  1. Jul 7, 2021 at 6:54 PM
    18" TRD Off Road Wheels
    Wait, @bmf4069 let's you pay cash? :confused: He makes me spoon him for membership dues!
    At least I get to be the big spoon, but still....
    CodyP, chrisb, bmf4069 and 3 others like this.
  2. Jul 7, 2021 at 6:59 PM
    NWPirate
    Zach
    WA
    Trade brother from another mother discount I guess?
    :confused:
  3. Jul 7, 2021 at 7:58 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    I made them turn the debit card BACK to an ATM card. WTH would I want a debit card when I can earn an extra months+ interest on my money by using a credit card?
    des2mtn, Darkness and FrenchToasty like this.
  4. Jul 7, 2021 at 8:05 PM
    Sort of genius is you run a small business, when I worked for McDowells; I bought a lot of shit being maintenance; all towards those frequent flyers miles for the owner!!!!
    chrisb and Darkness like this.
  5. Jul 7, 2021 at 8:21 PM
    NUDRAT
    SW CT
    It's my understanding tankless needs you to run full hot to get the heat flowing. Dunno if that's true or not. Would annoy me.
    I went traditional tank (gas) because my house runs when the electricity goes out. My gas hot water needs no electricity. My ancient gas furnace needs no electricity other than the blower - but heat rises so no big if no fan.
    Can you have hot water with a tankless if the electricity goes out?
    There's so many power out episodes around here that it's kinda irresponsible to not have a backup generator. I got the RV instead, and a house that works without electricity.
    onesojourner and NWPirate like this.
  6. Jul 7, 2021 at 9:23 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    NUDRAT[OP] and Sirfive like this.
  7. Jul 7, 2021 at 9:46 PM
  8. Jul 7, 2021 at 9:47 PM
    A ron Swanson drill pass is any drill press @empty_lord uses.
    CodyP and Tundra2 like this.
  9. Jul 7, 2021 at 9:51 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Where do we send the nudes? And do they prefer tasteful, gratuitous, or absurd?
  10. Jul 7, 2021 at 10:26 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’ve got an ol clausing drill press and it’s been fantastic
    onesojourner[QUOTED] likes this.
  11. Jul 8, 2021 at 3:31 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  12. Jul 8, 2021 at 4:17 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Those are great machines. I kind of like the look of the older models.
    NWPirate likes this.
  13. Jul 8, 2021 at 6:47 AM
    @Darkness
    In the first picture, that duct tape is covering a hole. It's open there because the venting for the previous HVAC used the same vent as the water heater. So that should be replaced IMO. Also, all 3 companies have said the angle for the vent is no longer at code. Supposed to vent straight up..?
    NUDRAT[OP], Darkness and FrenchToasty like this.
  14. Jul 8, 2021 at 6:55 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Whats the crooked upside down tank? I dont thing ive ever seen that before. Pressure booster?
  15. Jul 8, 2021 at 6:56 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    If you spit on it first, it works better.
    Are you really living if your life isn't in danger?
  16. Jul 8, 2021 at 6:56 AM
    Water expands when heated, and it’s good to have somewhere for it to expand to; it’s called a expansion tank.
  17. Jul 8, 2021 at 6:58 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    well shit.
    My 50 (55?) gallon water heater doesn't have one of those.
  18. Jul 8, 2021 at 6:58 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @FirstGenVol the vent doesn't have to run straight up for that heater but it definitely should have an elbow rather than a makeshift T fitting there. The only part that isn't DIY friendly is your copper pipes are hard lined to your heater, so it has to be cut out and sweat together again. In California we have supply lines (flexible hose like a giant ss brake line) that make it easier on DIY.
    Sweating copper isn't hard, but getting all the water out of the lines to sweat copper can be a pain. Seeing those things, it might not be a bad idea to hire this one.
    NUDRAT[OP], bmf4069 and FirstGenVol like this.
  19. Jul 8, 2021 at 7:10 AM
    Oh now I see why you were saying I should install it. I've done many faucets over the years with those style hoses. If that were the case I'd feel comfortable hooking up the lines. I'm not about to try and sweat copper.
  20. Jul 8, 2021 at 7:11 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Same here in PA.
    @FirstGenVol you could add some supply lines. I know a lot of folks are leery about Sharkbite fittings but I've also never first hand heard of one failing. You would need to relocate the expansion tank though.
    https://www.homedepot.com/p/SharkBi...tegrated-Ball-Valve-u3088flex18bvlf/202685676
    Add in a new 90 and what looks like a reducer for the vent and you'd be set.
    Darkness[QUOTED] likes this.
  21. Jul 8, 2021 at 7:15 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Ok, ive got an expansion tank, but its under my sink, and has an air bladder in it. I never knew what it was called, but it helps push water through my RO filters.
  22. Jul 8, 2021 at 7:18 AM
    How does the end of that attach up top? There are no threads.
    Space is already really tight there. Where would you put it?
  23. Jul 8, 2021 at 7:20 AM
    My last house didn't have it either. I don't understand why since it seems important.
    Randy Morton likes this.
  24. Jul 8, 2021 at 7:24 AM
    That is basically a booster to support high usage, it stores extra water, when more water is being used than what it can produce
    I don’t have one in my house……
    Sirfive[QUOTED] and Darkness like this.
  25. Jul 8, 2021 at 7:26 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Shark bite fittings just click into place. Really, you push it on and it clicks, thats it. I've always been weary of them but haven't heard of them failing either.
    The expansion tank you could probably move up if you got creative and loop the supply line.
    Festerw likes this.
  26. Jul 8, 2021 at 7:27 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I don't have an expansion tank either. Pressure regulator at my intake and a relief valve on the heater that has never released.
    chrisb and onesojourner like this.
  27. Jul 8, 2021 at 7:30 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    My dads last house was on the end of a cul de sac, and his whole house had like 90 psi water pressure. Showers were great, but using the sinks was messy if you didnt know what you were getting into.
    NUDRAT[OP] likes this.
  28. Jul 8, 2021 at 7:40 AM
    Darkness, bmf4069 and Randy Morton like this.
  29. Jul 8, 2021 at 7:40 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    An expansion tank is only necessary if you have a closed loop plumbing system. When the water in the tank heats up, it expands. If there's a check valve on the supply line that keeps water from going back into the main supply from your house (sometimes separate, sometimes in the water meter) the extra pressure can damage the lines and fixtures in your house.
  30. Jul 8, 2021 at 7:40 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Teaser for my walking trail. Ignore the blue lines. I had to submit a plan, but that plan isnt set in stone.
    209965468_10159227943085275_320875161041_c29717fe7ea03d720e46a4683cfbec1767bbc155.jpg
    210645815_10159227940960275_466270840119_1dc829429a2fe05c6a4a34c3e49473458e7d97c8.jpg
    NUDRAT[OP], chrisb and Darkness like this.
