Leaving skid plate off
Discussion in '1st Gen Tundras (2000-2006)' started by Strangebird22, Jul 7, 2021.
  1. Jul 7, 2021 at 8:33 AM
    Strangebird22
    Strangebird22 [OP] New Member
    Terry
    Ohio
    2000 Tundra AC 4.7 4X4 SR5
    I bought my 1st gen 3 years ago and after doing the first oil change I decide that PITA was not going back on. I do not off road and only drive it a couple time a week back and forth to work. I do pull my camper with it, but don't imagine going anywhere that it would be needed. So it's been 3 years no issues. I thought that maybe it would cause overheating problems but that is not the case. I do still have the plate and hardware if I ever need or want to reinstall it. So has anyone else left the skid plate off.
  2. Jul 7, 2021 at 8:39 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Yes, that is no big deal. Not all tundra's even come with skids. There is no issue with leaving it off if that suits you better.
    RitcheyRch likes this.
  3. Jul 7, 2021 at 9:12 AM
    terrward
    terrward New Member
    2004 DC SR5
    Mine was pretty rusted through and 2 of the bolts were snapped. Been running without a skid plate for a while now with no issues, actively looking for a replacement but there are none for sale locally to me.
    w666 likes this.
  4. Jul 7, 2021 at 9:32 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Opinions always vary when that question comes up given it is more of a personal choice in believing what is and what ain't beneficial from a skid plate !
    Personally mine is off at the moment for front suspension maint and will go back on when I get round to it !
    How critical is the front skid? | Toyota Tundra Forum (tundras.com)
    15whtrd and Darkness like this.
  5. Jul 7, 2021 at 9:40 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I looked at the stock skid as more of a flung debris guard than anything. I don't think it will help if you hit anything serious bit I did run over a fallen tree with mine on accident once. To me the extra 10 minutes of pulling it off and putting it on was worth peace of mind.
  6. Jul 7, 2021 at 10:32 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I swapped mine out for a Skid Row plate. It doesn't have the elephant ears and oil changes are easy without removal.
    [​IMG]2021-01-02_10-08-14 by GhostCreekMine, on Flickr
  7. Jul 7, 2021 at 10:58 AM
    @Glock 40 I can't get over how good your truck looks with that red/black combo you have going. It looks great every time you post a picture.
    Also, I love my skid row armor. I'm tempted to get the transmission skid one day.
    Glock 40 and Darkness like this.
  8. Jul 7, 2021 at 11:04 AM
    This is a good point. Even if you don't offroad, you never know what you may encounter on the road these days. I've hit both a semi tire and an extension ladder in the past 3 years.
    Darkness[QUOTED] and 15whtrd like this.
  9. Jul 7, 2021 at 11:11 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I would keep it. It does provide protection to the radiator, hoses, and front of engine from road debris.
    While a pain to remove, its far less so on the 1st gen than the later models.
    Darkness and 15whtrd like this.
  10. Jul 7, 2021 at 11:40 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think its only 5 small bolts. Grease them up so they won't rust and use a jack to hold the plate up while you remove/install them. Or do the yoga pose where you are on your back with your knees up to hold the plate. It isn't that bad.
  11. Jul 7, 2021 at 11:43 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I thought about leaving mine off as I don't off road. However, given my luck, the moment I take it off, I'll hit some rock or pothole and it'll damage whatever the skid plate was protecting.
  12. Jul 7, 2021 at 11:57 AM
    Helps me with these 3-4 things:
    1. Debris on road deflected from doing underside damage
    2. Pushes high snow drift down to keep it from getting caked up on underside of engine area
    3. Prevents pre-mature rusting of engine Bay Area
    4. Deters vandals from having easy access to damage things underneath
    Sampson, 15whtrd, FirstGenVol and 3 others like this.
  13. Jul 7, 2021 at 12:12 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    What about gas mileage?
  14. Jul 7, 2021 at 12:13 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Equally as bad, with or without the plate!
    JODOOR likes this.
  15. Jul 7, 2021 at 12:14 PM
    Mines off, but will go back on before upcoming adventure
  16. Jul 7, 2021 at 12:55 PM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    Wish my first gen came with one! It must've rusted off before the PO had the frame replaced under recall.
  17. Jul 7, 2021 at 2:33 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    I haven't ever removed the skip plate on my 06 RWD 4.7 to change the oil. No problem draining the pan. When doing the filter I put about 3 triple walmart bags under the oil filer on the skid plate. Remove oil filter reaching from top of engine and drop the old filter into the walmart bags and screw on new filter real quick. Remove walmart bags with old oil filter and oil mess. I usually get a few drops of oil on the skid plate I wipe off with a couple of paper towels.
    KNABORES likes this.
  18. Jul 7, 2021 at 4:52 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Fun fact while we are on skid plates, V6 Tundras even have plastic or rubber skids per @Tundra2, which obviously does less than metal.
    You'll be okay for typical DD'ing without it. If I were you, I would at least put it on when you're towing the travel trailer. It would suck for a trip to come to an abrupt halt because you came across an unavoidable road hazard.
    15whtrd likes this.
  19. Jul 7, 2021 at 4:54 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes. Plastic skid on V6. It's cheap insurance to leave on. Even if it is plastic. It will absorb some of the blow, and may even save the whole truck in a catastrophic event.
    des2mtn likes this.
  20. Jul 7, 2021 at 8:46 PM
    ToyotaJim
    ToyotaJim New Member
    My 2002 does not have one, but I'm on the hunt for one. Cheap insurance against damage. My 2000 has one, and yes a minor pain the 1 or 2 annual times I need to change the oil filter.
    I was driving home one night on the freeway at 60-65mph and in a fraction of a second, right in the middle fo the my lane, I hit a large truck tire that made multiple contact points with the bottom of my Mercury sedan. Thankfully, no damage. But there was literally no reaction time. Hit is a 1/2 second after seeing it.
    Anything more solid, or larger, a tree branch, log, rock, animal carcass, etc. could do serious damage to the very expensive underside of a vehicle.
    I'm putting a skid plate on my harvest list for my next run to the junk yard...
  21. Jul 7, 2021 at 9:06 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Wait, you V8 people have to remove your skid to change the engine oil?
    Sirfive likes this.
  22. Jul 7, 2021 at 9:37 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    206768305_10159202917735275_349023570827_f0961c2af433764c577913da51558f0b3e5d1e93.jpg
    Tundra2 likes this.
  23. Jul 8, 2021 at 6:00 AM
    Tundies
    Tundies New Member
    Justin
    2001 AC LTD, 2005 DC SR5
    I have a V8 Tundra with the plastic skid plate on my 2001 LTD. One of the bolt holes snapped during... something so it has a lil dangle on one side. I'll replace it, or just sell the 2001, eventually.
  24. Jul 8, 2021 at 6:24 AM
    Not the oil, the filter.
    Looks like an inviting home for critters.
    Sirfive[QUOTED] likes this.
  25. Jul 8, 2021 at 6:26 AM
    As he said, just the filter. But several members with Ape Arms have reported they can reach it from above and don't remove the skid plate. Me, with tiny arms cannot. Thankfully the Skid Row plate doesn't require me to do that.
    Jack McCarthy likes this.
  26. Jul 8, 2021 at 6:27 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    The TRD Pro skid plate installation instructions call it an engine under cover.
  27. Jul 8, 2021 at 10:37 AM
    I've always removed my filter from above. I also do not remove the skidplate during oil changes, I make a ramp for the oil drippings with the coated cardboard box that comes with my giant Mobil 1 oil filter. My daughter's Jeep Cherokee has a plastic skidplate with a trap door for oil changes. I've left the trap door off from day one. Oil filter on the Pentastar 3.2 V6 is a top mounted cartridge (same for the 3.6 in the wife's JGC) . So nice. Unscrew the cover, pull the cartridge, put a new one in, screw the cover back on.
    ToyotaJim likes this.
  28. Jul 8, 2021 at 11:56 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I like to take the skidplate off. Like a lingerie bra. I know whats in there, but it really sets the mood.
    JasonC. and Mustanley like this.
