Zerex Asian Coolant $11.99 Advanced Auto Parts
Discussion in 'Deals & Group Buys' started by SouthWestGA, Jul 9, 2021.
  1. Jul 9, 2021 at 12:54 PM
    SouthWestGA
    SouthWestGA [OP] New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Advanced Auto Parts has Zerex Asian Coolant 50/50 on sale for $11.99 a gallon
    I purchased 3 online today for pickup locally
    Just passing the info along
    YardBird and Black Wolf like this.
  2. Jul 9, 2021 at 1:01 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 AC TRD
    Bassani cat-back
    What have you got against hot asians?
    300BLK, Gravy, 2mchfun and 1 other person like this.
  3. Jul 9, 2021 at 3:06 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    In case you want to think that it's either a typo OR....uhhhh......um......sumptin other.........well...........here it is:
    Tundra2 likes this.
  4. Jul 9, 2021 at 3:13 PM
    Aurora CO
    Great deal. You going to flush out your system or is your water pump weeping pink crust? My 07 did so I bought a gallon. Still have it. Almost full. Zerex is good stuff.
    AZTundra likes this.
  5. Jul 9, 2021 at 3:43 PM
    SouthWestGA
    The work is actually on my wife’s 2008 Limited Sequoia 5.7 with 244,000 miles.
    The original issue is a leaking AC Condenser
    But while I’m in there…..it will get an Aluminum KOYO Radiator, HPS Silicone Hoses,and Aisin Water Pump/Thermostat/Housing plus new coolant.
    Along with TRD Front and Rear Sway Bars,New Sway Bar Bushings and End Links
    Oil Change and Transmission Drain/Fill as well
    That should do it for another few years lol
    Cheaper than trying to replace it at today’s prices for sure.
    woods and Black Wolf[QUOTED] like this.
  6. Jul 9, 2021 at 3:47 PM
    Sirfive
    ‘02 AC TRD
    Bassani cat-back
    there are hot asians in your area that dont want to meet you anymore.
  7. Jul 9, 2021 at 4:11 PM
    Aurora CO
    Sounds like you got this figured out:thumbsup::burnrubber:
  8. Jul 9, 2021 at 4:28 PM
    SouthWestGA
    Only occasionally! With 4kids and a .5th due in October, Most of the time it’s unorganized chaos
    Better than dealer coolant prices for sure!
    WILLINH and Black Wolf[QUOTED] like this.
  9. Jul 9, 2021 at 4:30 PM
    Aurora CO
    Didn't you get a bit of moisture lately from Elsa? Hopefully not too bad.
  10. Jul 9, 2021 at 4:31 PM
    SouthWestGA
    Just enough to wet things down pretty good and make a bunch of steam and haze. On/off showers the last few days.
  11. Jul 9, 2021 at 5:08 PM
    raymond_hb
    raymond_hb New Member
    Oakland, CA
    07 Tundra Limited 2WD
    Got my DD SS3 Sport and VLED lights from @memario1214 thank you very much for changing my mind on the fog lights love them super bright. I did have some housing installation problem there was a stubborn screw on the side that would not let the fog housing sit well but once removed housing stuck on. PowerStop Z36 brake kit low key freaked out when I saw the tiny rear pads compared to the front. Those will go on later
  12. Jul 11, 2021 at 9:30 PM
    SouthWestGA
    I picked up the coolant today
    The salesman said it is reduced through the end of the month
  13. Jul 11, 2021 at 9:55 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This is perfect. I was looking at buying a 6 gallon case from big gurllll
    $108 + Tax for 6 gallons or $142.40 + Tax for 12 gallons.
    It's not like this stuff goes bad in the container does it?
  14. Jul 11, 2021 at 10:10 PM
    SouthWestGA
    I have no clue about expiration
    Maybe someone can help us out with that question
    Tundra2[QUOTED] likes this.
  15. Jul 11, 2021 at 10:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I would think it doesn't go bad in the container, but only goes bad when heat cycled by running engine.
    Source
  16. Jul 12, 2021 at 5:39 AM
    SouthWestGA
    So last night i began my project
    the dang fan support bracket is loose and makes noise when free wheeling
    i didn’t order that part lol oops
    Next time i know better
    Big gurl says it’s arriving tomorrow
    The parts store says dealer only unless i want Dorman or Gates
    Tundra2 likes this.
  17. Jul 12, 2021 at 5:46 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Aisin should be good replacement. Check rockauto
    SouthWestGA[OP] likes this.
  18. Jul 12, 2021 at 5:56 AM
    SouthWestGA
    Big gurl says the Aisin should be here tomorrow hopefully
  19. Jul 12, 2021 at 8:18 AM
    SouthWestGA
    Looked at a few Sequoias and sent out feelers
    But at this point,you’re just putting money into a new rig on maintenance since it has an unknown history. You could end up doing the same things to it,you never know!
    So better to save on ADValorem taxes and payments and just keep what you got
    Maybe when the kids get a few years older and aren’t as rough on a vehicle then get something else
    At least that’s what I tell myself…..Don’t get another vehicle until it’s an absolute “Need”
