Conflicting research caused this thread to be created. 3" lift questions.
Discussion in 'Suspension' started by TucsonTundra1794, Jul 9, 2021.
  1. Jul 9, 2021 at 10:07 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Not yet, been out on family vacations and getting my butt kicked at work, just haven’t had any time. Will probably do it this weekend depending on how work goes.
    BiggHertz[QUOTED] likes this.
  2. Jul 9, 2021 at 10:11 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    oh man! I know that feeling!
  3. Jul 9, 2021 at 11:16 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Icon stage 8 is a hardcore setup for “occasional offroading”. You do not need that level of components if you’re not gonna really push it
  4. Jul 10, 2021 at 6:10 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    I like to differ that statement....only to say I wasn't a believer at first by only reading so many lifts, components, makes, coilovers, spacers, AAL, blocks, shocks, and so on.....you get it.
    My final answer was toytec 2.0 aluma series complete lift kit...omg, never looked back, rides imho is better than stock, just the right lift to clear 295/75/18 with no issues and again rides so schweeet....even 1st time friends who jumps in for a beer run says what a plush ride and was so surprised...take it for what it's worth and read up members with toytec lifts...all positive. good luck with your build.
  5. Jul 10, 2021 at 10:13 AM
    TucsonTundra1794
    TucsonTundra1794 [OP] ASCM #6-11 I'll buy if you're willing to ship
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    What did you do for the rear? Just the add a leaf?
  6. Jul 10, 2021 at 10:49 AM
    Bob_Wiley
    Eric
    AZ
    Yeah, for the rear I got piggyback shocks with the compression dampening control valves and a replacement leaf pack that’s a step up from OEM (all part of the stage 6 package). Didn’t take long before the leaf pack started squeaking, which is a known annoyance with Icon. Not so annoying that I’ve done anything about it yet, I really only notice it when driving around the neighborhood with the windows down.
  7. Jul 10, 2021 at 10:58 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I’ve noticed the squeaking too after I put in my new leaf packs. Like you said, not bad enough to really take action on it, but enough to notice it and kinda be bothered while driving around with the windows down.
  8. Jul 10, 2021 at 11:18 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I'm getting the RTX leaf pack and wondering if I should order coachbuilder shackles or if the oem ones will be fine.
    Bob_Wiley likes this.
  9. Jul 10, 2021 at 11:22 AM
    Bob_Wiley
    Eric
    AZ
    @TRDFerguson didn’t you replace your shackles recently with CB’s?
  10. Jul 10, 2021 at 11:25 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Since the leafs are going to give me all the lift I need I could just order the +1 coachbuilder shackles and it wouldn't hurt to have them. Also wondering if any bushings should be upgraded to poly while it's all open. Did your icon kits come with poly?
  11. Jul 10, 2021 at 11:29 AM
    Bob_Wiley
    Eric
    AZ
    I didn’t do the install, but I’m 99% certain my Icon kit didn’t come with any replacement bushings. Pretty sure you have to buy those separately.
  12. Jul 10, 2021 at 11:29 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Nope, just running the Icon expansion pack with stock shackles for now, with Coachbuilder poly bushings in the leafs.
    I don’t know how the RXTs come but I’d imagine they already have poly bushings. The upper bushings in the truck frame are already poly.
  13. Jul 10, 2021 at 11:30 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
  14. Jul 10, 2021 at 11:31 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Ok so then I'll leave the coachbuilder shackles for later since they aren't necessary. That's an easy install when I decide to do it.
    SC_TRD likes this.
  15. Jul 10, 2021 at 11:35 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Also saw this under the total chaos uniballs in the UCA thread. Might try and price these too
    From the UCA thread under total chaos:
    • UCA's are designed with added caster to aid in retaining factory alignment specs when aftermarket lift kits are installed. This reduces the darting or wandering in the vehicle's steering when 2.5"-3" lift kits are installed.
    SC_TRD likes this.
  16. Jul 10, 2021 at 11:37 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    I’ve noted many complaints about nearly all add a leafs and replacement spring packs. It really is all about manageable expectations. Things will creak and groan, just sorta the nature of things. I inevitability settled on OEM leafs and CB+2 to avoid these scenarios myself. I have seen a handful of members revert back to OEM leafs.
    the devil you know vs the devil you don’t…
    - JS
  17. Jul 10, 2021 at 11:41 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I'll give them a shot and keep the oems just in case. Those I feel comfortable swapping out myself if I need to.
  18. Jul 10, 2021 at 11:45 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
  19. Jul 10, 2021 at 11:50 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  20. Jul 10, 2021 at 11:53 AM
    #50
    TucsonTundra1794
    Anthony
    Tucson, AZ
    The icon kit says 3" front and 4" rear. I'm hoping to sit close to that
  21. Jul 10, 2021 at 11:57 AM
    #51
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    3 front, 4 rear (unloaded) would be a truck 3 inches taller from where you’re at now and an additional 1” of rake…for about a 3 inch rake….is this what you’re trying to accomplish?
    - JS
  22. Jul 10, 2021 at 12:01 PM
    #52
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Yes that's what I would like.
  23. Jul 10, 2021 at 12:08 PM
    #53
    2mchfun
    You might want to add a rear brake line relocate kit, cheap insurance when it droops.
    SC_TRD and BiggHertz like this.
  24. Jul 10, 2021 at 12:11 PM
    #54
    TucsonTundra1794
    Anthony
    Tucson, AZ
    These?
  25. Jul 10, 2021 at 12:14 PM
    #55
    2mchfun
    Nope, google OME Tundra rear brake line relocate kit
  26. Jul 10, 2021 at 12:15 PM
    #56
    2mchfun
  27. Jul 10, 2021 at 12:22 PM
    #57
    TucsonTundra1794
    Anthony
    Tucson, AZ
    They had those on the Toytec site too I thought they were the same thing. I'll order them
  28. Jul 10, 2021 at 1:46 PM
    #58
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    CB has some as well.
  29. Jul 10, 2021 at 2:00 PM
    #59
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I ran Toytec on my truck for 2 years. It was just a Bilstein with 600lb linear coils. Smooth but not as smooth as stock by nature- the stock progressive coils flex easier than linear coils do. Wasn't bone jarring by any means but over quick things like speed bumps it was noticeably more stiff.
    D4x4TRD and TucsonTundra1794[OP] like this.
  30. Jul 13, 2021 at 11:29 AM
    #60
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Alright guys I went with icon stage 8 and tubular UCAs with delta joints. Parts should be in next week. Please don't tell my wife.
