeak too much and now I’m looking at replacing the complete leaf pack. I think AALs are hit or miss. Thinking of going deaver U748 and staying away from any of Icons leaf spring products going forward.
    DZ_, Wallygator and Bigboitundra like this.
  9. Jun 5, 2021 at 8:38 PM
    #69
    dhbrown
    2019 TRD Pro, black
    My dad has icon up front on his taco. They've squeezed from day 1. Lucky for him he's practically deaf... Lol. I personally think icon is over rated.
    Pbed85, Wallygator and 2mchfun like this.
  10. Jun 5, 2021 at 8:39 PM
    #70
    dhbrown
    2019 TRD Pro, black
    I also should note I live in Colorado. Dry as hell.
  11. Jun 7, 2021 at 4:51 PM
    #71
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    Well when you put it like that, yea it does make sense when you are hauling that much weight. And damn that Army Green PRO looks completely sick with those toys on top. Sweet setup.
  12. Jun 8, 2021 at 3:15 PM
    #72
    TorinWallace
    TorinWallace Yota Addict
    2020 TRD Pro, DoubleCab, Army Green.
    CB Shim + Shackles | 305/70r18 KO2's | 18" Method NV's | Firestone Airbags | Tow Mirrors | Marlon Sleddeck | Spyder smoked taillights.
    Thanks man!
    Bad Cow[QUOTED] likes this.
  13. Jul 3, 2021 at 9:51 PM
    #73
    redhat
    redhat Leadfarmer
    Jacob
    Sacramento
    2019 TRD PRO
    Nothing but good stuff.
    I added a set of Alcan custom springs, with an added 750lb weight rating. With my decked system and ARE shell it leveled it out and rides much better.
  14. Jul 4, 2021 at 9:33 AM
    #74
    jimbrophotodotcom
    jimbrophotodotcom New Member
    Hawaii
    2021 Lunar Rock Tundra TRD Pro
    IG: @LunaTheTundra, Coachbuilder kit and 35s soon
    I’ve been thinking about the RAS. Is it compatible with the CB shackles?
  15. Jul 4, 2021 at 9:34 AM
    #75
    2mchfun
    Im certain the HD version would be, not sure about the standard kit.
  16. Jul 4, 2021 at 3:15 PM
    #76
    Bradleybb
    Georgia
    2021 CM TRD OR
    Got the RAS HD helps out a lot with my towing set up , works with CB +2 , not with +1 without mods ,had to grind down the brace about 1/4”that ties em together,
  17. Jul 15, 2021 at 8:42 AM
    #77
    shakey_jake
    shakey_jake New Member
    Jake
    Virginia Beach
    2012 Tundra 5.7 TRD 4x4
    6" lift. 35s on 20s
    I bought a 29" travel trailer, approx 6,000lbs and it made my lifted tundra sag in the rear 2-3 inches. There was probably about 650 tongue weight. I did a lot of research on airbags, sumo springs, RAS, add a leaf, coachbuilders and ended up with the RAS. Mainly due to no change in the unloaded ride quality, and benefit of handling, way less body roll. plus with my cheap lift (6 inch blocks) in the rear, this completely eliminated all wheel hop and axle wrap. It's very noticeable on how much better it handles unloaded. The only down side is it lifted my rear about 1.5 inches so I have a small rake now but being that it's already lifted in the front it just looks a little higher. Not really a bad thing but something you should consider if going RAS. Really no other option will give you so much more benefits than a RAS.
    USCG2005 and jimbrophotodotcom like this.
  18. Jul 15, 2021 at 11:39 AM
    #78
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    Can anyone point me to a set of greasable bushings in stock anywhere for both rear leaf packs? Even greasable shackles with included bushings will work.
    I have a set of Dobinsons I can’t use until I find bushings, OEM-size bushings will work.
  19. Jul 16, 2021 at 6:17 AM
    #79
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    @2mchfun has them look up his build
    2mchfun likes this.
  20. Jul 16, 2021 at 6:53 AM
    #80
    2mchfun
    I used greasable shackles and bushings from Ironman 4x4 with Dobinson's HD leaf packs
  21. Jul 16, 2021 at 7:24 AM
    #81
    CoffeeAddict
    2016 Tundra CrewMax
    The problem is no one had any in stock. I’ve got an ARB set on the way now from Overland Expedition Outfitters, we’ll see if they work. Per Dobinsons they use OEM sizing so I should be good to go. I’m picking up the HD RAS too, no sense going halfway at this point. Your build made my mind up on that, I was on the fence.
    AggiePhil and 2mchfun[QUOTED] like this.
  22. Jul 16, 2021 at 8:35 AM
    #82
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    I have the same, and agree with your complaints. I spray mine with fluid film around the brackets every once in a while to keep them quiet. A couple of shots where they rub does the job.
  23. Jul 16, 2021 at 8:37 AM
    #83
    2mchfun
    Be careful, the leaf packs are a bit heavy and awkward due to the shape. Extra hands would be helpful but not necessary. Good choice on your part. BTW, don't forget a rear brake line relocate kit for when it droops. My truck is getting extension limit straps in the near future too because if it goes airborne suddenly the heavy springs will extend hard which isn't going to do the shocks a lot of good.
  24. Jul 16, 2021 at 12:33 PM
    #84
    CoffeeAddict
    2016 Tundra CrewMax
    I now have a brake line relocate kit on the way, I’m probably right on the line of needing it or not. Same for limit straps, I have no plans on catching air intentionally but it’s cheap insurance. Shoot me which ones you choose if you don’t mind and I’ll piggyback on your selection. :thumbsup:
    2mchfun[QUOTED] likes this.
  25. Jul 16, 2021 at 1:46 PM
    #85
    2mchfun
    ThisScreenshot_20210716-155118.jpg is the strap clevis, mounts need to be fabbed still, straps will be ordered after I know the length or distance between the mounts at full droop minus about 1.5" to allow for the stretch and to prevent full extension. This is all going to take time as it is not my biggest priority. Family and chores before play basically.
    You can search Amazon for this or other sites. They also have weld on mounts, I will be fabricating my own mounts though.
  26. Oct 10, 2022 at 2:51 PM
    #86
    AI84
    AI84 New Member
    Encinitas
    2017 TRD Pro CM cement
    Are your RAS HD and do you know what tension setting they are on? We run similar setups.
  27. Oct 11, 2022 at 4:42 PM
    #87
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I took off that ras and went with bags, Ras was awesome for loading up the bed, but wasn't that great with tongue weight, it was set at max tension.
  28. Oct 11, 2022 at 4:48 PM
    #88
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    I went with shackles (and new shocks) and am happy so far on my 2018.
  29. Oct 11, 2022 at 6:04 PM
    #89
    AI84
    AI84 New Member
    Encinitas
    Ah bummer to hear - I ordered RAS today and my issue is mainly tongue weight. But I'm only using a hitch carrier to carry my dirt bike + gear in the bed so it's nothing too crazy. What were you pulling and what was the tongue weight if you don't mind? Curious if it was a lot more than I'll be using with my RAS.
  30. Oct 12, 2022 at 5:50 AM
    #90
    Downytide
    GTA
    I tow either a utility trailer with random things/vehicles up to total 8k lbs, with tongue weight around 700lbs, or travel trailer that's about 5k and has 500lb ish tongue weight.
    When I had stock pro suspension, it was great for load in the bed, it also had a very small rake which was great, it had just tiny sag in the back like when stock, rode well too.
    Then I switch to fox 2.5 DSC , I couldn't get rid of the feel when going over large holes (which is often as I'm out in country side) it feels like the suspension wants to kick, so the front is butter smooth and rear can be jarring, and the front even at lowest setting is about 1 to 1.5" taller. So now it's +3 shackles and bags with cradle.
    In short, with stock suspension is decent, didn't work well for me when switched, it still had decent articulation as I take it on trails every now and then.
    AI84[QUOTED] likes this.
