Check Out My Lower Ball... Joints
Discussion in '1st Gen Tundras (2000-2006)' started by DarkMint, Jul 9, 2021.
  1. Jul 9, 2021 at 7:28 PM
    DarkMint
    DarkMint [OP] just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    NWPirate, des2mtn and Darkness like this.
  2. Jul 9, 2021 at 7:34 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I was one of the ones who thought it didn't look right. It was clearly just a bad pic, sorry, that looks perfectly fine.
    NWPirate, des2mtn, Darkness and 2 others like this.
  3. Jul 9, 2021 at 9:04 PM
    They look like they’re leaking with the wet spot on the LCA.
    des2mtn, Darkness and DarkMint[OP] like this.
  4. Jul 9, 2021 at 9:10 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    The ball joints are fine. Like Tilly said, I think the glare from the other images created the illusion that a bolt was backing out or not in all the way. The oily residue is probably old residue that wasn't thoroughly cleaned off.
  5. Jul 9, 2021 at 9:15 PM
    DarkMint
    Ben
    Thanks everyone. You guys rock.
    NWPirate, Darkness and jpink like this.
  6. Jul 9, 2021 at 9:28 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Told ya :hattip:I admit when everybody was chiming in I thought maybe they are on computers and have a better view. Glad its all good.
  7. Jul 10, 2021 at 3:20 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    :hattip:
  8. Jul 10, 2021 at 6:14 AM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    My question is, why install new ball joints and not use new hardware? Not that it’ll be an issue, but new bolts would’ve made the job look prettier.
    DarkMint[OP] and w666 like this.
  9. Jul 10, 2021 at 8:43 AM
    Sunnier
    Sunny
    San Diego, CA
    I agree. If you had this done, why not get new bolts? It’s not fun when one backs out causing the others to vibrate, then snap, leading to failure of the entire assembly….
    DarkMint[OP] likes this.
  10. Jul 10, 2021 at 8:53 AM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    I'm still waiting for the day that I hear this from my wife.
  11. Jul 10, 2021 at 12:14 PM
    Are you speaking from experience? That sounds very specific.
    DarkMint[OP] and Sunnier[QUOTED] like this.
  12. Jul 10, 2021 at 1:27 PM
    Sunnier
    Sunny
    San Diego, CA
    Yes.
    I was out with experienced mechanics so it got fixed on the trail and I made it home. But in addition to the LBJ break itself, the fender was damaged. And I get wind in the cab now— the truck landed on the wheel/tire and either cracked or bent the firewall in such a way that the cab isn’t sealed as before. It was a pretty significant collision truck vs. itself.
    We subsequently replaced all the bolts on both sides. The truck had ~215k miles and all were probably original. My truck is long travel and I drive (and land) it hard, but most agree the LBJ are the weakest point on our first gens. I now think they oughta be replaced as maintenance at high mileage, but I especially can’t see changing some components but reusing the fasteners—- those have the most stress on the smallest area IMO. I can’t remember how much $ for new bolts for both sides, but I know it was < $50 . I can’t imagine not swapping in new when everything else got replaced.
    At this point, it’d be an easy driveway repair for the OP— swap ‘em out one a time, get each to torque specs.
  13. Jul 10, 2021 at 2:12 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm not sure that they reused the bolts. The bottom joint end is just as rusty as the 4 bolts, and the tops of the bolts look new. Maybe its just rusty already
  14. Jul 12, 2021 at 12:51 AM
    DarkMint
    Ben
    I'll give the bolts a good hard look. I got this done at my local stealership on recall so I didn't pay a dime, and hence would not be surprised if they didn't bother changing out my fasteners.
    This is the first car I've owned to with intent to work on it myself like this. I know a lot of you guys say this but... The parts buying just doesn't stop huh?
