  1. Jul 6, 2021 at 4:08 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
    Drained a can blastin' my nuts and bolts. Will have to go pick up some more PB Blaster or Liquid Wrench, whichever happens to be in stock when I go out later this week. Rear Sway Bar shipment appears to have been delayed by two freakin' months.
    FirstGenVol likes this.
  2. Jul 6, 2021 at 5:01 PM
    That sway bar won't be difficult to install. We can do it later.
  3. Jul 6, 2021 at 5:54 PM
    Cummins3500
    Logan
  4. Jul 6, 2021 at 6:04 PM
    The kit I did wasn’t bad, maybe try not doing the block off plates if you don’t HAVE to
    TRDGen and Cummins3500[QUOTED] like this.
  5. Jul 6, 2021 at 6:19 PM
    Cummins3500
    Logan
    @FrenchToasty which kit you go with? From what I can tell the block off plates tend to be a pain to install lol
  6. Jul 6, 2021 at 6:21 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Anybody know how often the rear drum brakes should be serviced? Are there any available upgrades for them other than disc conversion?
  7. Jul 6, 2021 at 6:21 PM
    I found a user on t4r that makes a kit; Slyfox. Under 50 shipped without block off plates. I did injection delete when I put headers on that eliminated the tube, therefore I didn’t need the plates.
    Yes I’ve heard they are a pain just because there’s no room. What were your codes again? Or what did they point to?
    onesojourner and TRDGen like this.
  8. Jul 6, 2021 at 6:23 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    I'm wondering if they're needed as well or only needed to run the non vvti style headers to save some major coin.
  9. Jul 6, 2021 at 6:24 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    And now I know. Thanks
  10. Jul 6, 2021 at 6:25 PM
    So that’s what I did and for that reason, ran the long tube non vvti version, and then didn’t need to order the block off plates, it’s super nice not hearing those hoovers in the morning!
    TRDGen[QUOTED] likes this.
  11. Jul 6, 2021 at 6:25 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Yeah I can't wait for the day I do the same
  12. Jul 6, 2021 at 6:27 PM
    Cummins3500
    Logan
    *P1445- secondary air Injection switching valve stuck closed bank 2
    *P1442- stuck closed in secondary air injection vacuum switching valve bank 1
    *P2441-secondary air injection switching valve stuck closed bank 1
    also throwing catalyst effiency belowthreshold (p0430) and high voltage oxygencircuit sensor bank 1 sensor 2 (p0138)
    I figure I’ll address the sais codes and then worry about the last 2
  13. Jul 6, 2021 at 6:29 PM
    @Cummins3500 this is basically all I had to install and hide it in the loom on the way to the maf
    @TRDGen i went full custom off of the long tubes, the borlas don’t do much muffling haha.
    I’d also like to tune the exhaust back pressure some, I feel like my dual 2.5 needs a little restriction for more BP
  14. Jul 6, 2021 at 6:31 PM
    I’m guessing if they are stuck closed, you won’t need the plates. Not sure if you’ve replaced all O2s/ checked harness, but your cats might be done, perfect time to do headers……..jk I know you just got her back from the doctor
  15. Jul 6, 2021 at 7:16 PM
    Cummins3500
    Logan
    I’m curious to see how hard they are to get in. Hewitt recommends install but I’m sure that also doubles as a sale tactic also. We’ll play that one by ear. At least those codes can’t send me into limp mode :anonymous::bananadead:
  16. Jul 6, 2021 at 7:22 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You want them. Eventually the exhaust gasses will erode the valve away.
  17. Jul 6, 2021 at 8:25 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I took the river dust off.
    I had a suspicion that my weathertech floor mat was interfering with my gas pedal.
  18. Jul 7, 2021 at 3:47 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Pretty much I just open them up if the parking brake won't hold the truck.
    No upgrades I'm aware of other than the disc upgrade.
    TRDGen[QUOTED] and oscardog86 like this.
  19. Jul 7, 2021 at 11:39 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Changed to these. No reviews yet.
    Thrussn and Darkness like this.
  20. Jul 7, 2021 at 11:42 AM
    empty_lord
    05 rollover special
    That’s what my 05 has stock
    Tundra2[QUOTED] likes this.
  21. Jul 7, 2021 at 11:45 AM
    empty_lord
    05 rollover special
    I actually thought the same. But checking mine it wasn’t. The throttle % is % max voltage. It’s not corresponding to throttle opening. Mine maxes at 84%
  22. Jul 7, 2021 at 11:53 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    With my floor mat in I was only able to press the throttle to 54%. With the mat removed it goes to 74%. The weird little hump on the back and bottom of the pedal made contact with the mat. Your floor mats may be different too.
    Both of those pedal ID sensor screenshots were with my foot lightly pressing the pedal to the floor.
  23. Jul 7, 2021 at 12:03 PM
    empty_lord
    05 rollover special
    Ah. Fair enough
  24. Jul 7, 2021 at 12:07 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I hope this is for some sort of cooling alcohol/distilled water misting shenanigans. It has come up a couple times in different threads in the last week or so.
  25. Jul 7, 2021 at 12:17 PM
    There are posts on here describing how to fix that leaking rear window. Let me know if you haven't found them and I can try to dig them up.
    mbreed2[QUOTED] likes this.
  26. Jul 7, 2021 at 12:27 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Filled up petrol holding area. 19.3 gallons. $54.09. Added a quart of oil. Added about yay much seafoam to the crank case. Remembered my oil test kit I ordered. Cussed myself. Drove off.
    NUDRAT, onesojourner and NWPirate like this.
  27. Jul 7, 2021 at 12:40 PM
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    Thanks, I have seen them. Gonna take a look under the third brake light.
  28. Jul 7, 2021 at 12:49 PM
    mbreed2[QUOTED] and FrenchToasty like this.
  29. Jul 7, 2021 at 2:59 PM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Thanks, I have not seen this one. Good write up. Still, not sure how that window comes out.
  30. Jul 7, 2021 at 2:59 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hand jiu-jitsu.
    Thrussn and NUDRAT like this.
