How critical is the front skid?
Discussion in '1st Gen Tundras (2000-2006)' started by Baller, Oct 9, 2019.
  1. Oct 9, 2019 at 4:35 PM
    Baller
    Baller [OP] New Member
    '05 Tundra SR5 DC
    Just interested to hear what people think? How much, if any, in the way of structure, does it play a role? When daily driving on the street, is the protection it provides, actually amount to anything? I've had mine off for last little bit and wondering if I should bother putting it back on if I'm only planning on street travel in the foreseeable future.
  2. Oct 9, 2019 at 4:46 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The only thing I could think of is hitting something and ripping off the oil filter. Last year I came upon a semi tire on the interstate that I had no time to avoid. I was driving my wife's Rav4. I hit the shit out of that tire and immediate pulled over. Luckily her car has a canister style filter so it didn't do any damage. But I have since wondered how that tire could have damaged something else.
    What is your reason for not wanting it on?
    Darkness and Pinay like this.
  3. Oct 9, 2019 at 4:47 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    You never know what you could run over on the street. Skids more critical off road but still good idea on pavement.
  4. Oct 9, 2019 at 4:50 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Second that. I'd also be nervous about road debris or even a dead squirrel ripping off an ATF hose at 80mph on the highway.
    TNTundra7 and Pinay like this.
  5. Oct 9, 2019 at 4:51 PM
    TNTundra7
    TNTundra7 New Member
    TN
    2016 SR5 4WD 5.7L
    Bilstein 5100s, TRD RSB, TRD Wheels
    I banged mine up a little when I first got the truck backing into a driveway. It was dark, I was zapped from driving 10 hours and just got into a hurry backing in. I'm sure it saved my oil filter and who knows what else. That is probably a rare situation, and most of the time it will not get hit if you are not off-road. However, may I ask why you do not want to put it on? Looks or inconvenience or something else? I think it's like 5 bolts or something.
    Pinay likes this.
  6. Oct 9, 2019 at 5:00 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @Baller just buy the Skid Row plate and then you can do oil changes without removing the skid plate.
  7. Oct 9, 2019 at 5:08 PM
    Baller
    '05 Tundra SR5 DC
    It's inconvenience. I've got an RCD lift and where the skid bolts to the lower crossmember is a serious PITA to get to. I've thought about fabbing something to bolt to the lift's crossmember to make things MUCH easier. I may just have to get to work on that.
  8. Oct 9, 2019 at 5:10 PM
    Baller
    '05 Tundra SR5 DC
    Will it work with the 6" RCD lift?
  9. Oct 9, 2019 at 5:11 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Mine was gone when I bought the truck, 30k of daily driving with no problems.
  10. Oct 9, 2019 at 7:58 PM
    turboser91
    turboser91 New Member
    Fresno
    06 DC 4x4
    6" RCD lift
    It should work with the RCD lift. Only problem I see is the rear mounting bolts will be tough to bolt on between the original cross member and the new cross member. There's only a about 1" gap. Plus it will not cover the new cross member with the RCD kit.
  11. Oct 9, 2019 at 8:09 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I wouldn't drive without one. I've had everything from tires to fallen trees appear in front of me on the road. 5 minutes of wrenching every 5k miles isn't a big deal.
    marbleville, FirstGenVol and Pinay like this.
  12. Oct 9, 2019 at 10:02 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I don't see any need for it if OP has a 6in lift and doesn't off road it.
    koditten likes this.
  13. Oct 9, 2019 at 10:06 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    My 2002 Sequoia and 2004 Tundra were the first 4WD vehicles I bought that came with skid plates under the engine and they were the first thing that I removed. I have been driving 4WD trucks for 45 years hunting, fishing and off-roading and never sustained engine damage from not having a skid plate under the engine.
    I have had numerous lowered mustangs in my life, my wife drives a Camry and they have never had engine damage from road debris. So I figure if a lowered car is safe to drive down the road then my lifted 4WD should be safe from being damaged without a skid plate. I like the convince of not having if in my way for engine servicing and inspection. But if someone else wants theirs on I won't argue, we each have our own opinion.
  14. Oct 9, 2019 at 10:22 PM
    Aerindel
    Aerindel New Member
    Montana
    2000 Tundra AC, SR5, 4.7 V8 4WD, 340k'ish miles, 2008 Sequoia, 220k Miles
    The stock one isn't really a skid plate, just a splash guard. I've been driving all summer without mine as I've been working on the truck a lot. If I ever get everything buttoned up again I'll put it back on but I don't think its that important.
    BubbaW likes this.
  15. Oct 9, 2019 at 10:49 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    My daily driver is a lowered GTI, it has a heavy duty skid plate and its been used several times. To each their own.
  16. Oct 10, 2019 at 3:52 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I removed mine. I don't like the way it looks anyway. Just motivation to make something better. I'm probably in the minority of people that should have one though. Something about plowing into a sandy bank or ditch and stuffing the front end makes me cringe a little. The same goes for desert ditches in snow. Never know where I'll end up when I'm trying to carry speed to make a hill or something when it's slick and muddy/snowy in the desert. I've been alright so far though.
    Darkness likes this.
  17. Oct 10, 2019 at 4:30 AM
    BigRedFireEngine
    BigRedFireEngine New Member
    Toronto, Canada
    2016 Crewmax 1794 Edition in.... red.
    Extang Solid Fold 2.0 Trifold Tonneau, Go Rhino RB10 running boards, Kenwood DDX9905s
    It’s so easy to zip it off and on with a cordless impact gun, I wouldn’t go without it.
    marbleville likes this.
  18. Oct 10, 2019 at 5:01 AM
    I've mentioned this before here but several years ago in Orygun, I was headed in to town and came across a minor rockslide. I had nowhere to swerve. Two rocks took out the oil pan and disabled the car. I like skid plates.
    bmf4069, Darkness and Pinay like this.
  19. Oct 10, 2019 at 5:11 AM
    georgie
    georgie New Member
    The stock trd sport anyway is more than a splash guard. I gives front protection to the rubber boots cvt joints and oil pan. better than nothing.
  20. Oct 10, 2019 at 5:12 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    When I got my truck it was missing the front splash guard/skid. I thought it looked weird without it (and I definitely like the looks better with it on), but I mainly found a used one for the protection. Lots of the A/C and radiator fins (and the drivebelt and pulleys) are exposed and I'd hate to take a rock through them. The truck sits high (2.25" lift) so there was a definite path for damage. We have a lot of tractor trailers and dump trucks here, so lots of bouncing rocks on the highways. I also didn't like the idea of water being able to splash these same areas with any rain or puddle.
    marbleville and georgie like this.
  21. Oct 10, 2019 at 5:19 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    While I can't say for certain, I would suspect it does. This skidplate uses the OEM mounting holes. So as long as those are still accessible I would think it should work.
    This is one of those risk vs reward questions. The potential risks of not having a skid plate doesn't seem to outweigh the pros for me. That's just my opinion. I look at it the same way as my fire extinguisher and 9mm. The chances of me needing them are slim but the potential consequences of not having them are huge.
  22. Oct 10, 2019 at 5:30 AM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    Well, because of the rarefied air that accompanies ALL Tundras, the skid plate is necessary to keep the vehicle planted on this good Earth by creating a powerful kinetic connection to the planet's gravitational force. Without the plate, Tundras would likely float away as the clouds do, when drawn by forces not of this world, for such trickery is the making of the gods themselves who have a real thirst for the great treasures of Earth, and we all know that Tundras are such a treasure. Removing the skid plate would be like removing your feet, and we all know that without our feet to anchor us to the ground, the hot air that constitutes our opinions would surely cause us to float away as well.:tinfoilhat:
    NE_WARRIOR, bmf4069, Aerindel and 2 others like this.
  23. Oct 10, 2019 at 12:43 PM
    TNTundra7
    TN
    2016 SR5 4WD 5.7L
    ^^^ This ^^^
    Pinay likes this.
  24. Oct 10, 2019 at 3:08 PM
    Aerindel
    Aerindel New Member
    Montana
    I would agree except the factory skid plate is not so much a fire extinguisher and 9mm but more a bottle of water and can of pepper spray. I've got nothing against it as it does no harm, but I also don't think its substantial enough to really help all that much either. An aftermarket armored one I would feel different about and is something I plan to make over the winter along with a new front bumper.
  25. Oct 10, 2019 at 3:53 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Have to agree with any and all reasons given above by others....just like Am Ex "Don't leave Home without it".
    Did recently remove the front skid plate tho !
    Aerindel likes this.
  26. Oct 10, 2019 at 6:07 PM
    Borador
    Borador New Member
    Olive Branch, MS
    2016 Crewmax 4x4 w/1794 Interior upgrade
    Their website just shows skid plates for Tundras from 1999-2006.
  27. Oct 10, 2019 at 6:49 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Correct. That's why this is posted in the 1st(cough:best) Gen section.
  28. Oct 10, 2019 at 6:58 PM
    marbleville
    Yep, last name too.
    State of Confusion
    Here, here, what he said ^^^.:amen:
  29. Oct 10, 2019 at 7:30 PM
    koditten
    Kirk
    Midland of the Mitten
    The skid does come off easy with a cordless driver, but it also can get installed with same cordless driver by the next retard and cross the threads.
    I've been driving 4 x 4vtoyitas since 1998, is seems those bolts are cross threaded or rusted solid.
    I pull mine off the 1st time I do service and toss them in the scrap pile.
    I got insurance if I hit something in the road. I've had no near misses on the trail.
    If you want it, keep it, if not, you most likely won't miss it.
  30. Oct 10, 2019 at 7:31 PM
    Opus5150
    Opus5150 Terminal Lance
    Live Free or Die
    2017 Tundra
    Cheaper than a new engine... I've seen 4x4s dead on the trail because something holed the radiator or oil pan. I've personally hit an empty 5 gallon bucket at highway speeds that caused all sorts of discomfort to the underside of my old POS Bronco 2. No guards on that pinnacle of Ford engineering, and I had to replace the radiator due to a 2 dollar piece of plastic. Put the guard back on. Heck, you can have my old stock one if you're ever in the Richmond, VA area. Chances are you'll never need it daily driving, but why take the risk?
    djhase and marbleville like this.
