  1. Jul 6, 2021 at 10:49 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Been a long couple of days pulling trim, making holes and running wires. Got a RedVision display head installed in the overhead console. Mounted it to the useless card holder panel. It will monitor and control the rear lithium battery system, and solar and ac inputs.
    12v 202 amp hour lithium battery - 37 lbs total - such amazing energy density.
    szabo101, Paulskie, 2mchfun and 16 others like this.
  2. Jul 7, 2021 at 3:34 AM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Looks sweet. I was looking at that same rack with tonneau brackets. Do those tonneau brackets mount to your bed rail tracks? You mind taking a pic of how they mount under your tonneau?
    TIA
  3. Jul 7, 2021 at 6:25 AM
    Tunka
    Tunka New Member
    So cal
    2018 sr5 crwmax
    2.5 leveling kit 30555r20 ko2 fuel assault wheels
    Atlas progressive expedition pack and bilstein shocks installed
  4. Jul 7, 2021 at 7:35 AM
    UFG8R75
    UFG8R75 New Member
    Frank
    2021 Cement Tundra Limited
    Did you wrap or paint the tail lights? Same with the third brake light?
  5. Jul 7, 2021 at 7:36 AM
    CoachJ
    CoachJ New Member
    J.
    2021 Tundra Trail
    TRD Pro Exhaust Muffler Delete
    Thanks! Just learning how to take long ISO shots and set up for sunrises/sunsets
  6. Jul 7, 2021 at 7:41 AM
    ryanryan34
    ryanryan34 "Its almost done"
    Olympia WA
    2016 Supercharged Overland Build
    Supercharger, Carven Cat-Back, Rough Country Heavy Duty Front and Rear Bumpers with grill insert, , BDS 3" Suspension Lift, 18x9 XD 820s, Kenda Klever 33x12.5, AJT Designs interior items, De-badged, Tuffskins custom door sills, RCI Skid plates. Victory 4x4 Bed rack and Stiffeners. Roofnest Condor XL RTT
    You will love it. Just had mine installed about a week ago. First tank of gas will go quick, just saying
    3xYOTA, sbxx312, AZTundra and 19 others like this.
  7. Jul 7, 2021 at 7:56 AM
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    These particular brackets don't mount to the rails since the rail is lowered by the Revolver X4 cover. I think KB Voodoo has a set of longer brackets that mount to the rails. That said, here are some photos from RCI's website as I didn't take any before putting the tonneau cover back on. The tonneau cover basically clamps in the z-brackets (you can drill through the top down through both brackets for added support), and I'm surprised at how solid it is without drilling them in. I'll try to take some photos
    I did use blue loctite on the feet for the rails and the bracket bolts.
    instructions with more pics (pdf): https://rcimetalworks.com/wp-content/uploads/2020/07/Bed-Rack-Tonneau-Adapter-Kit.pdf
  8. Jul 7, 2021 at 7:59 AM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    I painted with VHT Nightshades on all three
    UFG8R75[QUOTED] likes this.
  9. Jul 7, 2021 at 8:23 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
  10. Jul 7, 2021 at 8:23 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    @Tunka what is that location of photo? Almost looks like NM.
  11. Jul 7, 2021 at 8:32 AM
    UFG8R75
    UFG8R75 New Member
    Frank
    Might have to try them out if I can make them look as clean as yours. Did you take the lights out before painting or did you mask off/any other recommendations?
  12. Jul 7, 2021 at 8:37 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    It wasn’t easy but at the end of the day, I have put my family’s needs first for the past 18 years and my wife knows how much I wanted this upgrade and that is that really.
  13. Jul 7, 2021 at 9:04 AM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    I took them all out. I sprayed thr VHT very lightly, therefore you could immediately tell it was a home-job. That’s where an application of 1k clear coat comes in. It smoothed out all of the small bumps that spray on smoke leaves. I also suggest sanding it with 1000grit or lighter. I used 500grit on the passenger taillight and it required 3 coats of clear instead of one like the driver
  14. Jul 7, 2021 at 9:26 AM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    Enjoy it!!
    NjPro[QUOTED] likes this.
  15. Jul 7, 2021 at 9:37 AM
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    What were the before and after dyno numbers?
  16. Jul 7, 2021 at 10:35 AM
    NickDPT
    NickDPT New Member
    SoCal and DTX
    2020 White 1794 4x4 TRD
    Bilstein 6112/5160 set at 2.5 OME Dakar leaf springs Built Right UCA Falken Wildpeak AT3W 285/75/18 Decked drawer system Front Runner overbed rack Rago dash plate for RAM radio and phone mounts
    IMG_0609.jpg Reba finally got bigger and rides like every big girl should, like a dream!
    Falken Wild Peak 285/75/18
    Built Right UCAs from Excel Suspension/SD Truck Shop
    No spacers yet; will go with minimal probably .25" to eliminate minor rubbing at max turn angle
  17. Jul 7, 2021 at 10:45 AM
    NickDPT
    NickDPT New Member
    SoCal and DTX
    Damn man! Genuinely excited for you!
    Been waiting to live in a state that will let me, and will be next month!
  18. Jul 7, 2021 at 10:51 AM
    abonko
    abonko New Member
    Lifted. Cooper 34s. Go Rhino running boards.
  19. Jul 7, 2021 at 11:49 AM
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    I thought it looked like Sedona, Az.
    Dc2015 and AZBoatHauler like this.
  20. Jul 7, 2021 at 12:28 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Toytec has this leaf pack shim that they say "can be used to help with the drivers lean that is common with Toyota trucks." Is there a reason to avoid shimming up one side on the axle? I know top plate shims are used on the front coilovers to help with the front, but I'd never seen any mention of doing this under the leaf springs.
  21. Jul 7, 2021 at 12:37 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Good to know! Thanks!
  22. Jul 7, 2021 at 12:45 PM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    Making me excited or my truck. Today is the production day according to the dealer! got an MGM on the way
    What did you use for a lift?
  23. Jul 7, 2021 at 1:06 PM
    dbldutch
    dbldutch Full send
    Dutch
    Highlands Ranch, CO
    2021 Black SX SR5 crew
    Trd pro headlights, baja designs fog lights, total chaos uca's, toytec lift
  24. Jul 7, 2021 at 1:16 PM
    abonko
    abonko New Member
    jimbrophotodotcom likes this.
  25. Jul 7, 2021 at 1:26 PM
    floridadatatech
    floridadatatech New Member
    Pete
    Port Orange
    2021 Tundra SR5 Crewmax Cement
    1- Red Tailgate Letters 2- Nerd Side Rails 3- Black Exhaust Tip 4- Cold air intake 5- Black Rhino 20” Forge 6- Nitto 305/50/20
    5EDF5736-60C0-4F3F-B20D-38DA21DA4BC9.jpg 29D5F18B-E3A8-4CE4-827D-A8CA9D905271.jpg New wheels 21 crewmax
    Stock height 305/50/20
  26. Jul 7, 2021 at 4:46 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Hit a milestone. Pardon the dust. Photo taken on a flat, straight stretch of road with no one around. Also, did my 3rd oil change (1st at 500mi; 2nd at 3k) and switched from Mobil1 to Amsoil. Engine definitely runs quieter. Almost no ticking. Crazy!
  27. Jul 7, 2021 at 4:59 PM
    mikesTundra77
    mikesTundra77 BRAAAAP BRAAAP
    M_i_k_e
    earth, sol system
    BLOOD,SWEAT+BEERS
    4 " ready lift kit General grabbers 35" Rock warrior wheels 17" Leather Clazzio seat covers KN intake StartX remote starter HRS sequential tails Custom grille+badge ME-SO map lights+dome light Lots of CHROOOOME
    Clazzio seat leather/vynil covers are on. Tuff install cuz I did it alone. 2 people are recommended tho. Somewhat expensive but I think they are worth it. Finally got that leather smell and they fit great.
  28. Jul 7, 2021 at 5:09 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Love the blue stitching!
  29. Jul 7, 2021 at 5:22 PM
    Wallygator
    Looks great! An that shifter is awesome:thumbsup:
  30. Jul 7, 2021 at 6:01 PM
    CoachJ
    CoachJ New Member
    J.
    2021 Tundra Trail
    changed the rubber…
    the goal is to stay as stock as possible
    my 4Runner is the play toy/project
    stayed w/ the wheels that came stock
    BFG KO2 in 275/70R18
    absolutely NO modifications
    94654F09-8B18-4874-A946-9DAE89C83318.jpg 52A9DD71-DF52-40CE-9931-D06EA1472C5B.jpg BEA48046-35F6-4EE2-939B-B3AE6AF042E4.jpg
    my personal favorite angle to shoot the truck
    she’s named Lana Rhodes LOL
    3xYOTA, D4x4TRD, KWC and 26 others like this.
